Old 02-10-2014, 10:23 PM   #231
Re: The Brown Crown
BC, when I visited you a couple of years ago you told me where you got your window shades and I'm sorry to say that I've forgotten. Would you refresh my memory please as these are what I'd like to use on my skoolie. Thanks, Jack
Old 02-11-2014, 06:45 AM   #232
browncrown's Avatar
Rated Cap: 79 at Birth
Re: The Brown Crown
Jack, they are UV resistant screens I got at Home Depot
BC
Old 02-11-2014, 10:43 PM   #233
Re: The Brown Crown
looks factory build.
well done
Old 02-23-2014, 09:48 PM   #234
browncrown's Avatar
Re: The Brown Crown
Making some progress on the bus today. The basic frame for the new wet bar in the Crown begins to take shape. Can't see it in these pics, but I also drilled holes in the floor for the plumbing for the sink. On the left end, there will also be an extension of the length, but only half as high. It will funciton as a smaller cabinet space and a place to put the coffee maker so that is does not block the view of the TV. Carpet in that area will come up and be replaced with better insulation.
Lot's more framing to be done and getting the electrical boxes put in and wired using the old wires that are hanging on the TV wall.
The inverter will be built into the area as well.
Also got a good deal on a bar sink and faucet combination package at Home Depot for $90
BC
Old 02-24-2014, 11:18 AM   #235
thommassey's Avatar
Chassis: All American RE
Engine: 3208TA Cat 250HP
Re: The Brown Crown
What size/type inverter are you using BC?
TUMBLEWEED (AKA Rufus) build:
viewtopic.php?f=9&t=11121
PICTURES : http://s1338.beta.photobucket.com/user/ ... M-HP/Rufus
thommassey is offline   Reply With Quote
Old 03-02-2014, 05:36 PM   #236
browncrown's Avatar
Re: The Brown Crown
Originally Posted by thommassey
by thommassey Ľ Mon Feb 24, 2014 9:18 am
It's a ProWatt 2000
BC
Old 03-02-2014, 05:42 PM   #237
browncrown's Avatar
Re: The Brown Crown
Got some more construction work done on the wet bar project. I was able to get a countertop piece cut for the sink and a built-in ice bucket. I also ran the electrical for two GFI sockets and got the plumbing almost done. I had to offset the plumbing through the floor becasue below this area is a bulkhead seperating the engine compartment from what was the spare tire compartment and I didn't want to cut through the bulkhead. Here are a few pics of the recent work.
BC
Old 03-02-2014, 06:29 PM   #238
Re: The Brown Crown
Looking good BC. Is the piece of clear plastic hose a drain for the ice bucket?
Old 03-02-2014, 06:52 PM   #239
browncrown's Avatar
Re: The Brown Crown
Originally Posted by ol trunt
by ol trunt Ľ Sun Mar 02, 2014 4:29 pm
Yes, that is what it is for. The tube will go through the floorboard to the outside. The bucket will also have an insulated lid that will fit nearly flush with the counter when it is completed
BC
Old 03-09-2014, 09:19 PM   #240
browncrown's Avatar
Re: The Brown Crown
This weekend I was able to finish building the shelf and supports for my reconstruction project. I also built a protective covering for the inverter which is open at the front and back for ventilation, but the front will have a small door to prevent kicking the inverter with the feet
About 3/4 of the way done with this now, most of what is left is finishing work
BC
Ohio Crown 1971 Crown iusvir Skoolie Conversion Projects 10 03-08-2017 07:31 AM
HELP .Crown ?s Lord-Maniac Mechanical and Drivetrains 8 06-20-2014 04:42 AM
Looking for a crown bus tubing&adventures Classifieds | Buy, Sell, Swap 30 12-14-2009 12:14 PM
brown recluse spyder timbuk Everything Else | General Skoolie Discussions 18 09-03-2009 01:39 AM
Crown ??? Crown buses??? The best of all the school buses frank-id Conversion General Discussions 1 03-05-2006 04:30 PM
