Old 10-20-2011, 09:38 AM   #1
Re: The Fun Side
Hey Custer --- Welcome to the madhouse! Your Bird looks like a newer version of one I raised the roof on about 15 years ago. Love them Birds, built like a tank and you'll find lots of help & encouragement here. What's the engine/tranny combo on that darlin'?
Old 10-20-2011, 11:52 AM   #2
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
Re: The Fun Side
You could try using the key on this site http://www.angelfire.com/ca/TORONTO/VIN/bluebird.html
I've used it to look at the makeup of a couple birds I was interested in.
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 10-20-2011, 01:56 PM   #3
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: The Fun Side
TA is, I believe, for turbocharged, aftercooled. It's a good thing to have.
Old 10-20-2011, 05:26 PM   #4
Re: The Fun Side
welcome , this is the place to be ,for a world of info, jokes, and just plain crazy stuff
dont be a scared to ask anything about a bus,or anything else for that matter.
Old 10-20-2011, 08:52 PM   #5
Re: The Fun Side
5.9 Cummins would be correct for that type of bus (TC/2000 FE). As for transmission it most likely has the AT545 Allison automatic. Great looking bus, can't wait to see what you do with it.
kshamrock12 is offline   Reply With Quote
Old 10-20-2011, 10:19 PM   #6
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
Re: The Fun Side
Hi Custer. If you spend enough hours reading the posts on this site, you will learn everything you need to know about your bus and how to convert it. I have a 1973 Blue Bird. I like it a lot. Please breathe a new life into your machine, and post a lot of pictures.
Old 10-20-2011, 11:35 PM   #7
lornaschinske's Avatar
Rated Cap: 89
Re: The Fun Side
You should have metal plates on the front of the bus (interior) over the windshield and over the drivers side window with lots of info stamped into it.
Fulltime since 2006
Old 10-21-2011, 09:19 AM   #8
Re: The Fun Side
Hi Guys --- I raised the roof on my old Bird 19". Had massive storage inside but still well under 13 feet for over the road clearance. Used a combination of Blue Bird OEM roof ribs cut into 19" segments and 1-1/4" square tube. (NOTE: Blue Bird does not sell "repair" sections for their roof ribs, you have to make your own. They are adamant that any damaged ribs only be replaced, not patched.) The square tube fit inside the remaining rib and the cut sections fitted over that. I had consulted with a factory (Bird) engineer on the raise plan and he strongly recommended cutting every other rib at a different height to avoid creating a "weak line" along the length of the bus. Seemed to make sense, so I cut one rib at the bottom of the window and the next at the top. Worked out great.
Just maybe the most important thing I learned from him was to make sure and cross brace both the upper and lower body sections before cutting anything. Otherwise it will twist out of shape when cut free and be a nightmare to try and get back into proper alignment when welding the two back together.
Another issue he addressed was regarding the front & rear caps. Some folks like to cut them free and just raise them along with the rest of the roof, but he said nix on that. According to him, the way the Bird body is configured, it gets most of it's integrity from the way they are designed and tied to the lower body and should be left in place. We cut our roof at the third rib from the front and rear and raised only the remaining roof. Worked out well and provided yet more storage in the space that was created between the old "inner" roof and the new outer shell. Great place for the A/C and other things BTW.
Hope this helps and happy to share the experience.
Old 10-21-2011, 08:44 PM   #9
pipopak's Avatar
Re: The Fun Side
I would add that parking the bus on a FLAT and LEVEL surface would be a great help. That is the way the body is built and will avoid putting stresses on it.
Also, about the rear cap, I would leave it alone, then after raising the roof get a second scrap one, cut the part needed to fill between the original cap top and new roof line and use the open space left as storage.
pipopak is offline   Reply With Quote
Old 10-21-2011, 09:04 PM   #10
pipopak's Avatar
Re: The Fun Side
OK, now I'm hallucinating big time. What if, when starting to cut the ribs, follow this sequence (after doing all the bracing):
1) cut roof sheathing at front and rear.
