Old 06-30-2014, 11:33 PM   #401
PDBreske's Avatar
Rated Cap: 1
Re: The Camel Conversion Project
Don't you just hate when random events get in the way of the work you really want to do? One of my external hard drives today decided to stop working. I should say the enclosure decided to stop powering the drive inside it, so I yanked the drive out and connected it to my computer with a nifty adapter that I bought for this very purpose. If you value your data, I recommend you get one of these: NewerTech USB 3.0 Universal Drive Adapter. It has saved my bacon more than once.
The drive in question stores my entire photo library of over 50,000 images. Needless to say, this is pretty important to me. I do have the entire drive backed up, but I'd rather not have just one copy, even if that copy is redundantly stored on a four-drive array. I ordered a new enclosure and another hard drive because this one is getting close to its capacity anyway. That's another $180 I won't be spending on the bus.
After the computer issues, I managed to install the laminate on my kitchen countertop. The pattern is "oiled soapstone" and I love it. I also cut the stainless edge guard to length, although it's still wrapped in protective film, much like the backsplash from an earlier post.
Read about the "Camel" RV Conversion project!
My first passion is photography. Visit my website to see some of my work.
Old 07-01-2014, 12:25 AM   #402
gmarvel's Avatar
Engine: DD6-71T
Absolutely beautiful work! Your wood working skills are far superior to anything I could do. Jealous, but excited for you. It is looking great.
______________________
Greg and Donna Marvel
Danville, California
http://www.transtraks.com
gmarvel is offline   Reply With Quote
Old 07-01-2014, 05:23 PM   #403
PDBreske's Avatar
Rated Cap: 1
Thank you! I'm not really a woodworker, but I am a perfectionist and I tend to do things slowly, but correctly. Sometimes.
Old 07-02-2014, 08:26 PM   #404
PDBreske's Avatar
Rated Cap: 1
Just another test fit of some of the kitchen parts, including the stainless edge trim. I love it and I can't wait until it's finished.
Old 07-02-2014, 08:50 PM   #405
The stainless is beautiful. How are you attaching it?
Old 07-02-2014, 09:07 PM   #406
PDBreske's Avatar
Rated Cap: 1
Well, I'm still trying to figure that out. I was going to use epoxy, but I am thinking it might be better to use silicone caulk or adhesive. Something that will hold metal on wood and not harden. I don't want any water to seep between the SS and the laminate and get into the plywood countertop. I'll also need to use something to hold the backsplash to the wall. Any suggestions? I'd rather not ruin the aesthetics with screws or bolts through the stainless.
I love the look of the stainless so much that I'm probably going to use it for the two or three other horizontal edges I'm planning.
Old 07-02-2014, 10:13 PM   #407
Chassis: All American RE
Nice. I dip out for a few weeks and everybody's bus is finished! Good work for sure.
LandLubber is offline   Reply With Quote
Old 07-02-2014, 10:37 PM   #408
PDBreske's Avatar
Rated Cap: 1
Hah! Not quite. ;) But thanks!
Old 07-03-2014, 11:00 AM   #409
PD, I had good luck using 3-M double sided tape to affix my stainless back splash to the side of the bus. I expect the same material could be cut to fit your counter edging. I used a very narrow counter edge (1/2"x1/2") which didn't give enough surface area to allow for the use of tape. Instead I welded "pins" to the back side. drilled matching holes in the counter, inserted the pins and bent them over under the counter to secure the edging. So far they seem to be holding just fine.
Old 07-03-2014, 11:32 AM   #410
GreyEagle's Avatar
Gorilla glue might do the trick......... just thinking out loud here.
I used it in our house to secure the stainless steel back splash in the kitchen.
just sayin???
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Good News Bus Conversion Project Bus Project Skoolie Conversion Projects 276 02-23-2019 07:50 PM
Jeremy's conversion project swaflyer Skoolie Conversion Projects 40 05-19-2014 06:04 PM
1991 Thomas RE Conversion project tfdfyrman Classifieds | Buy, Sell, Swap 3 10-03-2010 07:04 PM
RyanS's Bus Conversion Project RyanS Skoolie Conversion Projects 11 07-07-2010 08:00 PM
3rd bus, first conversion project Homeskooled Skoolie Conversion Projects 4 11-11-2009 08:43 PM
