Old 08-15-2014, 01:06 PM   #61
Re: The Broccoli Bus
Sweet.....mom...hotdogs and beer would be good
Old 08-15-2014, 10:26 PM   #62
Chassis: TC2000 RE
Engine: 8.3l Cummins
Well, I'm no rocket surgeon.
Originally Posted by bansil
stop the scientific crap and just cut it loose
be safe, looks good!!!!!
aaronsb is offline   Reply With Quote
Old 08-15-2014, 10:29 PM   #63
Chassis: TC2000 RE
Blue tape lines are uh...sketched in. Middle spar is installed.
Old 08-17-2014, 07:50 PM   #64
Chassis: TC2000 RE
Got the corners skinned. I think that is the hardest part of the sheet metal work. The rear should be comparatively easy, since its just an arch piece to fill the gap.
I am using 20 gauge on the roof, since that's what bluebird used too.
The center section is cut and fitted, just stopping for a little break.
Old 08-17-2014, 08:01 PM   #65
LuckyChow's Avatar
Coachwork: Phantom
Chassis: Gillig
Engine: Series 50
I'm very impressed with the work on those corner caps. They look terrific!
LuckyChow is offline   Reply With Quote
Old 08-17-2014, 11:56 PM   #66
Chassis: TC2000 RE
Sorry no outside pix with all the transition panels, it got dark.
It was a challenge to weld up that high. I ended up balancing the welder on a cooler on the dash, and running the lead out through one of the old upper flasher light holes.
Old 08-17-2014, 11:58 PM   #67
Chassis: TC2000 RE
Thank you for the feedback. I wasn't sure at first how much deconstruction needed to happen before adding the caps. It turns out I removed that whole section of the roof except for a 2" strip to weld to. If someone was crazy enough to do so they could chisel all the rivets off and pull that whole transition cap. I tried to be faithful as possible with what I am capable of to the way the bus is constructed.
Old 08-18-2014, 04:09 AM   #68
LOOKS GREAT!
Old 08-18-2014, 10:49 PM   #69
Chassis: TC2000 RE
Got the bits seam sealed and riveted. Now I need to get the rear cap done. Pretty sure that's just a bunch of rivets, sheet metal, and sealer so we'll see.
Old 08-20-2014, 11:20 AM   #70
Chassis: P-30
Engine: GM6.5
Rated Cap: 28
Nice work!!!! Sorry I didn't see your post about helpers sooner, were in Tacoma.... Holler if anything else comes up..
Wooftfd is offline   Reply With Quote
Old 08-22-2014, 12:21 AM   #71
Rated Cap: 40 Prisoners
If you need holding tanks or toilets I have several spares, whats your address so I can
stop in and see it some time maybe give some hints or advice.
Old 08-22-2014, 01:50 AM   #72
Chassis: TC2000 RE
I'll be working on it this weekend. I haven't had a lot of time this week to make progress. I think I've found the solution to the rear end cap and how to make it complete again - I've cut the strangely shaped arc corner pieces to mate up and form the corner.
It's also possible I may be picking up the sheet metal for the sides, not sure yet. I basically need approximately 70 linear feet of 20 gauge sheet metal, that's a lot of steel!
Old 08-22-2014, 12:29 PM   #73
browncrown's Avatar
Rated Cap: 79 at Birth
Roof is looking GREAT!
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 08-23-2014, 03:27 PM   #74
Chassis: TC2000 RE
Sides will be installed...sooooon.
Old 08-23-2014, 06:39 PM   #75
big_bertha's Avatar
Chassis: TC/2000
Engine: Cummins 6CT8.3
Rated Cap: 76
That looks real. I'm envious! Roof is looking great!
YouTube | Facebook
big_bertha is offline   Reply With Quote
Old 08-23-2014, 09:09 PM   #76
Chassis: TC2000 RE
Ready to rivet the last cap panels in after dinner.
There is still a lot of trim work to make it all look proper, so don't worry!
Old 08-23-2014, 10:19 PM   #77
Chassis: TC2000 RE
Lmk if you need something riveted!
Old 08-24-2014, 12:04 AM   #78
Chassis: TC2000 RE
Making some endcaps. Very high tech, fence boards and vice grips.
Old 08-24-2014, 10:46 PM   #79
Chassis: TC2000 RE
Here is the outside of the endcap as it is mostly done. It seems to take a long time, but really I have only worked on it a few hours here and there.
Left curved side is fixed with vhb tape and is ready for rivets right side is sort of flapping in the breeze before I pinned it into location.
Second photo shows what the interior looks like.
Old 08-24-2014, 10:52 PM   #80
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
wow looking good there
proconsul100 is offline   Reply With Quote
