Old 09-02-2013, 11:49 AM   #261
Re: The Journey Visvi 1999 Thomas MVP ER
I ran into one of those when i put my door in the side of the bus... sooo many rivets! you must be an expert rivet remover by now though lol.
Looking really good man!
Project Niles Skoolie
http://www.skoolie.net/forum/viewtopic.php?f=9&t=55161
FOLLOW US ON FACEBOOK TOO!!!
https://www.facebook.com/NilesSkoolie
NilesSkoolie is offline   Reply With Quote
Old 09-03-2013, 08:15 PM   #262
wmkbailey's Avatar
Engine: 3126
Aaaah relief. Even though it was 88, only 4 degrees cooler. With almost no humidity, it felt good to work out side tonight. I wish the sun wasn't going down earlier.
I started to drill out the rivets to get the sheet metal for the emergency door out. After the first 11 rivets where out the first piece almost fell off.
I decided I needed a break from drilling, so I welded in the support.
I only have about two hrs after I get home from work, but I did get ten more rivets drilled. That leaves eleven left to finish.
It is suppose to be like this all week and weekend
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 09-04-2013, 09:25 PM   #263
wmkbailey's Avatar
Engine: 3126
My quality assurance team had to come out and check the work I'm doing.
I got the rest of the rivets drilled and removed the sheet metal for the emergency door. I then realized that this was the top half, I still have to do something with the bottom half.
Checking it out the emergency door frame is held in with screws, between the supports and the old skin.
I can remove the screws and pry this out. Then I can put the new skin in the same place. I still have to order it because I forgot.
It was easy to remove , all the screws but two came out. I have to weld a support horizontal where the window sill would have been if it wasn't a door. This will be used to rivet the top piece over the bottom.
William
Old 09-04-2013, 10:06 PM   #264
Engine: 190hp 5.9 Cummins
What is your procedure for drilling out the rivets? Size and type of drill bit, ect. Do you use the same size bit all the way, or change bits? Drill part way then use a center punch? How many rivets are your bits lasting.
Also when a screw will not come out with my 1\4 impact, I just give it a few wackes sideways with the cold chisel and a 4 pound hammer. Then they come out every time.
Your thread is my favorite on skoolie.net right now.
Thx Nat
Old 09-05-2013, 07:39 AM   #265
wmkbailey's Avatar
Engine: 3126
Wow thanks Nat,
My rivets are 3/16, so I use a 3/16 Milwaukee Thunderbolt Black Oxide drill bit . I also use 3 in 1 oil to help keep the drill bit from getting to hot and take my time. I drill until I'm even with the piece the rivet is in, and then I can chisel the head off. Most times I can punch the rest of the rivet out too, if not I drill some more until it comes out.
I get about fifteen rivets before it starts to slow down being able to drill. The trick is to not drill too fast, heat is your enemy. I have a drill doctor, but can only get three sharpening before the bit does not work as well.
I never thought of wacking the screw, I use the magic flat screw method.
William
Old 09-05-2013, 10:31 AM   #266
I too am removing rivets by the hundreds on my current project.
You are spot on about heat being your enemy when drilling. To avoid the mess of cutting oil, I've been cooling my bit every 5 to 10 rivets by just plunging the drill bit into the moist cool ground. While that one is cooling, I use my other drill to drill 5 or 10 more, then repeat.
I've been using a 3/16 Milwaukee Cobalt drill bit. They cost about $10 but I'm able to drill about 50 rivets before it stars drilling slower. I get over 200 rivets before its to dull to use any farther. Same as you, I drill into the rivet flush with the steel underneath, then hit with a flat cold chisel. Most times one hit is all it takes .
Ive been using my Dewalt 20 volt drills to power the bit. I can drill around 100 rivets per 3 ah battery. I also have Milwaukee 12 volt impacts and drills. I like them too.
Thanks for sharing
Old 09-05-2013, 10:37 AM   #267
wmkbailey's Avatar
Engine: 3126
I've been using a 3/16 Milwaukee Cobalt drill bit. They cost about $10 but I'm able to drill about 50 rivets before it stars drilling slower. Nat
My Home Depot only has the $2.37 Black Oxide drill bit. I may have to look arund for the Milwaukee Cobalt drill bit, save me time sharpening drill bits.
My Milwaukee 12 volt drill started to smoke, so I switched to my corded drill. It has more power and makes drilling easier.
William
Old 09-05-2013, 10:39 AM   #268
wmkbailey's Avatar
Engine: 3126
I drilled a trough into the platic top of my ladder and fill it with oil and just dip the drill bit in every so often. I swear the bit drilles better with the oil.
William
Old 09-05-2013, 11:06 AM   #269
Diesel Dan's Avatar
Engine: DT466/AT545
I used to work in a machine shop, and we always used oil or another form of liquid coolant/lubricant when cutting steel. The purpose is to cool the cutting edge, lubricate the non-cutting surfaces and chips, and wash away fine chips. Yes, it is messy and smokey, but it definitely helps you to drill faster and of course extends the life of the drill bit.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 09-05-2013, 11:53 AM   #270
wmkbailey's Avatar
Engine: 3126
Ordered my Natures Head Composting Toilet today http://www.natureshead.net/ It is shipped from PA, so I should get it by Monday or Tuesday.
Since I don't need a black water tank, or any tank directly below my toilet. I may put my bathroom in the rear of the bus. My bedroom may only have a 5' wall making the bus look more open on the inside. Still playing around with this idea. It looks like I have plenty of room to run the drain for the shower and sink. My grey water tank will be forward of the rear axel. Fresh water will be under my bed.
William
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 11:55 AM
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 436 02-12-2017 09:38 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 11:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 11:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 07:49 PM
