Old 10-15-2013, 06:15 PM   #361
wmkbailey's Avatar
Engine: 3126
Re: The Journey Visvi 1999 Thomas MVP ER
Finally some good weather. I got out after work and was able to get two hrs in before it got dark. I got the drivers side strap measured and drilled. Even got started riveting it on. Tomorrow I should be able to finish it and get the top strap riveted, it is all ready drilled. Then I can measure and do the final cut om the front and start welding.
I'm so looking forward to getting this done and putting in the windows.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 10-15-2013, 06:16 PM   #362
wmkbailey's Avatar
Engine: 3126
Originally Posted by lifeintheslowlane
I painted mine with a brush and roller in 4 hours in a Menards parking lot.
I did mine with a Wagner spray gun in two hrs in a tattoo parlor's parking lot
William
Old 10-16-2013, 05:27 AM   #363
Chassis: Saf-t-liner
Engine: Cat 3126 - MD 3060
Well I don't know what I mean either. I do have a traumatic brain injury. Don't mind me.
ThePimentals is offline   Reply With Quote
Old 10-16-2013, 07:53 AM   #364
wmkbailey's Avatar
Engine: 3126
I call them brain farts.
I hope to have the bus to the point where I can take trips next year. I would like to come up north next fall. If I do I will let you know, would like to meet up with you all.
William
Old 10-18-2013, 05:52 AM   #365
I hope by next fall to be gone, but, I'm sure life won't want me to be. So I'll see you then, haha.
Old 10-18-2013, 08:22 AM   #366
wmkbailey's Avatar
Engine: 3126
If you are, let us know where you are heading, I'm sure we can find a spot to meet. With a rolling home, the journey is the fun part.
Ha ha, did you see how I rolled that in, "the journey is the fun part", "The Journey Visvi ". I'm so clever.
William
Old 10-18-2013, 06:17 PM   #367
Engine: 190hp 5.9 Cummins
How far north?
Old 10-21-2013, 10:09 AM   #368
wmkbailey's Avatar
Engine: 3126
How far north?
Not sure at this point. My destination will be Indiana, more than likely will stay in the states. I need to check and see how much longer my passport is good to. I want to make it to Canada sometime, more than likely in the hot summer I will head that far north.
William
Old 10-21-2013, 06:33 PM   #369
wmkbailey's Avatar
Engine: 3126
I'm having a hard time getting the pieces for the roof to line up. I finally decided that it does not have to be perfect, just close.
The old roof steel on the drivers side was not pull down tight to the support, so it puckers. I could not clamp it down when I was riveting it with the new straps.
I drilled out the two next to the pucker to help make it not so noticeably.
On a side note after climbing the short ladder and clambering over the front of my bus to get on the roof. I noticed that porkchopsandwiches was climbing through the emergency hatch. Duh.
Now my ladder isn't too short.
The area of the roof that puckers pushes the front piece about 1.5" out of alignment. I cut back into that area to bring the front piece back into alignment.
I was able to now weld the front piece in, Here you can see where the ol roof puckers up.
Hopefully I can hide most of it with the magic of body filler.
Now I can start on the fun pieces, the side panels. I added some extra cardboard to my old template and made a new template.
Used it to mark the steel and cut with my jig saw. Then I marked 1/2" lines parallel to the edge and scored it with my grinder. The place where I buy my sheet metal suggested this approach.
I found a place on the ground that had a nice slope and used it to form the curve.
It worked really well. Now everything is welded together.
The template is close to being the same on the passenger side. I will have to make some minor adjustments and I can do the same.
William
Old 10-21-2013, 06:59 PM   #370
LuckyChow's Avatar
Coachwork: Phantom
Chassis: Gillig
Engine: Series 50
When I put the new cap on my Thomas, I had to take a ziz wheel and make a blade width cut in a couple of places to take out some of the material so it would lay down. Stitch welded it back.
LuckyChow is offline   Reply With Quote
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 443 04-13-2018 09:34 AM
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 10:55 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 10:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 10:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 06:49 PM
