Old 06-03-2016, 01:04 PM   #91
opus's Avatar
Chassis: All-American R/E
If it has raised ridges on the valve cover, it should be a 360. How many fuel filters are there? 2 usually on a 466, 1 on a 360.
Old 06-04-2016, 10:27 AM   #92
ii_amnt's Avatar
360 it is!
-Travis
1991 International. DT360. Spicer 5-speed manual transmission. Work in progress; spray foam, wood stove, etc...
ii_amnt is offline   Reply With Quote
Old 06-04-2016, 01:22 PM   #93
ArmyChap's Avatar
Originally Posted by Brad_SwiftFur View Post
I'd have to look up what the FBC means.
Full Box Framed Chassis?
ArmyChap is offline   Reply With Quote
Old 06-04-2016, 02:02 PM   #94
Chassis: International S3800
you have close to the same Bus as me.. i have a DT360... mine was replaced by Jasper and they used the 185 HP version of it...
your DT360 is not a bad engine.. I have a carpenter 7 row thats rates at 27500 GVWR.. and it kicks right down the road at 65... and i havent run up the timing or the fuel screws.. I checked and both are bone stock on mine..
you can also get some more horsies quite easily without harming your DT360 by turning up the fuel screw.. and depending on where its set.. 22 degrees timing is completely safe...
the DT360 does in facrt (or should) have 2 fuel filters.. a water separator with a 12 micron filter in it.. and then right under the injection pump a fuel filter that should not be any finer than 8-10 micron... using a 6 (like the DT466 uses.. and it will fit!) can cause your fuel system to lose prime... idle rough. stall or have no power...
the VIN decoder said blue bird school bus for mine too... incomplete bus means it was shipped from IHC (mine was built in springfield ohio).. with just the hood and the chassis.. typically youd see a plastic cover over the front dash to protect it...
seeing school bus chassis towed 2 wheels at a time was commonplace for me as I lived in dayton and carpenter was in mitchelll indiana and wayne was richmomnd (I believe)..
I have the complete set of factory chassis service manuals for our busses...
the wiring diagrams arenbt included for the BODY but are for the chassis... your main wiring diagram for the carpenter is on the header panel above the student mirror.
Old 06-04-2016, 03:28 PM   #95
ii_amnt's Avatar
Yea, I'm sure it's a great engine, too. I just somehow got the idea in my head that it was the 466 without ever verifying it and was mildly disappointed for a bit. I don't feel these conversions add all that much weight and the most I plan to tow is a flatbed with my old Mercedes on it (GVW of 3,500#) and I know I've got the gearing to handle that. One day I may switch out the rear end and do some further traveling with it and get some good highway speeds. I will be staying in the great lake region while I use it, not a whole lot of driving so it really isn't bothering me right now.
I cut out that diagram and saved it from the scrap, planning on framing it up somehow and keeping in the drivers cabin.
-Travis
Old 06-04-2016, 03:41 PM   #96
ii_amnt's Avatar
The interior lights are likely a universal size, and I have a Carpenter bus too ... I need covers for some of my lights and since Carpenter is out of business, finding Carpenter branded covers is highly unlikely.
I plan on reusing mine on my interior, but I'm planning my electrical system now. If I have leftovers, I'll give you first dibs (if you even want them, I don't know how cheap or common they are) .
Speaking of electrical, here's my initial thoughts for how that's going to go for me in the short term. The PD4045KV by Progressive Dynamics seems like a great little product. Just to clarify, this takes shore power that you wire in and will convert to DC for distribution to your DC circuits and the built in charge controller, right?
At first, I'll only have this power panel, my external sockets for shore power and generator and the wiring and outlets throughout the bus. Later, I will buy my batteries and inverter when I get settled in MI and have get some income happening.
I'd like to put as much on DC as I can, at least my lighting for now.
-Travis
Old 06-04-2016, 04:31 PM   #97
before id change rear ends id change the transmission.. an allison 1000 series appears to be a pretty decent fit.. it is a 6 speed where 5 and 6 are overdrive...
run that on a slightly turned up DT360 and youd be more than highway ready... I have 4.78s in the rear on mine and my bus will run 65.. it topped out completely at 65 before but I went with 6 brand new 11r22.5 tires so I gained a few MPH.. or in my case lost a few RPMs because even though it will go 68 now i rather run a schoolbus at 65..
wierd of carpenter not to put an interior light over the driver.. the old waynes used to have a driver light with a separate switch.. if you dont re-use all your carpenter lights id like one to install in that position..
Old 06-05-2016, 07:18 PM   #98
ii_amnt's Avatar
So, I drove to Charleston and picked up some RV windows. Almost picked up a roof-top AC unit, too. I feel like I'm going to kick myself one day for not picking it up- $50 is what he was going to take for it. It was a little beat up and the internals looked a little rusty, but apparently it was still working. Didn't include the fans and I wasn't sure what it would take getting it running electrically with my set up.
So, now I've only got one....maybe two windows to pick up. I may splurge on my picture window for a dual pane and get the absolute biggest size that will fit.
If anyone wants that roof-top unit, he said he didn't have a problem with me handing out. Can't promise $50 since I was buying other stuff, too. Just send me a PM.
-Travis
Old 06-05-2016, 07:53 PM   #99
opus's Avatar
[/LEFT]
I have almost everything on DC. Its there...why not?
I keep my lights like yours and replaced them with LED grid that plug into the socket. Now you need sunglasses at night, inside the bus.
