Old 07-04-2013, 05:20 PM   #31
somjuan's Avatar
Rated Cap: 71
Re: The Good Ship Anne Marie
Originally Posted by Redbear
I can't think of who did it, but in some of the projects here I have seen beams (2x6s?) cut to the curve of the roof as the support for a deck . . . .
TygerCub's deck is a little like that. We had considered doing something more along the lines of cut 2x6s or 2x8s bolted to the ribs, but I think there will be more disadvantages to a design like than than there would be advantages. I think so much material so close to the deck will collect wet dirt, leaves and grime. I also worry that bolting into the side of a 2x6 will weaken it substantially. I don't claim to know anything about this, but those are concerns I have.
p.s. Someone here who uses their bus for a race viewing platform noted that uninvited intoxicated "guests" would appear on the platform when there is an outside ladder. Due to the nuisance and liability they recommended having interior access through a roof hatch instead. Just sayin' . . . .
I understand this concern, but that won't be a route I'm going. I don't have any stock roof hatches, and I'm not brave enough to make my own. I've been thinking about making the exterior ladder fold up to at least make the deck not explicitly inviting when I don't want it to be.
7.3L Bluebird Conventional My build thread flickr bus.life
somjuan is offline   Reply With Quote
Old 07-04-2013, 07:39 PM   #32
Hell ya! A rope ladder so you can pull it up!! Like a tree fort or pirate ship..............sweet.......or a cargo net like navy and marines
Old 07-04-2013, 07:50 PM   #33
Hmm a rope ladder would limit the drunks abilities...and be a fun "dismount"
Malkieri is offline   Reply With Quote
Old 07-09-2013, 06:32 PM   #34
somjuan's Avatar
Rated Cap: 71
It looks now like we're going to go with a standard aluminum ladder, with a bike rack option. The bike rack, with either bikes or chairs locked to it, should easily deter anyone with a casual interest in the roof deck. More on the deck later - we've bought supplies, and are finalizing plans, but don't really have anything to share.
First off, check out this mouse damage:
It's only damage to the insulation, though they got in through a small rust hole a bit lower. That has since been treated and sealed.
I've been reading the forums here for nearly six years, and somehow never noted the struggle with chair rail removal. The wall between the chair rail and the windows came off very easily once we removed the rivets. This was not the case from the chair rail to the floor. I completely missed this thread, and somehow glossed over this detail in . Take note: the chair rail does not stop at the floor! It bends down under the ribs, and below the floor.
We learned this the hard way by brute forcing our way into it. We went ahead with an angle grinder and sawzall and cut out much of the chair rail. The three strips of metal still attached to the ribs in the photo below actually have small spot welds that I couldn't see before cutting.
Anyway, that's what we're working on at the moment. We're going to have a real clean slate to start building on when we're done here.
And a question for you folks - at the front of the bus in the first roof panel, there is a small vent whose purpose I don't really understand. There was only fiberglass insulation and the permeable screen-like sheet metal up there with it. It never leaked, and it doesn't look like any water or bugs got in, but there it is. Will I need to keep this vent open? What was its function?
Old 07-09-2013, 06:43 PM   #35
It is just a vent to let the bus breath,during long spells of sitting
I am sure there is something scientific about it tho'.....it needs to breath anyway it works out
Old 07-09-2013, 07:13 PM   #36
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
I have one of those little vents on my bus. I covered it up on the inside with my carpeted ceiling. I don't think that it has affected anything. I have been living in this bus for over five years.
In the summer, I use my window air conditioner. In the winter I leave two of the windows open a half inch because I use propane catalytic heaters.
There is always ventilation of some sort.
Old 08-16-2013, 11:09 AM   #37
somjuan's Avatar
Rated Cap: 71
Alright, after a bit of traveling and a little time to rest and enjoy the weather, it's time to get back to work.
We've got the roof painted with two coats of BusKote, and we should be applying a third shortly. Insulation is getting cut and fitted. I'll post some pictures shortly.
Old 08-17-2013, 05:21 PM   #38
somjuan's Avatar
Rated Cap: 71
Here we're putting the finishing touches around the bluebird - we're still planning on doing a third coat.
I cut the battery door off today, the hinges and latch had basically rusted shut. I'll be making a new door and attaching it soon.
Insulation cut and fitted. We'll be filling in the gaps with Great Stuff.
Old 08-21-2013, 10:09 PM   #39
somjuan's Avatar
Rated Cap: 71
Great Stuff is really fun. I've never had a chance to use it so extensively before - it works wonders. Our walls are very solid now. One note: the can warns you not to get it on your skin. Take heed! It is a massive pain to get it off of you, just don't get it on in the first place.
We trimmed the excess foam with a razor on a stick. I'm not really sure what the tool is called, I think it's used for drywall. It worked very well. Touched up the primer coat on the floor, and started laying down insulation.
We laid down Red Rosin Paper, and are trimming our floor insulation to fit.
We'll have R12 in the walls, 6 on the floor, and somewhere in between in the ceiling. We should have the plywood subfloor in tomorrow.
Old 08-21-2013, 10:56 PM   #40
PDBreske's Avatar
Rated Cap: 1
Out of curiosity, how many cans of Great Stuff did you use?
Read about the "Camel" RV Conversion project!
My first passion is photography. Visit my website to see some of my work.
Not so good at Good Sam Insurance bapos Titles, Insurance, Registration and Money Matters 60 06-16-2015 10:23 AM
Good Sam gbstewart Conversion General Discussions 13 08-17-2010 10:55 AM
good day. Abbott Everything Else | General Skoolie Discussions 2 06-03-2010 04:14 AM
Is this bus a good bet? zamfir Short-Bus Conversion Projects 9 07-18-2009 11:37 AM
the Anne Marie somjuan Skoolie Conversion Projects 8 04-07-2009 09:00 AM
