03-11-2019, 05:43 PM
#281
Teaser, I'm going to do something in my shower I have never seen done before. I think it will be awesome. Post when I do it.
03-12-2019, 12:52 AM
#282
03-12-2019, 06:58 AM
#283
Originally Posted by o1marc
Got garage flooring fitted. If it doesn't rain tomorrow I will seal the floor.
Seal it how? The plastic matting or the floor in general?
03-12-2019, 07:01 AM
#284
Would likely have been way more expensive but way more cooler with the 2 part epoxy garage flooring that you pour. If you're doing the bus on the cheap forget it but I would think it would be better suited for your bikes and what-not. I'm sure there's a version of the Navy non-skid stuff out there somewhere too. That stuff would give plenty of grip to keep things from sliding around while driving.
03-12-2019, 10:47 AM
#285
The floor itself with Rustoleum
03-12-2019, 10:50 AM
#286
Bikes get tied down, they ain't sliding anywhere. Ya, the epoxy flooring wouldn't fit the budget, this stuff will work just fine. Navy non-skid version just throws sand in the wet top coat.
03-12-2019, 11:04 AM
#287
Was thinking also during loading/unloading that non-skid would be helpful.
03-12-2019, 12:02 PM
#288
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Do you think I need to seal my whole floor if I only have a little rust spot by the A/C lines? Probably 6x6" total. The rest is pretty spotless galv..
03-12-2019, 05:36 PM
#289
What makes you think only the rusty spot will rust? Preventive maintenance is important. I just painted my floor with a roller and cut in with a brush, only took about 1/2 hour-45 minutes
03-12-2019, 06:32 PM
#290
Got the floor done.
03-12-2019, 10:01 PM
#291
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Nice job on the floor. I'm probably at least a month or a shop rental away from warm enough weather to paint. Do you need special paint to go over galvanized?
03-12-2019, 10:09 PM
#292
Galvanized metal must be "etched" prior to painting. There are a number of "Self Etching Primers" that will do the job nicely. You can also use vinegar, Ospho or solution of water & ammonia. A little Googling will get you to a method that should work best for you and your budget.
03-12-2019, 10:50 PM
#293
I used Prep&Etch to, well, prep and etch the rusty floor before painting it with Rustleum High Performance Metal Primer.
03-12-2019, 11:09 PM
#294
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
there are several primers, or cleaners, or chemicals you can use to prepare galvanized metal for painting on the market - ask what your local paint store has to offer
03-13-2019, 06:12 AM
#295
Peakbus,
Ospho and Corroseal are what "everyone" here uses; they are fairly cheap and free shipping with Amazon Prime. A gallon is more than enough to do a 40' floor with 2 coats.
03-13-2019, 06:21 AM
#296
Peakbus,
YEah Ospho is awesome, cheap, and easy to find. Been using it since I was a kid fixing up old rusty vw's.
Great for prepping galvanized or oxidized surfaces for paint.
03-13-2019, 11:00 AM
#297
KleanStrip Prep & Etch from Home Depot is the exact same product as Ospho, only half the cost.
03-13-2019, 11:02 AM
#298
Ospho is half the cost of Corroseal; I got ripped off!!
03-13-2019, 11:48 AM
#299
There is a guy here that gets tanks out of the trailer factory for 45 gallons for 50 bucks
03-13-2019, 12:04 PM
#300
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Thanks for all the replies. I've got a quart of Ospho from a previous job. I was hoping to use it up, so this will do it! I just didn't think it was used on fresh metal. Now I know!
