Old 07-03-2014, 11:46 AM   #411
Diesel Dan's Avatar
Engine: DT466/AT545
Re: The Camel Conversion Project
I usually default to Liquid Nails for stuff like that. I like the fact that there is a thick bead that gets mooshed, so I feel like there is a better chance for adhesion. I'm no glue expert though...
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 07-03-2014, 12:56 PM   #412
roach711's Avatar
Rated Cap: 19
The counter top is gorgeous!
Originally Posted by PDBreske
The drive in question stores my entire photo library of over 50,000 images. Needless to say, this is pretty important to me. I do have the entire drive backed up, but I'd rather not have just one copy, even if that copy is redundantly stored on a four-drive array. I ordered a new enclosure and another hard drive because this one is getting close to its capacity anyway. That's another $180 I won't be spending on the bus.
Do yourself a favor and keep an offsite copy of your data drive. I back mine up to blueray disks quarterly and store the disks away from home. We had a home break in a couple of years back and my first thought when I saw the door kicked in was how glad I was to have my pictures stored at work. My setup is similar to yours with a redundant array for data and a separate backup drive on my workstation, but a fire or a thief could make both irrelevant.
The Roach Motel
Old 07-03-2014, 04:36 PM   #413
PDBreske's Avatar
Rated Cap: 1
I'll look into it, and thanks!
Read about the "Camel" RV Conversion project!
My first passion is photography. Visit my website to see some of my work.
Old 07-03-2014, 04:37 PM   #414
PDBreske's Avatar
Rated Cap: 1
Yeah, that's what I like about the idea of adhesive or caulk or something. When I push it onto the edge, I want to know it's filling every crack and gap. I think they use Liquid Nails to hang mirrors, don't they?
Old 07-05-2014, 09:14 PM   #415
PDBreske's Avatar
Rated Cap: 1
Another little project is the A/C duct over the entry door. It's taller than the duct opening on its right because it funnels the air through a much narrower opening and I didn't want to impede the airflow. (There will be turbulence inside this duct section, but it's not like I'm testing the next X-plane in there.)
I had a couple pieces of scrap plywood big enough to make both pieces, so I clamped them together and drew a partial ellipse on one surface. Then I cut both pieces while still clamped together to get identical curves on each. The top piece will obviously be hidden inside the duct, so it needn't be pretty.
Onto the inboard edges of these will be affixed a thin, flexible board (or maybe thin-gauge sheet metal), and that will be covered with some kind of reflective material to bounce the light from the ceiling fixture towards the shower on the opposite wall. I'll likely insulate inside the curved board, but only enough to keep the face from sweating due to the temperature differential.
Just in case you're wondering, the lower piece is still high enough that I won't hit my head on it as I enter or leave the bus.
Old 07-06-2014, 01:01 PM   #416
eyedeal.ink's Avatar
lexel is good stuff, I highly recommend it...messy though and it tends to flash over if you don't use it right away, making it impossible to smooth out edges like silicone would, DAP 3.0 crystal clear is really good stuff too, just not usually recommended for straight to wood, don't know about stainless, should be fine, I know silicone eats aluminum. Stay away from gorilla unless you got a good way to clamp it for one hour. Any way you glue it, it'll ruin the surround if you ever had to remove it.
Looking fantastic by the way.
"That's,. like,.. your opinion, man...." - the Dude.
eyedeal.ink is offline   Reply With Quote
Old 07-07-2014, 06:27 PM   #417
browncrown's Avatar
Rated Cap: 79 at Birth
Go ahead and test the next X-Plane in there Beautiful work!
BC
Old 07-07-2014, 07:16 PM   #418
sojourner's Avatar
Engine: DT408
Well, I'm still trying to figure that out. I was going to use epoxy, but I am thinking it might be better to use silicone caulk or adhesive. Something that will hold metal on wood and not harden.
A couple products that I have used in the boat business. One is 3M5200 and the other Sikaflex 291. Both cure flexible, can be tooled to finish and clean up with acetone. I've used both when installing outboard motors and various other underwater connections. I've even had 5200 pull gelcoat when tying to remove an outboard bedded with it. Great stuff and lasts a lifetime.
For areas where adhesion is not as required but sealing is, Lifecaulk is a good choice. You can "sand" it smooth once cured with scotch-brite pads to get a very nice finished look.
You can read about them ta the sites below.
http://solutions.3m.com/wps/portal/3M/e ... 622&rt=rud
http://usa.sika.com/en/solutions_produc ... 02102.html
http://www.boatlife.com/life-calk/
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 07-07-2014, 07:38 PM   #419
PDBreske's Avatar
Rated Cap: 1
LOL. Thanks!
Thanks for the info! I have learned that 3M makes great products, and that anything labeled "marine use" is good for just about any purpose.
Old 07-31-2014, 09:25 AM   #420
Finally caught up in thread, awesome work as is your norm...very good job
Good News Bus Conversion Project Bus Project Skoolie Conversion Projects 271 11-18-2017 10:55 AM
Jeremy's conversion project swaflyer Skoolie Conversion Projects 40 05-19-2014 06:04 PM
1991 Thomas RE Conversion project tfdfyrman Classifieds | Buy, Sell, Swap 3 10-03-2010 07:04 PM
RyanS's Bus Conversion Project RyanS Skoolie Conversion Projects 11 07-07-2010 08:00 PM
3rd bus, first conversion project Homeskooled Skoolie Conversion Projects 4 11-11-2009 08:43 PM
