Old 07-25-2013, 11:06 AM   #111
wmkbailey's Avatar
Engine: 3126
Re: The Journey Visvi 1999 Thomas MVP ER
I could have taped them, but the steel was soft enough that the screw cut threads itself with the impact driver.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 07-25-2013, 11:13 AM   #112
JakeC's Avatar
I'm guessing Bansil is getting at the robustness of the screws, vs. 1/4-20 bolts.
Brutus
Old 07-25-2013, 12:12 PM   #113
wmkbailey's Avatar
Engine: 3126
If they want it that bad, they can just bust a window too. My front door is still wide open, only air holding it shut. This is just there to give someone second thoughts before they take everything.
I hope to have something more workable later. I may keep the back door, but will remove the side door.
William
Old 07-25-2013, 02:32 PM   #114
wmkbailey's Avatar
Engine: 3126
See somewhere came up with a good idea for the side door.
viewtopic.php?f=9&t=9827&start=30
I need to find something like this for the rear door.
William
Old 07-25-2013, 02:33 PM   #115
nope I was going to throw some 1/4-20 bolts with plastic knobs attached to them in the mail, have some extra pretty sure if they are long enuf
Old 07-25-2013, 08:30 PM   #116
wmkbailey's Avatar
Engine: 3126
I want to do something like what somewhereinusa did above so I can unlock from the outside too.
This is just temporary, but thanks.
William
Old 07-26-2013, 09:21 AM   #117
JakeC's Avatar
The heat coming down at all?
Brutus
Old 07-26-2013, 09:33 AM   #118
wmkbailey's Avatar
Engine: 3126
Nice pic. I took the motorcycle to work and had to find a jacket. It was down to 57 this morning. It will be a good weekend to get some work done on the bus. Next week we will be back up into the 90s.
William
Old 07-26-2013, 09:56 AM   #119
JakeC's Avatar
Nice!! I'm hoping the weather holds up this weekend to get mine primed. Supposed to be 70's and sunny, but I'm worried about wind.
Brutus
Old 07-28-2013, 01:35 PM   #120
wmkbailey's Avatar
Engine: 3126
*** Magic flat screw method ***
This worked nice.
Behold striped out corroded Philips head screw.
Magic flat screw grinding tool.
Behold Flat head screw
It comes right out.
Screw gone.
I had 50 screws that I could not break loose. Using this method I got all out but two. Those I just grinded the heads off.
William
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 11:55 AM
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 436 02-12-2017 09:38 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 11:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 11:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 07:49 PM
