Old 07-31-2013, 08:15 PM   #131
wmkbailey's Avatar
Engine: 3126
Re: The Journey Visvi 1999 Thomas MVP ER
Fingers crossed, I dropped the bus off to get inspected. I was told they are very busy and it may take a couple days. I hope it passes without any big hidden things showing up. I know the passenger side rear tires may need to be replaced.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 08-01-2013, 06:19 PM   #132
Chassis: Saf-t-liner
Engine: Cat 3126 - MD 3060
Yuck. Sorry you have to leave your bus somewhere for days, I hate that. Hope it passes.
ThePimentals is offline   Reply With Quote
Old 08-03-2013, 01:22 PM   #133
wmkbailey's Avatar
Engine: 3126
I got an update on the inspection. He does not work weekends, so it will get done on Monday. I miss my bus.
Education on steel. The labels may be wrong.
Across the street from me is a welding and fabrication shop. They sell steel for a good price, the lowest in the area. On shelves in the shop they have examples of what you can get. I was looking for Rectangle tubing that 1 1/4" square tubing would fit in. I found a piece that worked good with a little wiggle room to work with. 2" x 1 1/2" x 1/8" or 11 ga. I should have done the math because when you take in account the 1/8" wall size you have 1 1/4" with no room to wiggle.
Well I got my pieces today and they don't fit, go figure. I went back and measured the piece they had and the wall measures about .080" or 14 ga. When I complained they said they are there for the outside dimensions. I said "But you list the wall thickness." I guess it is up to us to know what we are doing. Now I have $35.00 dollars of steel I can't use. I will have to figure something down the road to build to use it up.
The 2" x 1 1/2" x 14 ga has to be ordered and wont be in until around Friday.
Hopefully it will work and I can get started on my roof raise.
William
Old 08-04-2013, 08:53 AM   #134
Roof racks? Long enough? Did you say you are taking the windows out by the way? I think I'll be in the market for more windows, good to have back ups. Especially ones that are exact tint.
Old 08-04-2013, 01:26 PM   #135
wmkbailey's Avatar
Engine: 3126
No, they are only 2' long. I might be able to use them to make my battery bay.
Yes I will be removing all the windows. Replacing with RV dual pane.
William
Old 08-04-2013, 08:30 PM   #136
Where are you getting the windows? Is that already in your budget?
Old 08-05-2013, 09:38 AM   #137
wmkbailey's Avatar
Engine: 3126
My new windows may not be put in until September or October, but I will be removing the windows this weekend or next. They come out before the roof raise and will be skinned over. I will put the new windows in later when I have my interior layout more final.
I may wait until after I spray the insulation. Then I will have a nice tight fit.
William
Old 08-05-2013, 10:49 AM   #138
JakeC's Avatar
That sucks about the steel. I hate setbacks like that :/ Getting exited to start cutting roof supports?
Brutus
Old 08-05-2013, 03:56 PM   #139
wmkbailey's Avatar
Engine: 3126
Just got off the phone from the shop. They had just got the bus inside and on the lift to take the wheels oof to measure the breaks. The inspector got calles to tow someone. He may get it done late tonight or tomorrow. So far everything looks good.
I'm iching to start cutting on the roof. I discovered that the wire harness has a connector right behind the drivers seat. That will make it easy to disconnect. I will cut it just after the connector to extend it after the roof raise.
William
Old 08-05-2013, 05:21 PM   #140
MAKE SURE TO CUT IT FAR ENOUGH FROM CONNECTOR SO YOU CAN STAGGER THE INDIVIDUAL CUTS A COUPLE INCHES SO HARNESS DOESNT END UP BEING BIG AROUND AS A COFFEE CAN
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 425 01-18-2017 09:40 PM
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 59 04-13-2015 10:02 PM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 11:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 11:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 07:49 PM
