Old 07-31-2015, 07:41 PM   #11
ii_amnt's Avatar
I have a layout going here. We sketched it out with my daughter's sidewalk chalk on the floor. Seemed to be okay... but those wheel wells are tricky. As this layout is now, you could not shower in the bath. The tub would need to sit on the wheel well. We have been thinking about picking up a water trough from tractor supply for that and building some heavy duty wood support to get the fit right. But, I'd still like to shower for real. Maybe the toilet can sit over the wheel well instead. That would create an awfully odd space though.
Maybe moving the bathroom to the front of the bus would be better.
The rear storage would be totally accessible from the rear door. Tubs could be slid underneath the bed. I would paint the inside of the door windows and hang tools on the reverse wall of the "headboard". There would be 2 or 3 levels of steps proceeding from the doorway and wrapping its way to the night stands. These could be accessed by pulling up pieces of wood that cover them and store clothes or whatever. More drawings to come on that. I may have to cardboard mock up that to see how it would really work in that space. The edges have the least headroom, but I'm not sure I would really use that small amount of space for real walking anyways, just scooting my way into or out of bed.
-Travis
1991 International. DT360. Spicer 5-speed manual transmission. Work in progress; spray foam, wood stove, etc...
ii_amnt is offline   Reply With Quote
Old 08-02-2015, 09:26 PM   #12
ii_amnt's Avatar
Got the floor out today. There was no plywood subfloor, only deteriorated glue barely holding on to rubber. The rust wasn't too bad, shouldn't be too big of a chore to remove and treat. We got out the DSLR and the rest of our pictures should be a little nicer to look at.
The pictures speak for themselves, we tore that bus up. I have a friend coming to help next weekend, so hopefully we can drop the ceiling and walls and start treating rust.
I've included a imgur album since the forums won't resize my pictures for me, or at least I'm assuming that's why my uploads keep failing.
If you look at the pictures I have some of a link of the driveshaft. It seems to be separating. What might cause this to happen? Also, you'll notice the inner set of rear tires have quite a bit of wear. I am pretty upset at myself that I didn't notice that when I bought it.
-Travis
Old 08-03-2015, 11:21 PM   #13
ii_amnt's Avatar
I think it would work a lot better to embed these images into my posts. Maybe I'll redo that last post. But, we are considering a roof raise, liek this wanderlodge here:
https://www.flickr.com/photos/25276600@N04/9496508246/
I'd like to leave the end caps where they are. doing one like this seems less daunting and I actually like the look it will provide. I will likely leave the front and back parts of the cab intact at the same length.
-Travis
Old 08-04-2015, 08:27 AM   #14
I am all for leaving the factory caps intact, but you might consider sloping that roofline. It will make a world of difference in drag.
Old 08-04-2015, 11:31 PM   #15
ii_amnt's Avatar
I am reading through wmkailey's build thread, and it's causing me to still go back and forth on the raise. As I work on the bus, I have yet to have my head even graze the ceiling, but I know I will be loosing at least an inch.
Also, seeing his leaks makes me have second thoughts on doing spray foam insulation. I worry that that would be sealing it all up for life and whatever leaks that may develop, I would have no way to get to them and seal it up and ensure it dries out properly.
-Travis
Old 08-05-2015, 06:02 PM   #16
ii_amnt's Avatar
Local craigslist has an old coal/wood stove.
From what I've read one important factor of having a wood or coal stove in your bus is a good seal on the door. I don't really know much about this type of stove. Any thoughts? The price seems right. Three and a half feet tall may seem a bit overkill, though.
-Travis
Old 08-05-2015, 06:07 PM   #17
Engine: 190hp 5.9 Cummins
I feel roofs should be left one piece, as they are the strongest part of the entire structure.
When I cut mine loose, parts of the floor sagged from rusty floor supports. That means the roof was keeping the floor in position.
Old 08-05-2015, 06:58 PM   #18
ii_amnt's Avatar
I am not totally sold on a roof raise yet. I am wanting to build so that I can break into the walls with ease at later dates to address leaks that arise. This may allow me to do the raise at a later date. But, we will see how deep in $ I get once I have half of my window openings covered. I may not want to ever cut all that. I am on a timeline of about a year to be able to at least move in. That means new windows and insulated and plumbed. A battery bank and sockets for shore power.
If I am using the bus engine to charge house batteries, might I need an alternator with higher rating?
-Travis
Old 08-05-2015, 09:26 PM   #19
Leaks are fixed from the outside, not the inside.
You need a alternator with a higher duty cycle.
Using your alternator to charge your house battery's is the worst, and highest cost method of all options available.
Old 08-05-2015, 09:33 PM   #20
Chassis: I.H.
Nice looking heater, small footprint. I know nothing about them.
