Old 08-18-2013, 02:12 PM   #201
Re: The Journey Visvi 1999 Thomas MVP ER
Good show old man happy rum and coke....oooppss birthday
Old 08-19-2013, 08:38 AM   #202
JakeC's Avatar
It's up!! Looks awesome! And happy birthday as well. Hope you have fully recovered
Brutus
Old 08-19-2013, 09:55 AM   #203
wmkbailey's Avatar
Engine: 3126
Almost recovered, getting old is over rated.
Raising the roof 10" does not look like much, but being able to see out the windows with out bending over is nice.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 08-19-2013, 11:14 AM   #204
JakeC's Avatar
I bet! I actually really like your raise. High enough that it will get you the results you need, but it won't look goofy. Your bus may end up being the cleanest roof raise, yet. Let's face it, Smitty's bus was awesome, but it looked like Frankenstein from the front. Millicent looks awesome, but not streamlined (oxymoron for a bus, I know). Yours has the potential to look VERY clean. I think it will flow better aesthetically is what I'm trying to say, lol.... It will depend largely on if you can slope the rear, as well as the front.
Brutus
Old 08-19-2013, 11:36 AM   #205
Diesel Dan's Avatar
Engine: DT466/AT545
I agree with JakeC - this roof raise is awesome! It's almost exactly what I was envisioning as how I would do that job, so I'm really excited to see how it works out. Even if you decide to just fill in the gap flat rather than sloped I think it will look okay. Like I said before, if you just add some "stuff" up there on the lower roof sections to break up the lines, I think it will be fine. TV antenna, air horns, solar panel, roof rack... anything like that.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 08-19-2013, 12:07 PM   #206
wmkbailey's Avatar
Engine: 3126
I may keep the rear flat and add roof top storage in that space. It would be easy to get to from the rear. Not sure how I would do a ladder because of the engine door.
William
Old 08-19-2013, 12:16 PM   #207
Just weld the lower rungs right to the door. You probably need to reinforce the door with some thing.....maybe that square tubing you got that didn't work for the roof raise?
I know the exterior slopes are what everyone is looking at right now, but I am more curious what your plans are for the interior of the front sloped edge. Are you going to cut it out so that the sheet metal you add is the new ceiling or are you going to leave it and use it as a shelf for something? Seems to me like a good place for the sound system to be hidden and out of the way.
Malkieri is offline   Reply With Quote
Old 08-19-2013, 02:00 PM   #208
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Awesome raise, I vote for slanted front straight rear, keeps with the basic roof line of a Thomas.
Not sure what your engine door is made of, my Blue Bird came with factory roof rack. Lower rungs are bolted to the door, which is made of about 3/16 aluminum. There are steel plates inside, the whole thing is pretty solid.
Old 08-19-2013, 02:03 PM   #209
wmkbailey's Avatar
Engine: 3126
Thanks guys sound like that may work, problem solved.
William
Old 08-19-2013, 02:14 PM   #210
wmkbailey's Avatar
Engine: 3126
I plan to cut it away and slope it up in a way to add windows there. like the Greyhound Scenicruiser
I know they would be small windows, 8" - 10" high. We will see what I can find.
William
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 443 04-13-2018 09:34 AM
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 10:55 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 10:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 10:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 06:49 PM
