Old 09-18-2016, 10:05 AM   #841
The slide-out clothes rack is a great idea...where did you find that one?
Old 09-18-2016, 02:42 PM   #842
Chassis: TC2000 RE
Engine: 8.3l Cummins
I made them from some thick wall dom stainless pipe and a stainless rod. They are loose tolerance to avoid galling. I drilled some holes on the end of the rod and the end of the tube and ran a roll pin, which then was assembled into the plywood hanger ends.
It's not that complicated. A little loud (scrape scrape) when opening and closing but it's super simple and should last forever. If I felt inspired I could probably come up with a simple nylon bushing on each end to eliminate the noise.
aaronsb is offline   Reply With Quote
Old 09-18-2016, 08:41 PM   #843
Great job!
Old 09-19-2016, 01:39 AM   #844
Chassis: TC2000 RE
Master bedroom door. Keeps the peanut gallery out. Its a nice space saver, and still locks. Little felt pads and some angle channel helps keep the sound from traveling.
The clear plastic panel above lets natural light in from the roof hatch.
Old 09-19-2016, 10:37 AM   #845
Chassis: B3800 Short bus
That is a really neat use of slides! I'm sure the hardware costs half of what the big box stores want for pocket door slides.
Old 09-19-2016, 01:46 PM   #846
Chassis: TC2000 RE
A set of 20" full extension drawer slides cost 20 bucks, I used two sets.
Old 09-19-2016, 01:56 PM   #847
Chassis: International S3800
badass on the slides!! love it!
Old 09-25-2016, 06:54 PM   #848
Chassis: TC2000 RE
Getting some cabinet faces installed.
Old 09-25-2016, 09:33 PM   #849
MuddaEarth's Avatar
Rated Cap: 66 Passenger
Dig'n the master bedroom door! Your bus is coming along really nice man!
I need to get back to work on mine....I just moved from the previous location where I was working on Transcendence. The owner of the property is selling and moving to Colorado....so, I'm now relocated and ready to get to work!!
If you want to teach people a new way of thinking, don't bother trying to teach them. Instead, give them a tool, the use of which will lead to new ways of thinking.
― Buckminster Fuller
MuddaEarth is offline   Reply With Quote
Old 09-25-2016, 10:38 PM   #850
Chassis: TC2000 RE
Good to hear you are set up again. Since you have the foam on the inside it should be pretty cozy to work in this winter without a lot of moisture condensing on things.
With that big door in the back I would imagine you could make a little workshop space to construct the rest of the interior!
If it helps I'm using 5 ply 1/2" birch for all the cabinetry. Its a great wood, seems dimensionally stable and takes a good hard finish. Birch's hardness is up there with oak, but doesn't have that deep grain (which I don't really like)
