Old 01-23-2019, 06:25 PM   #201
Those should look pretty cool.
Old 01-23-2019, 06:33 PM   #202
Thanks, I hope they don't look out of place when I'm done. hard to picture them when holding them against the old windows and picture the old windows not there.
Old 01-23-2019, 06:51 PM   #203
RV windows sure are nice.
Old 01-24-2019, 08:05 AM   #204
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
I'm sure they'll look good. If you can get the top one tucked up under the roof ledge it'll help keep it from leaking. Also, I had bought some black butyl tape that I used on my RV windows. It sucked. The white stuff worked way better. I ended up using roof and gutters sealant in the caulking tube after install to ensure no leaks.
Nick
Old 01-25-2019, 03:59 PM   #205
OMG, started to cut up the bus today. Cutting the ribs out of two windows to mount the RV bunk windows.
20190125_143245.jpg   20190125_143415.jpg   20190125_153442.jpg   20190125_161611.jpg   20190125_161627.jpg
Old 01-25-2019, 05:22 PM   #206
Ninjakitty's Avatar
Looks great
Nick
Old 01-25-2019, 05:42 PM   #207
Thanks, now I have to find a way to repair the lower corner of the window skins. International has that pesky reveal and I can't skin below the rub rail without having a horizontal seam. I could buy a full International 3 window skin (4' x 7'), for $180. But I don't need the reveal above the rub rail.
It was hard to cut a section of rib out without going through the skin.
Old 01-25-2019, 06:10 PM   #208
Lookin' good!
Old 01-25-2019, 08:16 PM   #209
Man those look awesome!
Perfect execution. I'm going for something similar in the shorty where we'll have a bunk bed.
Old 01-25-2019, 08:21 PM   #210
Thanks, I think I will replace the short rib sections between the windows with more 1-1/4" tubing. The other side I will assemble the whole section on the floor, weld it , then fit it in the wall. I think I can do a cleaner install that way.
Old 01-26-2019, 05:41 PM   #211
So I go out today and work a bit on the windows on the other side. Taking my time and thinking will leave me with a cleaner install than the other side. I was going so well, decided to knock off before having to do the custom trim of the skin so I don't have square corners showing. I get the top window section made and installed and welded in place. I go to the other side to take a measurement and realize, looking through the bus, and realize things don't look lined up. WTF, I installed it one window too far forward. Now I have to cut it out and move it back and replace the rib I cut out. I'll get a section of rib from the rear window to replace it with.
Old 01-26-2019, 05:44 PM   #212
The front window I cut by mistake is not a big deal as that window was a delete item anyways as the shower or fridge will go there and not have a window behind it. If I'm careful, the rub rail section I need to cut here will be just long enough to splice in across the E Door delete.
Old 01-27-2019, 08:56 AM   #213
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
We got doorS. Still a bunch of mods to complete. Need a bar going down the inside edge of the left door for the rubber moulding on the right to seal against. Need 4" extensions on top. Looks good so far. I still need to wire all the lighting that was transferred to the doors.
How tall will your doors/opening be?
Assuming your bike[s] will fit inside?
Lookin' good so far.
Old 01-27-2019, 10:54 AM   #214
The door opening will be right at 58". The Triumph is only 41" and the Harley is smaller. So no issue fitting bikes, I'm trying to have enough headway to keep from taking off your head riding a bike into the garage. I'm sure you will need to duck, but not as much as you would on a 53' opening.
Old 01-27-2019, 02:41 PM   #215
Got the passenger side fixed and ready for sheet metal. This side came out much nicer.
Old 01-29-2019, 03:29 PM   #216
Got that side out of the way, now to mod some rub rail end caps.
Old 01-29-2019, 06:04 PM   #217
Ninjakitty's Avatar
Nice! Looks sweet
Nick
Old 01-30-2019, 06:08 PM   #218
Customized the rub rail end caps for the bunk windows.
Old 01-31-2019, 03:39 PM   #219
Finished end cap.
Old 01-31-2019, 03:41 PM   #220
Pretty cool, marc!
Its the little touches that really make a build stand out!
