Old 04-13-2015, 07:42 AM   #61
Originally Posted by family wagon View Post
Now I'm at the black-stuff-on-ceiling problem that Vlad and EastCostCB lamented about not too long ago. Thanks to them for mentioning that spray foam didn't stick to it very well; now I know I need to deal with it before embarking on the foam. But how? I tried rubbing a small area with a naphtha-soaked paper towel and found that it does dissolve the coating, but that could take a really long time. I've thought about using the paint sprayer to apply repeated coats of naphtha and let it soak a bit, hoping to turn the coating into a gel than can be wiped off.
I scrape the black stuff with a thick putty knife or chisel, then go at it with a stripper disc on the end of a drill or angle grinder. I'll update my thread in a day or two. Mine had a ton of surface rust under there. Damn leaky roof hatches!
Old 04-13-2015, 09:08 AM   #62
Engine: 190hp 5.9 Cummins
As long as there is no rust under that tar, why remove it?
Just spray the spray foam directly onto it.
Even if the spray foam delaminates from the ceiling, it won't matter after the ceiling is finished.
Old 04-13-2015, 11:14 AM   #63
maggiemae's Avatar
Year: 1975
Coachwork: Ward
Engine: Ford 391 V8
Hallelujah, we're finally at this point, too!
So you have to Remove this stuff to see if there is rust underneath? Won't the rust just visibly come through?
I'm guessing this stuff is some type of sealant?
Cheers!
-Kelsey and Justin
Thewolfbus.com
maggiemae is offline   Reply With Quote
Old 04-13-2015, 11:36 AM   #64
Chassis: Blue Bird
Engine: ISC 8.3
The stuff on mine is tar-like. It's still a little soft and pliable even after all these years, which is why I didn't really consider sanding to remove it (thinking the paper would just clog with this stuff). It is not applied very evenly -- some places are very thin and dried before they could grab the fiberglass at all; other places are thicker and have a lot of fiberglass stuck in them (another reason not to sand). My guess is that its purpose is to absorb sound, but not very well, and to adhere the fiberglass in place.
As thin as it is I would think any rust would show through. I'm planning to clean up the middle area of each section and not worry about the edges with the hope that foam will adhere well enough to keep itself in place. We'll see how that goes.
Old 04-13-2015, 12:27 PM   #65
Here is mine.
once all the asphalt/tar and rust are gone, I apply ospho then Rusty Metal Primer by Rustoleum.
Old 04-13-2015, 01:00 PM   #66
maggiemae's Avatar
Year: 1975
Coachwork: Ward
Engine: Ford 391 V8
Ah I see!
And the rusty tar is definitely noticeable, good to see that picture for comparison!
Old 04-13-2015, 03:22 PM   #67
Gross. Does a heat gun soften it at all?
taskswap is offline   Reply With Quote
Old 04-13-2015, 03:31 PM   #68
Yeah. but I don't think softening it is the way to go. When its soft it gums up the chisel or scraper too easily. Left in its "solid" state it sometimes comes off in strips if you get a good method going.
Its brutal getting this stuff out.
Old 04-13-2015, 03:37 PM   #69
we used to use dry ice to remove the 1/8 thick rubber crap on floor boards in cars, it would make it hard and then hit with a hammer and pop it up with screwdrivers into big pcs
not sure if working overhead with dry ice is a good thing tho'
Old 04-13-2015, 11:12 PM   #70
Chassis: Blue Bird
Engine: ISC 8.3
I sent a piece of the wall hat channel to that sheet metal shop this morning. I was surprised to get a call back not even four hours later saying the new channel was ready to be picked up! The fit is fantastic. I have one less excuse for dragging my feet about it..
Old 04-14-2015, 08:50 AM   #71
I'm glad you chose the hat Chanel vs tubing.
Looking forward to more pics.
Old 04-15-2015, 06:55 AM   #72
Chassis: I.H.
Wow, that place did a great job.
