07-01-2017, 05:31 PM
The GypZ Jewel! Conversion on our FE 2000 AmTran International DT466E
07-01-2017, 05:32 PM
I have no idea why the pics aren't showing up.. Just a few..
Sent from my SM-N900T using Tapatalk
07-01-2017, 05:42 PM
Engine: DT466E Allison 3000
Rated Cap: 84 Kids/56 Adults
Nice to see another big Amtram. I've got a 84 pax 1999
Sent from my SM-G930V using Tapatalk
"Once you get it, you got it."
07-01-2017, 05:44 PM
I don't see too many of them.. I'm trying to find the manual for this beast.. It seems pretty hard...
07-01-2017, 05:45 PM
I have digital copies of the engine manual for the 466E. Good luck finding anything on the body, I've yet to find anything from anywhere.
07-01-2017, 05:52 PM
I would also test your coolant or replace it ASAP, mine had deteriorated and ate through my cylinder liner o-rings and now I'm in the middle of an inframe rebuild. The 466 is known for that if you don't keep up on cooling system maintenance
07-01-2017, 05:58 PM
The coolant looks bright green.. At least what I pulled from the rear heater. I plan on doing all fluid changes and filters once I get more into the build.. I also will need new tires.... Get everything done at once. Do you happen to have a link for a copy of the engine manual?
07-01-2017, 06:01 PM
It's on my Google drive, I need to figure out how to make a link to it for everyone
07-01-2017, 08:58 PM
Rated Cap: 37,400 lbs GVWR
Get yourself some HD coolant test strips - they test pH, strength and nitrites. That will tell you whether to change the coolant or not. Have you changed the coolant filter yet, or added more SCAs? It's not a guessing game! It's the same for engine oil and transmission fluid - a fluid analysis will tell you if you need to change them or not, plus a lot more besides.
07-01-2017, 09:00 PM
I'll get those and test it.. Thane so much!
07-01-2017, 10:46 PM
Chassis: Thomas
Engine: CAT 3126
Looks like you've gotten a lot done. How bad has the floor patching been?
Sent from my SM-N900P using Tapatalk
07-02-2017, 09:12 PM
Not bad. Just taking one area at a time... So I don't feel overwhelmed. I'm going to start on the other areas this week.. Once that's done.. We start to build it out..
07-05-2017, 11:39 AM
Chassis: Sold
Looks good. I have a 2000 RE Amtran, kids have the seats loose but my goal is to really start on it next year. My project list is already overflowing this year. Mean while, I'm just planning and stocking up supplies.
Sent from my Nexus 5X using Tapatalk
07-05-2017, 11:50 AM
07-05-2017, 11:52 AM
Nice. Our goal is to take our first trip in it in Dec.. Just about 100 miles away from where we are now.. Test her out a bit.
07-07-2017, 05:40 PM
