Old 11-06-2013, 12:25 PM   #91
Re: The Good Ship Anne Marie
Looks amazing great job!!!
Project Niles Skoolie
http://www.skoolie.net/forum/viewtopic.php?f=9&t=55161
FOLLOW US ON FACEBOOK TOO!!!
https://www.facebook.com/NilesSkoolie
NilesSkoolie is offline   Reply With Quote
Old 11-06-2013, 04:07 PM   #92
somjuan's Avatar
Rated Cap: 71
Thanks, all.
Originally Posted by ferroequinologist
Did you just use self tapping screws?
Normal #8 1.5" sheet metal screws, not self tappers. We pre-drilled our holes through both the wood and metal with a 1/8" cobalt bit, and used a #8 countersink bit to get the heads nice and flush.
I don't know whether this will be a problem for you or not, but very very occasionally, we'd drill through the wood right into a hole in the rib where a rivet had been. Sometimes, the screw we put in wouldn't hold at all, other times it would. Either way, at this point you're faced with either leaving the screw in and doing the next rib down the line to be sure it stays in place, or putting the whole board into the scrap pile for when a shorter piece is called for.
7.3L Bluebird Conventional My build thread flickr bus.life
somjuan is offline   Reply With Quote
Old 11-14-2013, 10:10 AM   #93
ferroequinologist's Avatar
Year: 1973
Chassis: Chevy C60
Engine: Chevy 350, custom rebuild
Yes, that has happened to me when I put up 1x2's just to temporally put up some insulation (it's been cold here! we had snow for only like the 3rd time in 125 years here in early Nov!)
I'm curious to see if it will warp any in your instillation. I have a section in the back where the roof slopes down to meet the back, and I am trying to figure out how I'm going to do that part. I've even thought about steaming the wood first so it is a little flexiable.
I need to do something though, as the insulation I have up now is just covered over with heavy plastic and staple gunned up to the 1x2 stringers.
ferroequinologist is offline   Reply With Quote
Old 11-14-2013, 10:29 AM   #94
ferroequinologist (good one )
I was expecting some exotic other world scientist or doctor
sorry for hijack
Old 11-14-2013, 12:50 PM   #95
somjuan's Avatar
Rated Cap: 71
Even that is probably unnecessary, since they're so thin, they're really quite flexible. It would need to be a pretty sharp dip to require steaming.
As far as warping, I expect a little, but I doubt it'll be too bad. The screws will keep them from doing anything too dramatic. I just expect the usual expansion/contraction. Though the air was pretty dry when we put them up, many of them were warped enough that they aren't crazy tight, and I don't expect any buckling or the like when it gets humid out. But I guess that remains to be seen.
Old 11-14-2013, 12:51 PM   #96
profbrady's Avatar
Coachwork: Amtran FE
Engine: DT466 / AT545
Whoah that ceiling looks amazing. Nice one!!
profbrady is offline   Reply With Quote
Old 11-18-2013, 07:07 AM   #97
Year: 1973
Chassis: Chevy C60
Ok Thanks. I took the wife to Lowe's and showed her the boards. And I showed her the pictures of yours. She likes the idea but we are low on funds so getting the insulation up and covered with plastic is taking priority. I will probably start on the ceiling after Thanksgiving.
Thanks for answering my questions! It is always easier to dive into something when someone else has already figured out the depth and that there isn't any rocks or washing machines in the way!
Old 11-18-2013, 08:02 AM   #98
somjuan's Avatar
Rated Cap: 71
Happy to help. I was pretty surprised by the lack of documentation both here and elsewhere on wooden ceilings. I've seen a fair number of conversions with them, but can only remember seeing one or two topics here that touched on them. And of course when I went back to find them, I could not.
Old 11-18-2013, 03:03 PM   #99
Year: 1973
Chassis: Chevy C60
I was looking at the packs again and have been trying to get a good idea of how many I need. My bus is probably the same size as yours or close. It looks like a pack will do a 2ft wide section 8ft long. Is that about right?
Old 11-18-2013, 03:20 PM   #100
somjuan's Avatar
Rated Cap: 71
That does sound about right. I believe we went through a little over 30 of those packs.
Not so good at Good Sam Insurance bapos Titles, Insurance, Registration and Money Matters 60 06-16-2015 10:23 AM
Good Sam gbstewart Conversion General Discussions 13 08-17-2010 10:55 AM
good day. Abbott Everything Else | General Skoolie Discussions 2 06-03-2010 04:14 AM
Is this bus a good bet? zamfir Short-Bus Conversion Projects 9 07-18-2009 11:37 AM
the Anne Marie somjuan Skoolie Conversion Projects 8 04-07-2009 09:00 AM