Old 04-15-2015, 07:13 AM   #73
If anyone in my area needs any hat channel, hit me up. I'm going to be ordering a bunch from the local fab shop. Will most likely go with 14ga Galvaneal.
Old 04-15-2015, 07:08 PM   #74
Chassis: Blue Bird
Engine: ISC 8.3
My brother came out to work on the bus with me yesterday. The fiberglass cap (?) that covers the whole rear end kicked our butts. We got the window out and took the hood/door off, but I don't think we got any of the rivets out. We drilled many of them but then couldn't get the remaining body of the rivet to push out through the back. It is glued all the way around too, and I haven't figured out how I'll break that without damaging the fiberglass. So we let that be for now and moved to something else: the rub rail between the doors on the right side. Got that off and then we were so excited we pushed on and removed the front three lower side panels.
Check out that rib between the two windows -- it is filled in! Here is a close-up:
The hat channel has a piece of.. something.. welded inside it. I don't know yet whether it's a closed tube, or an open C or U shape. In any case I'm now even more happy to have picked the "make more hat channel" route -- if not for that, I'd have a stack of square tube and a broken plan for using it.
I guess these might be done this way because of the large windows -- the bus has only half its ribs actually reaching the floor, and each of these has to carry its own weight plus half the weight on the ribs above the windows too. I'll stick to the original plan of extending the hat channel only, and not extend this surprise inner section. Since I'll be adding new full-height ribs in what used to be the middle of most of the windows, I think it should be fine.
Old 04-16-2015, 09:24 AM   #75
Ribs on a Blue Bird Bus are 12 ga, not 14.
Old 04-16-2015, 09:33 AM   #76
I don't have a blue bird, but will build them out of whatever is on my bus. 10, 12, 14... whatever it is.
Old 04-16-2015, 09:51 AM   #77
Chassis: Blue Bird
Engine: ISC 8.3
Per the chart at Engineering Toolbox the thickness of 12 ga galvanized is 0.108 inch. With my calipers I didn't find any point so thick as that (thin edges standing up around punches and cuts excepted). IIRC mine measured from 0.074 to 0.085. It's just the average $10 digital caliper, but drills and such whose shank size is known are measured accurately enough with it, so I figured this range of measurements pointed toward 14 ga for mine. Certainly won't hurt anything to go thicker where there's space for that, of course. It wouldn't surprise me to find that the design changed over the years.
Old 04-16-2015, 10:14 AM   #78
I figured 14ga from more than a decade of cutting the stuff in a steel shop. I just felt it with my fingers. I'll cut a section out, take it to the shop and buy the steel accordingly.
Old 04-16-2015, 12:42 PM   #79
Good point it may change over the years, and per manufacture.
Also our Canadian buses may be built thicker to give longer life before rust out?
Old 04-16-2015, 08:37 PM   #80
Chassis: Blue Bird
Engine: ISC 8.3
Trying to figure out how to break the sealant/adhesive that is between this fiberglass rear cap and the sheet metal -- with minimal damage to the fiberglass so it can be re-used.
A friend suggested... oh, what did he call it... a "buzzy cutter," I think. Also known as "oscillating multi-tool." Maybe that vibrating blade could slide between the metal and fiberglass..? Surely it would shave some fiberglass off the back side, but maybe not too much... Any thoughts about this or another approach?
Covered Wagon travelinwithus Everything Else | General Skoolie Discussions 9 08-06-2013 07:53 PM
Covered Wagon Roof oilitright Skoolie Conversion Projects 17 12-31-2011 03:39 PM
the Waste-Not Wagon - an intro. waste-not wagon Skoolie Conversion Projects 2 07-29-2009 09:01 AM
Whoa Cheese Wagon!!! (BRAKES) JesuitLarson Conversion General Discussions 6 01-18-2009 10:54 AM
Hawg wagon project. timbuk Skoolie Conversion Projects 16 11-29-2008 09:46 PM
