Old 08-22-2013, 11:01 AM   #221
Re: The Journey Visvi 1999 Thomas MVP ER
Maybe Lorna?
Someone did I'm sure
Old 08-22-2013, 11:28 AM   #222
wmkbailey's Avatar
Engine: 3126
Looks like the next two weekends will be some fun. I get an extended weekend next because of Labor Day, just in time. My steel will be here and cut by two this afternoon. Good thing I have most of the roof welded, I have to drive across the street to pick it up. My 3/16 Structural Rivets will come in tomorrow.
The windows won’t be here until Monday, but I'm starting from the back working forward anyway.
Update, I just got an e-mail from UPS. They are in New Stanton, PA and will be delivered tomorrow.
Question about making the end cap; I'm going to weld to the rear piece and slide the top band under the raised roof and rivet together at that support. I have never welded sheet steel, do you just tack and use something like bondo to fill it the rest of the way, or do you weld the complete seam. Everything I see on TV, they just tack weld and fill.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 08-22-2013, 06:54 PM   #223
Originally Posted by wmkbailey
Anyone try to install one of these retractable screen doors on the front door?
Originally Posted by bansil
Maybe Lorna?
If I recall correctly, Lorna once mentioned having the "As Seen on TV" magnet screens that hang like a bead curtain across the opening. You, your dog, or your cat just push your way through the middle, and the two halves part like the Red Sea in front of Moses' rod. Pass through, and magnets sewed into the center seam snap the two halves closed to keep the nasty flyin' critters out.
If I remember wrongly, chalk it up to "Old-Timers' Disease." But they are a good idea worth trying.
Edit: Wow! Post #800. It took me over five and a half years to get this far, though.
Old 08-22-2013, 09:55 PM   #224
wmkbailey's Avatar
Engine: 3126
Maybe Lorna?
I see back in 2011 Lorna was looking into this screen, but I think Redbear is correct and she went with the "As Seen on TV" magnet screens
William
Old 08-22-2013, 10:55 PM   #225
roach711's Avatar
Rated Cap: 19
We have one of the magnetic door screens and it works pretty well considering it only has 4 closing magnets. If I was going to get another one I'd get a "Magic Mesh" screen which has 18 magnets and looks like it closes way better than ours.
The Roach Motel
Old 08-23-2013, 12:32 AM   #226
LuckyChow's Avatar
Coachwork: Phantom
Chassis: Gillig
Engine: Series 50
You will stich seam it. Do not weld solid.
LuckyChow is offline   Reply With Quote
Old 08-23-2013, 09:05 AM   #227
wmkbailey's Avatar
Engine: 3126
Yes, I plan to stich seam the weld, my question is do I overlap them and weld the entire joint or space them and fill with some kind of body filler.
William
Old 08-23-2013, 09:24 AM   #228
JakeC's Avatar
If it were me, I would just stitch (space them) and fill. I had a tear on the top of my bus that I had to weld and it was a PAIN. Thin sheet metal and using only fluxcore...that was fun I actually did weld the entire thing, but I felt that it was structural, and I needed to seal it. I was in Mexico and didn't have any filler
Brutus
Old 08-23-2013, 12:50 PM   #229
Fluxcore is def. NOT what you want to weld thin sheet metal
Now if you had access to a couple cunksof copper or alum say 2x4x3 and radiused on "small" end you could have an assistant inside bus with gloves holding it against the sheet metal as you stick it up a few pcs of alum is best so they can cool
Old 08-23-2013, 01:29 PM   #230
JakeC's Avatar
I know. Fluxcore was about the worst choice, but it was all I had and I didn't have gas. For rusty exhaust that I don't feel like removing and cleaning, though...it is by far my favorite. I crank the temp all the way up, turn my speed up to match, and let 'er burn (in about 1 second increments, lol)
Brutus
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 11:55 AM
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 436 02-12-2017 09:38 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 11:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 11:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 07:49 PM
