Old 02-25-2011, 06:48 AM   #1
browncrown's Avatar
Rated Cap: 79 at Birth
Re: The Field Mouse
Nice work, looks very good and great progress. Welcome
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 02-25-2011, 08:16 AM   #2
Diesel Dan's Avatar
Engine: DT466/AT545
Re: The Field Mouse
Yes, welcome! I love the rustic look of the paneling. Are you going to stain it? I've seen some other buses on this forum with stained paneling like yours and it looks georgeous. If you do stain, just remember to use pre-conditioner since the soft pine will not take stain evenly otherwise.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 02-25-2011, 10:19 AM   #3
Year: 90
Coachwork: Volunteer
Engine: 366
Re: The Field Mouse
thats a very nice conversion you got going on. im lerking around getting ideas for my conversion. Great job!!!!!!!!
Six Four is offline   Reply With Quote
Old 02-25-2011, 10:50 AM   #4
Diesel Dan's Avatar
Engine: DT466/AT545
Re: The Field Mouse
Originally Posted by Leonidas
... great job tracing those edges with the wood planks. That job is what is holding up my conversion right now, I cannot figure out for the life of me how to cut osb and paneling to cover my walls and match the curve of the bus Any advice there?
I didn't do a perfect job on mine, but you basically have to make a template first and then trace that onto the tops of subsequent panels. Here is a tutorial that is relevant:
http://www.familyhandyman.com/DIY-Proje ... erfect-fit
Try typing "how to scribe wood" into google and see what else you find.
Gallery:
Conversion Thread:
Old 02-26-2011, 06:12 PM   #5
Diesel Dan's Avatar
Engine: DT466/AT545
Re: The Field Mouse
Originally Posted by Beardy
Do you think I still need the conditioner with oil? I don't do much wood finishing...
Sorry, I've never used oil - but you know the internet has the answer to most questions! I would certainly do a sample piece of scrap wood first with whatever method you plan to use so you can see how it will turn out before starting on the bus.
Gallery:
Conversion Thread:
Old 02-26-2011, 08:56 PM   #6
lornaschinske's Avatar
Rated Cap: 89
Re: The Field Mouse
You do not need wood conditioner with boiled linseed oil. You will need to re apply the oil periodically (like every 6 months if in a lot of sun or dry air). Do not confuse with Tung Oil (sticky stuff).
Fulltime since 2006
Old 03-03-2011, 05:31 PM   #7
browncrown's Avatar
Re: The Field Mouse
Super work...and looking really good on the wood.
BC
Old 04-06-2011, 10:18 PM   #8
pipopak's Avatar
Contour gauge
Easiest way to copy a shape is to use a contour gauge. I got mine from Home Dep and is basically a plastic ruler with a bunch of sliding transverse pieces. Found it at the tile section and is about 1' long. They have another one at the tool section but is way too short. If I remember will put a pic tomorrow, right now I am barefoot all the way up to my ears!.
pipopak is offline   Reply With Quote
Old 04-20-2011, 11:44 PM   #9
pipopak's Avatar
Re: The Field Mouse
Here is the picture for the template gauge:
[img]
Template gauge by pipopak, on Flickr[/img]
Old 04-21-2011, 07:08 AM   #10
RevBill's Avatar
Coachwork: - Still Shopping -
Chassis: - Going Medium/Large -
Engine: - DT466 Desired -
Re: The Field Mouse
.. awesome flashlight too .. I have one that is probably 20 years old that works as well as the day I bought it .. still water-tight and bright ..
Chance favors the prepared mind. - L Pasteur
Luck is the residue of good planning. - B. Rickey
Travel is fatal to prejudice, bigotry, and narrow-mindedness ... - M. Twain
RevBill is offline   Reply With Quote
Old 05-26-2011, 08:20 PM   #11
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Re: The Field Mouse
Looks great inside. I bet you don't drive around much though. All your stuff would end up on the floor!
Old 05-27-2011, 01:37 PM   #12
browncrown's Avatar
Re: The Field Mouse
Realy nice inside...looks nice and comfortable and like a home!
BC
Wanted Field Trip bus dlor1 Classifieds | Buy, Sell, Swap 1 10-23-2007 09:50 AM
