Old 08-23-2013, 02:35 PM   #231
Re: The Journey Visvi 1999 Thomas MVP ER
I know I used fluxcore when I did shock mounts...mmmm..snow,water,grease....better penetration...oh and the wind...I feel the pain
Old 08-23-2013, 03:45 PM   #232
wmkbailey's Avatar
Engine: 3126
I'm using fluxcore, with my welder turned down to feed of 2 and low current, it will do 18 ga. the roof and what I got to join the roof is 16 ga. Spacing the welds is what I wanted to hear, less welding is good.
Oh, I have done 16 ga with an arc welder, that was fun.
So... what is a good filler to use
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 08-23-2013, 05:43 PM   #233
Kitty hair--by Bondo I think. Fills fast and has some strength. Then regular Bondo or metal glaze to finish to prime.
Old 08-23-2013, 07:38 PM   #234
LuckyChow's Avatar
Coachwork: Phantom
Chassis: Gillig
Engine: Series 50
Originally Posted by wmkbailey
Originally Posted by LuckyChow
You will stich seam it. Do not weld solid.
Yes, I plan to stich seam the weld, my question is do I overlap them and weld the entire joint or space them and fill with some kind of body filler.
Don't weld it solid. User a filler between welds. We used "All Metal" filler on my buses between the stitch seams. It has strength and will stay in the holes.
LuckyChow is offline   Reply With Quote
Old 08-24-2013, 03:05 PM   #235
JakeC's Avatar
That sounds horrible, lol... My arc welding skills are non existent.
Brutus
Old 08-24-2013, 07:41 PM   #236
wmkbailey's Avatar
Engine: 3126
It was a beautiful day today and tomorrow will be the same, high only 80. I worked a long day, but it seemed like I didn't get much done.
I finished welding the supports. Pulled the Ram-Supports off and welded those also.
I spent the rest of the time prepping to put the new skin on. I had to remove the cover panels on the inside over the engine cover. The drivers side I will have to put back on, it is part of the air intake. You can see it behind the ladder here.
Then I had to remove 20 rivets on each side to re-rivet the new skin to.
This was slow going it took a little over an hour each side to drill these out.
I had to remove the top screw here, this is where I will rivet the bottom of the new skin. I did a test fit and my measurements where correct.
It took about four hours total to get all done. Tomorrow I have to remove the old glue on the U channel and start re-skinning.
William
Old 08-24-2013, 07:43 PM   #237
wmkbailey's Avatar
Engine: 3126
Almost forgot, I did a test fit of my new windows.
From the front.
From the inside.
William
Old 08-24-2013, 08:28 PM   #238
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
What you are doing is great work. You're definitely talented with fabrication.
I am excited to follow your project.
Old 08-24-2013, 09:33 PM   #239
JakeC's Avatar
I love the windows! Looking good, man. I can't believe you already have the roof raised and supports welded.
Brutus
Old 08-25-2013, 09:44 AM   #240
Looking really good!!! I wish Ontario was more lenient on customization. If i did this i would never get it insured here.. Great job!!!
Project Niles Skoolie
http://www.skoolie.net/forum/viewtopic.php?f=9&t=55161
FOLLOW US ON FACEBOOK TOO!!!
https://www.facebook.com/NilesSkoolie
NilesSkoolie is offline   Reply With Quote
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 443 04-13-2018 09:34 AM
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 10:55 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 10:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 10:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 06:49 PM