2) cut one rib at the bottom of the window line.
3) weld one square tube to the bottom of the rib leaving it alone on the top, able to slide.
4) cut next rib at top of window line.
5) weld square tube to the top of the rib, leave alone at the bottom.
6) go all around until all are done.
Now when raising the roof SHOULD be like extending telescoping sections. Does it make sense?.
Old 10-22-2011, 11:11 PM   #11
Re: The Fun Side
I cut and raised mine first so that I could insert the square tube all the way from the floor up to the curve in the roof for maximum overlap. A couple of heavy duty farm jacks are more than adequate for lifting but I welded much larger base supports in place for stability.
Old 11-12-2011, 12:24 PM   #12
pipopak's Avatar
Re: The Fun Side
You have a beautiful long hair that will not last long if caught in any kind of powered rotary tool. Do yourself a favor and wear a net while working!.
Old 11-12-2011, 06:11 PM   #13
Rated Cap: 89
Re: The Fun Side
Ditto for the long dress. Loose clothing can easily get caught in power tools. I found out the hard way and I didn't think my shirt was all that loose. Ended up with a belt sander (80 grit belt) eating my shirt and the skin on my stomach. Took about two seconds for it to happen.
Fulltime since 2006
Old 11-13-2011, 06:28 AM   #14
TygerCub's Avatar
Engine: Detroit
Re: The Fun Side
Oh, yes, please do braid & secure your hair close to your head .
It's gross, but I've seen a photo of a fellow who was scalped after his hair was caught in a drill press at work!
Old 11-13-2011, 08:00 AM   #15
Send a message via ICQ to mightybus
Re: The Fun Side
Ditto the braids/hair net. Shawn Phillips, the famous singer, caught his hair in an outboard motor prop and it almost killed him. It messed him up bad.
mightybus is offline   Reply With Quote
Old 11-13-2011, 10:13 AM   #16
Rated Cap: 47
Re: The Fun Side
That little 4 inch grinder isn't going to hurt anybody beyond cuts. She lives with that hair in those clothes, I'm sure she is aware of them. Just be carefull.
I hope your husband appreciates your interest and help. My wife makes fun of me.
Motobus is offline   Reply With Quote
Old 11-13-2011, 10:47 AM   #17
pipopak's Avatar
Re: The Fun Side
That "little 4 inch grinder" turns at 11000 rpm. IT WILL CATCH HAIR!!!. And after catching the hair WILL SMACK YOU IN THE Face or head!!. And if you are lucky you will still have a piece of skin attached to your banged skull to regrow hair.
Old 11-13-2011, 11:00 AM   #18
Accordion's Avatar
Year: 1973
Re: The Fun Side
Please put your hair in a hat. Please wear pants. What everyone has been saying is true. It takes only a fraction of a second for power tools to hurt you. I know.
Old 11-13-2011, 11:55 PM   #19
Rated Cap: 47
Re: The Fun Side
You better get a hard hat to wear while working on the bus. I wouldn't step within 50 ft of that bus with a 4" angle grinder without safety glasses, a face shield, ear protection, welding gloves, coveralls, and better shave your head. You better wear a respirator too.
Just be carefull that grinding wheel will cut skin like butter.
Old 11-16-2011, 12:47 PM   #20
pipopak's Avatar
Re: The Fun Side
Originally Posted by custer
*IF* I ever have to use the grinder-thingie again, I will probably braid. (Won't be wearing any britches, though! ):
Not just the grinder, ANY power tool.
side windows keith Classifieds | Buy, Sell, Swap 0 06-13-2013 03:44 PM
Side rub rails - why keep them? dgorila1 Conversion General Discussions 2 09-11-2011 03:26 PM
Side Windows Travis Lovvorn Classifieds | Buy, Sell, Swap 1 09-02-2011 08:10 AM
A little side project . . . vonslatt Everything Else | General Skoolie Discussions 5 07-18-2005 07:51 PM
School bus side car? Steve Everything Else | General Skoolie Discussions 0 03-25-2004 07:35 PM
