Old 08-16-2013, 08:37 PM   #191
wmkbailey's Avatar
Engine: 3126
Re: The Journey Visvi 1999 Thomas MVP ER
Originally Posted by opus
I dont allow people over 6' on my bus. Problem solved!
Hey!
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 08-16-2013, 08:41 PM   #192
opus's Avatar
Chassis: All-American R/E
I figure its a lot less work to take that stand then to do a roof raise. At my age, I am getting an aversion to hard work. LOL!
Old 08-17-2013, 08:08 AM   #193
Chassis: Saf-t-liner
Engine: Cat 3126 - MD 3060
Does your deadbolt keep your door shut tight?
ThePimentals is offline   Reply With Quote
Old 08-17-2013, 01:56 PM   #194
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
I actually went to see wmkbailey's bus a few weeks ago, after he had gutted all the seats and interior panels but before he started cutting the roof. This particular model bus (late 90's Thomas MVP) has a LOT of headroom as-is, I am 6'2" on a good day and I had several inches of headroom in the center, I believe it is 78" in the center of these buses. Personally, if I am lucky enough to find one of these buses for sale before next summer, I wouldn't do a roof raise, but I believe wm wanted to do it so it felt more roomy and more room for add'l insulation. A lot of heat is lost via the roof and a lot of heat comes in via the roof.
I wouldn't trust myself with the metal fab or have the time / patience for such an endeavor but it will probably make the bus feel huge (comparitavely) on the inside.
porkchopsandwiches is offline   Reply With Quote
Old 08-17-2013, 02:26 PM   #195
It did
Old 08-17-2013, 07:35 PM   #196
bapos's Avatar
Everyone thinks being tall is the end all be all of things... Well having a bus and being 6'3" tall is not always the best thing in the bus world. Although I would love to raise my bus I wont do it to this one. This bus for me is more of an experiment. I love to see what everyone is doing and how they do it. Ideally I would like to see people do more video but one thing at a time. Being so tall Id like to raise the next bus I do.
I can feel the bottom of the roof rubbing my hair as I walk down the inside of the bus. Kind of a bad feeling but I I lean over as I have enough scars on my head.
Here is my school bus conversion thread http://www.skoolie.net/forum/viewtopic.php?f=9&t=10282
Pics of my conversion @ photobucket http://s18.photobucket.com/albums/b1.../School%20Bus/
Old 08-18-2013, 09:01 AM   #197
wmkbailey's Avatar
Engine: 3126
It did
Ha ha ha.
No it does not keep the door shut tight, just gives me some peace of mind. I can pull the door open about 2" Right now I use the air to keep it tight, but want to come up with a latch that would close the door tight from both inside and out., with out the air.
William
Old 08-18-2013, 09:54 AM   #198
wmkbailey's Avatar
Engine: 3126
Happy birthday to me. Yesterday was my 50th.
Here's Durango wishing me a happy birthday, you young whipper snapper (he's 13 1/2 which makes him like 76 our age. I hope I look that good when I get old)
I was hoping to start the lift at 11:00 but it took longer that expected to get everything ready.
These things I could not cut through from inside and made me climb on the roof to cut. Once I got the roof cut free the pillars were easy. Using my circular saw with a 7" abrasive cutting blade it made short work of it. Using the Ram Supports to put tension of the roof prevented the saw from binding. All the popping and groaning the bus made when doing it was ... interesting. It was weird walking through the bus and seeing the middle shift and the front not move, then getting off and seeing the front shift and the middle not. The Ram Supports held the roof up and felt very sturdy, I could only shift the roof about 1/2" either way, but it was not going anywhere.
At 12:35 we have lift off.
Up the first inch.
An hour and 15 minutes later it was done. It took little effort to turn the bottom nuts that lifted the roof. Nothing binded during the lift. My friend Jim was there for moral support and want to know if he could help. I only had one 15/16 wrench, but with only 3" left to go I remembered I have an adjustable that would work. I could have been done in under 40 minutes.
Now to start welding the bus back together. The roof had kicked out about 1/2" on the drivers rear and passenger front sides. When I clamped in the four corners to weld it came back into place.
I hung two plumb bobs, one front and the other rear to check alignment. I screwed the string to the roof support and spray painted over it to mark for when I lowered the string to make sure it was in the same place. Close enough for a skoolie.
Once I got the welder adjusted tit welded up just fine. The only other adjustment I will have to make is, when I cut the front roof free it spread out about an inch on both sides. The rear did not spread out like the front. I used one my ratchet straps and was able to pull it back in.
By 5:00 I had only eight supports welded in, but my neighbors, Blues BBQ Company, found out it was my birthday and brought over a bottle of rum and some Coke... What happens in the bus stays in the bus.
That blurry blue truck is them. That is about how it looked when we got done around 10:00
William
Old 08-18-2013, 10:40 AM   #199
wmkbailey's Avatar
Engine: 3126
I had a little too much to drink, so I walked home. At 5:00 this morning I heard it start to rain, so I stumbled back out of bed and walked back to the bus to cover it with tarps and drove the car home. Good thing it is only about a 30 min walk. Now I almost feel sober
William
Old 08-18-2013, 12:59 PM   #200
Happy BD The roof raise looks like fun. Well planned and well completed--credit where credit is due!
ol trunt is online now   Reply With Quote
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 443 04-13-2018 09:34 AM
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 10:55 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 10:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 10:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 06:49 PM
