Old 01-30-2016, 05:14 PM   #1
The bus with no name....Yet
We purchased this bus in November 2015 to convert into our mobile house. These are a few pictures that I have so far.
This is the bus before any work had been done. First days home
All the seats out and where properly disposed of.
Beginning to rip up the floor. We bought an old cast iron wood stove and man it's heavy! It will not be leaving the bus again. The spot where it is in the above photo is where it will live along with a hearth.
Ripping up the floor revealed some rust that was taken care of with ospho. Great stuff.
Using a wire brush and grinder to bust the rust. It was the worst around the wheel wells but luckily it was only surface.
Ready to prime. We used Rust Stop from the local ace here in gunnison.
Someone got carried away and forgot the tops of the wheel wells.
All done and now ready for the subfloor to go in. We have 1 inch foam board for insulation and on top of that will be 3/4 in plywood. I am 6'4 so headroom is a must. When it is all said and done with the wood floor put in I figured I will have just under a 1/2 of room before I bonk my head.
JahBus is offline   Reply With Quote
Old 01-30-2016, 07:10 PM   #2
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Try spray insulation UNDER the floor as well. I'll be doing that to Brunhilde after my brother sell's Dad's house.
Old 01-31-2016, 12:43 PM   #3
human being's Avatar
Year: 1994
Chassis: TC/2000
Engine: Cummins 5.9TA
looks good, that's about where I am on mine right now
"Gradually I came to realize that the process of saving the desert of the human heart and revegetating the actual desert is actually the same thing." -Masanobu Fukuoka
human being is offline   Reply With Quote
Old 02-16-2016, 11:25 AM   #4
The spray foam from underneath is a great idea. I will see how this holds up before we do that.
It has been warmer than usual in Gunnison the last couple of days so we have been getting some work done on the subfloor. We used furring strips and self tapping screws to frame around the insulation.
After that we laid down the plywood which will be our flooring until we do the wood floor this summer.
Stephanie scribing insulation
Up to the wheel wells done yesterday afternoon. Hopefully will be done with the subfloor this afternoon.
Old 02-16-2016, 06:19 PM   #5
Year: 1994
Chassis: Blue Bird TC2000
Engine: Cummins 5.9 12V
Rated Cap: ??...It's 28' long
Very nice looking! How tall are your ceilings? I'm 6'1" and if I stand up VERY straight I'm touching the ceiling. I have NO room to add insulation to the floor. Rats!
I will check into spraying insulation under the bus like you mentioned.
You guys are cooking right along. I'm envious of the sunshine! (winter in Seattle does NOT equal sunshine)
lizzabus is offline   Reply With Quote
Old 02-16-2016, 10:05 PM   #6
They are about 6'5 from the sheet metal. I am 6'3 so when I am done with the wood floors I should have just shy of a half inch. I understand that up in Washington. Lived in the Seattle are for a bit. How about this last summer though. Super dry! We went to the Olympic peninsula in August and it rained for about 3 minutes the whole two weeks there. Nothing like I remember the Pacific Northwest. It was in the 30s the last couple of days here in Colorado so I thought I'd better get some work done.
Old 02-17-2016, 10:01 AM   #7
My Blue Bird is in the 'Springs. I've made about as much progress but in over a year. I'm disabled so my energy is limited to a few hours a week. I lucked out getting a 40' with chair lift. If you are ever in the area, I'd be glad to give a tour.
rognyt23 is offline   Reply With Quote
Old 02-17-2016, 01:59 PM   #8
eyedeal.ink's Avatar
that steel floor is gonna stay the same temp as the outside of the bus, nothing you can do about that, not even spray foam underneath. That being said, we added 3/4" foam insulation, 3/4" plywood and 1/2" cork flooring, floor stays pretty comfortable but slippers are a good idea in the winter...I'm 6'3" and that's what I ended up with height wise.
"That's,. like,.. your opinion, man...." - the Dude.
eyedeal.ink is offline   Reply With Quote
Old 03-22-2016, 01:45 AM   #9
Think I might come out with about a 1/4 of head room after floor. We have finished the subfloor and moved onto rough framing. The bed is a queen sized with walk around and two night stands. The compost toilet will be over the wheel well backed by a 30 inch closet. We also found a pretty nice couch that will fit behind the drivers seat. We plan on making a trip to Moab UT in the coming weeks for our first trip after registering the bus.
Old 03-22-2016, 04:24 PM   #10
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
That "convenience" seat seems to be a mite close to the floor. Do you anticipate raising it a bit?
