Old 12-15-2015, 06:08 AM   #221
Sorry folks, Nat has been on time out and asked me to post this to answer the questions being asked here.
Ownins Corning rigid Styrofoam C-300 is what I will be using. It will not compress under the 14 gauge steel, or a 3\4 plywood subfloor under foot traffic. It is made to hold the pressures of cement being poured right over it. In shop application's with 6 inches of rebar reinforced cement, this gives over 3000 PSI of strength without deflection.
Sorry for the misunderstanding about the specs of the Rigid Styrofoam.
Old 12-15-2015, 12:50 PM   #222
Chassis: B3800 Short bus
Originally Posted by family wagon View Post
I think I can explain it. "Pounds per square inch ... per square foot" doesn't exactly make sense, but I note that if one takes the 2000 and 3000 as pounds-per-square-foot figures, and divides by 144 to convert square feet to square inches, then one has 13.9 and 20.8 pounds per square inch, or PSI. Viewed this way, nat_ster's numbers are roughly consistent with those cited by jazty (ie they're in the same order of magnitude). I'll guess it was a case of typing too fast and writing "PSI" where "pounds" was meant.
Yeh, there's a dozen ways to write it: PSI, KPa, lbs per square foot, aardvarks per hectare, etc.. I just grabbed the weight rating (in PSI) from the technical documentation of the product.
http://www.foamular.com/assets/0/144...778c340101.pdf
^ That one is omitting c-200 and c-300 for some reason.. Maybe they are products only available in Canada.
Old 12-18-2015, 10:14 PM   #223
Originally Posted by jazty View Post
Yeh, there's a dozen ways to write it: ..., aardvarks per hectare ..
1 psi is 106,897 Standard aardvarks per hectare. Just FYI.
floatingLomas is offline   Reply With Quote
Old 12-20-2015, 07:53 AM   #224
Coachwork: ward
Chassis: international
Engine: dt360a
106,896.75 for three legged aardvarks.
Old 12-20-2015, 09:54 AM   #225
Oops. I made a math error. It's actually 134,199 Standard aardvarks per hectare.
Old 12-20-2015, 02:10 PM   #226
Chassis: MVP
Engine: CAT 3116
Make sure you are calculating for Standard Aardvarks and not the lighter European Aardvark...
Piersg is offline   Reply With Quote
Old 12-20-2015, 03:58 PM   #227
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
What does that translate into Hedgehogs per square cubits?
Old 12-20-2015, 07:13 PM   #228
Chassis: MVP
Engine: CAT 3116
Not sure, that's kind of a prickly subject around here.
Old 12-20-2015, 07:58 PM   #229
Chassis: Genesis
Guys, lets stop polluting Nat's bus thread. :/
Timelord is offline   Reply With Quote
Old 01-20-2016, 03:16 PM   #230
Originally Posted by nat_ster View Post
These pics are from the fall of 2013.
I started planning the 23 inch roof raise.
I cut a four inch piece out of one of the ribs to take to the metal shop as a template. This insured that the new rib extensions will fit properly.
I had a metal shop make these out of 12 ga. Sheared, and bent to perfection on their massive bending brake. These pieces are my rib extensions to fill the 23 inch gap in the support ribs.
Showing how well they will fit.
Hi there.
First and foremost, CONGRATS on your baby !!! Mi youngest was born in December.
Secondly, AWESOME CONVERSION PROCESS !!! You are intimidating me !!
Third, my question ... because we are a family of 6, our bus is only 26 feet long from behing the drovers seat to the very back so, we obviously need to raise the roof in order to be able to add a loft for sleeping. I saw hiw you did yours and although it looks awefully intimidating, I think our newbie butt may be able to do it. However, we want to keep the bus windos so, do you think we could make the cut and the extention from under the windows as opposed to qhere the windows would go ?? I hope this is making sense ... or should we just not mess with cutting and raising and just add to the roof ?? We are soooo not skilful or knowlegable at all.
Thanks in advance for any advice you could.give us !!
Mash is offline   Reply With Quote
Old 01-21-2016, 03:41 AM   #231
This thread was motivation what happened to it!
mpyourhomie is offline   Reply With Quote
Old 01-21-2016, 07:32 AM   #232
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
The OP got banned or maybe it was a time out. Not exactly sure what happened to natster.
Old 01-25-2016, 02:33 PM   #233
Hopewully he will be back. I had so many questions.
and can't wait to see if the bus ever got stretched 8 feet and became rear engine.
1967 M109 Deuce and a Half
platetees.com
onemanarmy is offline   Reply With Quote
Old 01-26-2016, 08:37 AM   #234
Coachwork: -
Chassis: -
Engine: -
Okay - how long does a "time out" normally last??
What thread was it, where they got kickin' ??
Yes Nat_ster can get "intense", however I never saw anything nasty form him, either things got way softy here or what happened??
Cheers,
thjakits
thjakits is offline   Reply With Quote
Old 02-03-2016, 02:42 PM   #235
Thanks for the kind words. I would love to have help, and I would love to help others build their own. However, no one local shares the same interest.
Totally local over here and blown away by this project, going through it page by page now.
I also run a tiny house/alternative living group and I got to say there are quite a few local people who I think would be very interested in this.
ullyeus is offline   Reply With Quote
Old 02-03-2016, 07:49 PM   #236
I really hope he's allowed back on soon. This thread was amazing and so well documented.
Chris C is offline   Reply With Quote
Old 02-03-2016, 08:41 PM   #237
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
His account doesn't say he is traveling anymore.... It's up to him now.
I do hope he continues posting, he is a great source of information for us all.
"...Baler twine tie downs goin' down the road
On two bald tires and an oversize load..."
Hank's P-O-S is offline   Reply With Quote
Old 07-18-2016, 05:18 AM   #238
I'm from Edmonton, I bought a 1998 8 window international last week. Was planning on going right into the interior work but seeing what you've done I'm thinking I probably have a lot more work ahead of me than I planned! I would love any help/insights, maybe I could get you to come and do an initial assessment of what needs to be done sometime?
Karina is offline   Reply With Quote
Old 07-18-2016, 09:04 AM   #239
Coachwork: Corbeil
Engine: International DT466
Rated Cap: 24 Passenger
It's good to see the interest in Skoolies in Edmonton. Maybe some of us need to set up a new thread just for the Edmonton Area to share ideas and parts sourcing etc. Maybe a coffee meeting is in order.
Blinkinlights is offline   Reply With Quote
Old 07-18-2016, 05:20 PM   #240
I think a coffee meetup is a good idea
