Old 07-18-2016, 08:17 PM   #241
Coachwork: Corbeil
Engine: International DT466
Rated Cap: 24 Passenger
Any more takers?
So Karina...you just bought a bus...why and what are your plans?
Blinkinlights is offline   Reply With Quote
Old 07-18-2016, 08:29 PM   #242
We bought the bus so we could take it camping and to work out of town (we're apprentice boilermakers). I'd like to transition eventually to living in it full time but I think my boyfriend will need some convincing
Karina is offline   Reply With Quote
Old 07-18-2016, 08:59 PM   #243
Coachwork: Corbeil
So what have you done to it so far?
Old 07-19-2016, 06:16 AM   #244
Yall should start a thread.
Old 07-19-2016, 09:13 AM   #245
Coachwork: Corbeil
You're right.
Old 07-19-2016, 08:26 PM   #246
cheryl_ann44's Avatar
Chassis: International 3800 chassis
Engine: T444e
Ok I need to know where you got those trailer jacks I've been searching for just that size and type
Cheryl Ann
Blessed to be Alive!
cheryl_ann44 is offline   Reply With Quote
Old 07-19-2016, 08:26 PM   #247
Chassis: international
Rated Cap: 71
Originally Posted by Hank's P-O-S View Post
His account doesn't say he is traveling anymore.... It's up to him now.
From reading his thread before what ever happend happened he was enjoying the new addition.
My guess is he's spending the time with the family and building the bus and memories.... That my friends is living the life (family)
livinthelife is offline   Reply With Quote
Old 08-05-2016, 05:48 PM   #248
I was enjoying the build. Too bad but hopefully he is enjoying family time!
superduty_59 is offline   Reply With Quote
Old 05-16-2017, 09:23 AM   #249
Brewerbob's Avatar
Originally Posted by nat_ster View Post
I had a metal shop make these out of 12 ga. Sheared, and bent to perfection on their massive bending brake. These pieces are my rib extensions to fill the 23 inch gap in the support ribs.
Showing how well they will fit.
Nat,
Found your build while searching for info on rivets, rivet guns, etc. I'm going to do a raise as well. My bus is a '99. Are your OEM hats 12 gauge? Haven't gotten the skins off mine but was told it was 14 gauge.
Old 05-16-2017, 10:14 AM   #250
Brewerbob's Avatar
Good question, I'm glad you asked.
Being this work was done months ago, I sometimes forget the little details and experiences.
Being late in the fall, I chose the hottest day I could. I hung the panels at the top from two points, and allowed the sun to heat them to the point of hot to the touch. Then bolted them on.
A week later I painted on black primer. The sun came out and heated the now black panels. To my surprise, my panels were not as tight as I thought they were. Being 14 ga, the wrinkles were minimal, but they were there. Even my residential door started to drag a bit from the expanded metal.
Now, based on this experience, I would prime the panels black before bolting or riveting them on. This would have caused the sun the expand them to the maximum, before securing them to the ribs.
This would be highly effective in hotter climates, and if painting your bus a lighter color, the black will expand the steel more than the lighter, final color will.
Steel cools to fast for any artificial heating to be effective. Riveting and bolting is no fast process. Therefore I believe that using a black primer, and the heat of the sun to be the most effective method for the fellow skoolie owner.
Hope this helps others avoid wrinkles.
And what happens when it's Feb 17th in Alberta and the high temp for the day is -24°F?
Old 05-16-2017, 10:36 AM   #251
Robin97396's Avatar
Bob, the Nat_ster quit this forum over a year ago. I understand he had some interesting methods for builds. There are occasional videos.
Robin
Nobody's Business
Old 05-16-2017, 10:55 AM   #252
Brewerbob's Avatar
A side pic showing the pile of dirt still on top of the tank.
Was your bus drug thru a field and used as a plow? Holy hell!!!!
Old 05-16-2017, 11:40 AM   #253
Brewerbob's Avatar
Well that blows cheese. I didn't see any thing here worth banning but I do know how the forum business goes. Was on an RX-7 that got bought out. The new owners were such douche-noodles that our entire group left.
Old 05-16-2017, 12:40 PM   #254
Robin97396's Avatar
Nat was a bit of a Maverick from what I understand. Interesting to say the least.
Robin
Nobody's Business
Old 05-16-2017, 12:47 PM   #255
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
douche noodles away............
Old 05-16-2017, 12:49 PM   #256
Brewerbob's Avatar
Too much time in isolation. I was in a single wide mobile home without water or electric for about a week before I got everything hooked up. But that wasn't thru winter and it was in FL not Canada.
Old 05-16-2017, 12:52 PM   #257
Old 05-08-2022, 01:24 AM   #258
So why use 1/4 rivets when 1/4 bolts are cheaper, more available, and I don't need anything special to install them.
I have 14ga 1.25" sq tube that I was going to use to span a 19" raise with 10" of overlap in both the top and bottom channels. I'm considering using 1/4 bolts or rivets to join the tube with the channels... I also have some 12ga 1.25" angle iron that I was going to maybe weld or attach to the sq tube for my rivets and skin..
DiddBiddy is offline   Reply With Quote
Old 05-08-2022, 06:09 PM   #259
THANK YOU THANK YOU THANK YOU for reviving this thread! It looked interesting so I went to page 1 to start reading, and found a bunch of links including one for Nat_ster's Haul All. It's almost like a step-by-step on how I can build what I want to build from a bus when the time comes. I might even be able to add a few extra feet to a 40ft bus based on what I see here.
Veloc is offline   Reply With Quote
Old 05-09-2022, 02:24 PM   #260
you're certainly welcome... great information here eh!
