Old 08-19-2013, 02:17 PM   #211
Re: The Journey Visvi 1999 Thomas MVP ER
see that's what I want to do; raise rear 2/3rds
the scenicruiser is my dream bus
Old 08-19-2013, 05:17 PM   #212
wmkbailey's Avatar
Engine: 3126
Question about riveting.
This is how I plan to rivet the sides of the bus. I'm using the same spacing that the panels around the emergency door uses, 3 1/2" from top then 4 1/2" the rest of the way down.
Here is my pillar after raising the roof.
This is with sheet steel skin over lapped and riveted with above spacing.
My question is; as you can see it will leave two rivets only riveted to the sheet steel skin.
Is this OK, or will this cause an issue later on?
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 08-19-2013, 08:21 PM   #213
LuckyChow's Avatar
Coachwork: Phantom
Chassis: Gillig
Engine: Series 50
I believe that'd hold just fine. There shouldn't be much stress on that area.
LuckyChow is offline   Reply With Quote
Old 08-21-2013, 10:10 AM   #214
wmkbailey's Avatar
Engine: 3126
I found two of these on e-bay for $75 each.
They are 35" x 9" tinted RV windows. I think they will work on my new forward cap I have to make for the raised roof. I have anywhere between 12" - 15" depending on how I slant the front area. With the trim ring they are 36 1/4" Wide X 10 3/8" Long X 1 3/4" Deep
William
Old 08-21-2013, 10:15 AM   #215
browncrown's Avatar
Rated Cap: 79 at Birth
Beautiful job on the roof raise! Like others have said, I like the style, it's going to be great!!!
BC
Old 08-21-2013, 10:54 AM   #216
JakeC's Avatar
Perfect!!
And I agree that only having rivets attached to the skin in that area won't hurt a thing. The skin is just keeping the elements out
Brutus
Old 08-21-2013, 11:04 AM   #217
Guest
Posts: n/a
This is looking awesome! I can't wait to see how those windows look on the slant at the front.
Excuse me if this is off-topic but I thought that I might ask you since you're neck-deep in a roof raise... do you think that doing a roof raise by cutting ABOVE the windows would be much harder? When I get a bus I'd like to keep all of the original windows, raise the roof 10-12" and add small windows above the originals (in the space created by the raise) and on the slant (like you're doing). Anyone see a major issue with that kind of raise? Has it been done?
Thanks
PS. This is my first post! I had to sign up after seeing your project.
Old 08-21-2013, 01:08 PM   #218
wmkbailey's Avatar
Engine: 3126
Thanks
Thanks,
It would be a little tricky to cut above the window. You have cross supports at the window line. If you cut above, you have nothing to support your roof horizontally. You would have to weld something in to keep the roof in alignment. I have a gutter right at the roof line that I will put my new steel under to prevent leaking. Not sure how you would do that above the window line.
Anything is possible. I have not seen anyone do it above the windows; in the window area gives you an easy place to re-attach the roof.
William
Old 08-21-2013, 04:10 PM   #219
eyedeal.ink's Avatar
Those windows will look great, I'd definitely go with the tinted and you can't beat the price. Some days I wish I'd have raised our roof, the rear 2/3rds is a great idea, would've cleared the stove pipe too.
"That's,. like,.. your opinion, man...." - the Dude.
eyedeal.ink is offline   Reply With Quote
Old 08-22-2013, 09:14 AM   #220
wmkbailey's Avatar
Engine: 3126
Anyone try to install one of these retractable screen doors on the front door? I may give this a try.
http://www.homedepot.com/p/ODL-Stand...-100656632-_-N
William
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 443 04-13-2018 09:34 AM
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 10:55 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 10:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 10:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 06:49 PM
