Old 07-02-2013, 05:39 PM   #21
syke's Avatar
Chassis: All American RE
Re: The Journey Visvi 1999 Thomas MVP ER
Originally Posted by wmkbailey
Here are some photos.
There goes the neighborhood! Damn hippies.
Rear engine, big motor, lockup trans, rock bottom price... way jealous! Kick ass bus dude. Keep the pictures flowing.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 07-02-2013, 06:35 PM   #22
browncrown's Avatar
Rated Cap: 79 at Birth
Ditto!!!
BC
Old 07-02-2013, 06:54 PM   #23
wmkbailey's Avatar
Engine: 3126
Big dent, ouch
And a little rust
William
http://thejourneyvisvi.com/
viewtopic.php?f=9&t=464989
Old 07-02-2013, 06:58 PM   #24
wmkbailey's Avatar
Engine: 3126
I was looking at the Leaf springs and they look good.
Rear
Front
The only thing I could find is on the front passenger side. It looks like they have been replaced recently.
So maybe it was fixed.
Unless... "#5 Leaf sprint left rear track - broken" means the fifth leaf spring on the drivers side rear is broken. I did not check them. Any ideas?
William
Old 07-02-2013, 06:59 PM   #25
Awesome score...and by the way!
.that ain't no big dent ......and the rust you scored on this.....
Old 07-02-2013, 07:03 PM   #26
Look between the rear u bolts
It ooks like you have one big heavy set for the wt* ad a couple to locate (track?)
Cracked/broken will be reallllly obvious
Old 07-02-2013, 07:13 PM   #27
wmkbailey's Avatar
Engine: 3126
Drivers side tires look good.
Passenger side will need to be replaced soon.
We will see if they pass inspection.
William
Old 07-02-2013, 08:24 PM   #28
Congratulations on the auction win! And a high roof, too!
. . . .I guess I need to stay under 26,000 lbs
I just love Maryland.
Those are National CDL requirements - and the Gross weight is the figure on the data plate, not the amount you load it to. Some states will figure the gross by the higher of the maximum design weight or the actual overload shown on the scales. Driving an 18,000 lb vehicle would be OK on a Class D until you load it to 18,001!
National law also says RVs are exempt from CDL and truck inspection rules. If you are registered as a 26,000+ pound truck, you need a class B CDL. If you are an RV, some states will have a special heavy RV/air brake endorsement you might have to add to your car license, other states will let you go with any class.
Old 07-02-2013, 08:41 PM   #29
wmkbailey's Avatar
Engine: 3126
Redbear
That is how it is in Maryland for an RV except this is for a Motorhome or RV. They also require the special heavy RV/air brake endorsement, which I'm stuging up for. You have to bring your own vehicle. I will have to wait until I get it inspected.
Gross Vehicle Weight of Motor Home or RV License Class Required
Less than 26,001 lbs. Class C (Non-commercial or Commercial)
26,001 lbs. or more Class B or A (Non-commercial or Commercial)
So if my bus is rated for 30,000 , but it only weighs 21,000, I have to get the class Class B or A Non-commercial license because it is rated over 26,000?
William
Old 07-02-2013, 09:06 PM   #30
That's the way it works. 30,000 lb maximum design weight under Federal rules is Class B. If Maryland makes you pass a non-commercial Class B (no driving for hire) to drive a heavy RV, then that is in your future.
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 443 04-13-2018 09:34 AM
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 10:55 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 10:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 10:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 06:49 PM
