Old 08-10-2013, 05:50 PM   #161
wmkbailey's Avatar
Engine: 3126
Re: The Journey Visvi 1999 Thomas MVP ER
Next I cut the angle iron that will be welding on both the supports and rams. I will feed the threaded rod through the angle iron and that will be used to raise the roof.
The angle iron I got is 2" x 1/8", they will be cut to 1 1/2" wide.
Measured and scribe, wish I had a band saw to cut these, instead I used my angle grinder with a cutoff wheel. Not the most accurate, but quick.
Then I drilled a 3/4" hole for the threaded rod.
The rams that will lift the roof are 1 1/4" x 14 ga square tubing, cut to 42".
Here are all the pieces ready for assembly.
The reason my supports are rectangle tubing is to allow for the heads of the support bolts. That gives my 1/2" clearance for them. They are shorter than that so I added a nut to make up the difference.
The nut gets me just under .5". Here you can kinda see how it fits together.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 08-10-2013, 06:10 PM   #162
wmkbailey's Avatar
Engine: 3126
Now to assemble and weld. I have not welded in six years and my farm welder is an arc welder. I picked up a wire feed welder to use in the bus because all my farm welding was 1/4" or bigger, with lots of crud to weld through, it worked good for that. So some practice welds first.
First attempt, I did not get good penetration on the top piece.
This went a little better. It was hard getting use to the wire being pushed out into the steel, instead of me feeding the rod myself.
So here we go.
Here are all the pieces.
Assembled and ready to be welded. I think I stared at this for about 15 mins before I got the courage to start welding. Once started, it did not take long to get them all done.
One support and ram ready to go.
Here they all are. I checked each one to make sure they did not bind on the threaded rod. After I moved the ram up to where it needs to be to attach to the roof, I still had 12" of lift. I only need 10"
Once I attach these to the window pillars. I still have to measure and weld the piece that will bolt to the roof.
This is similar to what Gumpydog did to raise the roof on his MC9 bus. He welded the angle iron to the window pillars, I did not want to do that, so I stole the support and ram idea from "The Millicent Chronicles; two foot roof raise, big tailgate"
You can see how Gumpydog did his roof raise here http://www.gumpydog.com/Bus/MC9_WIP/...g_the_roof.htm
Here is a close up of my weld, I hope it will be good enough.
William
Old 08-10-2013, 06:20 PM   #163
wmkbailey's Avatar
Engine: 3126
whew!!!
William
Old 08-10-2013, 06:27 PM   #164
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
Very cool. You're a genius.
Old 08-10-2013, 06:33 PM   #165
wmkbailey's Avatar
Engine: 3126
I'm a copy cat
William
Old 08-10-2013, 07:42 PM   #166
wmkbailey's Avatar
Engine: 3126
Here is a visual of what I want to do. Crude, but it works.
William
Old 08-10-2013, 08:04 PM   #167
Accordion's Avatar
Year: 1973
That looks great. I must say that you might consider one or two windows behind the door. It will make it a lot easier for you to see when you intend to go through an intersection.
I once had a van with no windows on the right hand side except the passenger door. It was often difficult to see traffic, especially if the intersection was not 90 degrees.
Old 08-10-2013, 08:06 PM   #168
wmkbailey's Avatar
Engine: 3126
I will be putting Dual pane RV windows in, Just could not figure how to draw them in Microsoft Paint.
I wanted to show that I'm only raising a section of the roof not the whole thing.
William
Old 08-11-2013, 06:19 PM   #169
wmkbailey's Avatar
Engine: 3126
Nice weather today was able to remove all the windows and the outside covers for the window U channel. I re-mounted the one that are located where I will attach the roof raising mechanism. I like that word "mechanism"
After try many different ways to pry the outside covers off, I found that getting the prybar between the cover and the pillar and using your weight to pry out from inside work the best.
Then I bolted the Ram and supports to the window pillars. I moved the bus around and found a spot where the bus sits level. I'm going to mark this spot so I can find it to park when I move the bus next time.
I used a magnetic level I have and found out the bottom of the support needs to come out about .825" to be vertical with the bus. I had some 3/4" nuts and fender washers, 1 nut and 3 washers = .830, close enough.
See level to the bus. I then put the Ram and supports together to measure the piece that attaches to the roof.
I bought a metal cutting abrasive blade and put it on my compound miter saw. This cut through the steel like butter.
I drilled 1/4" holes 1 1/4" from the end of the piece to bolt to the roof support. I drilled them at 1 1/4" because if I put them at the halfway mark, I would not be able to get my hand drill in to drill the roof support.
Everything mounted, lined up and marked so I came weld it in place. I have to take it all down and cut the pillar, them put it all back together before I can weld.
Here is a close up of the bottom section.
William
Old 08-11-2013, 06:19 PM   #170
wmkbailey's Avatar
Engine: 3126
I need to drill the roof supports on the other three window pillars, cut and weld. I hope to get that done this week after work. Then I just need to finish cutting the roof apart and up she goes. I hope the weather behaves next weekend to do this.
Here she is all covered up and ready for the rain this week.
Anyone need any windows, I have some nice tinted ones.
William
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 443 04-13-2018 09:34 AM
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 10:55 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 10:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 10:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 06:49 PM
