Old 10-31-2013, 01:33 PM   #81
eyedeal.ink's Avatar
Re: The Good Ship Anne Marie
looking great, I really like the new running lights. That little space saving woodstove is cool, looking forward to hearing how it works out for you.
"That's,. like,.. your opinion, man...." - the Dude.
eyedeal.ink is offline   Reply With Quote
Old 11-05-2013, 04:44 PM   #82
somjuan's Avatar
Rated Cap: 71
Thanks for the photo kudos - I bought my first camera around the time this project started, and I've been learning along the way. Also, you have no idea how excited I am to run that woodstove - we're only about two weeks away.
Passive solar update: yesterday saw a high of 45 F outside, and we hit a little above 80 F in the bus by early afternoon. If I was in an area with a clear Eastern exposure, I imagine it would peak even sooner.
We started attaching our ceiling to the bus ribs. It overhangs a little, and we're going to trim it to fit just right, but that's down the road a ways. We worked our way up one row at a time, using screws to secure the boards where they needed it. The boards, 5/16th" T&G wainscoting from Lowe's, didn't need quite as many screws as we originally expected. Many boards only have one or two screws keeping them in place. Because of this, we actually had no trouble covering up the LedgerLoks or the carriage bolts we used to secure the roof deck in place.
Our method was to fit a board where it was going to go, pre-drill through both the wood and the metal, then countersink the hole, then secure the board with a screw (1.5" #. It worked very well, and they're not very visible unless you're looking for them.
We added the insulation as we went. Most of what we used was the stock insulation we had kept from when we took the sheet metal ceiling down. The stock insulation originally spanned the ceiling in three parts - one long part covering 80% of the span, and two shorter lengths to either side. We broke this up into five or so segments, and added the insulation above us as the boards progressed.
This wasn't a particular difficult part of the conversion, but it took some serious time. The ceiling took the better part of a week (with lots of trial and error, of course, along the way).
The wiring that runs the length of the port side of the bus will be hidden away in a little channel we build, so the only wires that remained above the ceiling were for clearance lights and turn signals.
The finished (or very nearly) product. Like I mentioned above, we still have to trim the boards to fit the windows just right, but the vast majority of the work is behind us. I'm very pleased with how it came out, and even more pleased to be done with the insulation. At some point in the future, we'll seal it with a flat or satin poly finish, leaving the natural color.
Next up, cutting a hole in that perfect ceiling for a chimney!
7.3L Bluebird Conventional · My build thread · flickr · bus.life
somjuan is offline   Reply With Quote
Old 11-05-2013, 04:50 PM   #83
sweet, great job
Old 11-05-2013, 05:16 PM   #84
Rated Cap: 48
Great work! I am hoping to do something very similar for the roof and its great to see it turn out so well for you guys before i dive into it
lestock-kay is offline   Reply With Quote
Old 11-05-2013, 06:00 PM   #85
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
Awesome looking ceiling.
Old 11-05-2013, 08:43 PM   #86
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
That is gorgeous!
Old 11-06-2013, 10:39 AM   #87
love the ceiling, should hold more heat for sure.
Old 11-06-2013, 12:52 PM   #88
ferroequinologist's Avatar
Year: 1973
Chassis: Chevy C60
Engine: Chevy 350, custom rebuild
I looked at that exact same product yesterday and thought, "that would make an awesome ceiling"
And now I know it will! Great job! really coming together now!
ferroequinologist is offline   Reply With Quote
Old 11-06-2013, 01:16 PM   #89
somjuan's Avatar
Rated Cap: 71
I highly recommend it. But be forewarned - these come prepackaged in sets of 6, and many of the pieces in our packages were damaged, split, warped, or otherwise too ugly to use. We had no trouble cutting around some boards with only minor imperfections, and Lowe's was totally cool about taking the rest back (in sets of 6, of course). They look great, and fit together well, but you're not able to pick the good boards like you are with other lumber.
Old 11-06-2013, 01:24 PM   #90
Year: 1973
Chassis: Chevy C60
Yes thanks for the heads up, I did notice that the first two 'packs' I picked up had some damage. I might have to pick through the stock at the Lowe's near the house and go by the one near my work to get enough good material.
Did you just use self tapping screws?
Not so good at Good Sam Insurance bapos Titles, Insurance, Registration and Money Matters 60 06-16-2015 11:23 AM
Good Sam gbstewart Conversion General Discussions 13 08-17-2010 11:55 AM
good day. Abbott Everything Else | General Skoolie Discussions 2 06-03-2010 05:14 AM
Is this bus a good bet? zamfir Short-Bus Conversion Projects 9 07-18-2009 12:37 PM
the Anne Marie somjuan Skoolie Conversion Projects 8 04-07-2009 10:00 AM
