11-24-2015, 08:04 PM
#841
Engine: 3126
Re-doing the Bedroom part tali (two)
On to day two of the bedroom upgrade. The plan for today is to get the bed platform completed so I can sleep in my bed again, all though the couch was very comfortable last night.
I using the same 1 1/4 I used in the walls. I like the size of this for making everything. We are screwing to the wall and adding supports to the floor to make it stable. The far corner was the hardest to line up, can anyone say plumb-bob. the bus is parked in a place where it is level, this makes building easier, you can use a level to check everything. All pieces are within 1\8″.
We added supports where the hinges are and cross pieces that sit on 1 1/4 wood screwed length wise. The larger piece is a whole 4′ x 8′ plywood cut down the the 80″ a queen size bed is. The piece next to the wall is 11″, to allow for the hinges between them. You need space from the wall to allow for the thickness of the mattress.
You can see the cross pieces attached to the plywood, they sit on the lower 1 1/4’s. This is very strong, I was able to walk across it with no give.
There is a 4″ over hang to make it easier to walk around. The inside storage is almost two feet deep. Tomorrow we build up the floors at the end and along the right side to cover the wheel humps. With the roof raise I will be able to step up and my head just rubs the roof.
11-26-2015, 08:44 AM
#842
Rated Cap: 79 at Birth
Nice bed build...looks really good!
11-27-2015, 09:02 PM
#843
Engine: 3126
Re-doing the Bedroom part tsoi (three)
It is nice to now have a place to put everything.
We also covered the wheel humps, I’m so tired of stepping over them.
I used the same old tried and true method I did for the walls and bed. Someday I will get around to putting down flooring, at this rate I will wait until the painting is done. This took a lot longer than I anticipated. My dad is learning how each piece of wood have to be fitted to the space. Nothing is square and leaving a small gap is good. tight fits = noise, in a house that flexes.
I added two cabinets on the engine shelf and we started to finish insulating and covering the back cap. We should finish this tomorrow and also get the front cap done. The tubing is for my sleep number bed. I like my comfort.
11-27-2015, 09:03 PM
#844
Engine: 3126
Thanks Browncrown, it is nice to know someone is still checking out my build.
11-27-2015, 09:20 PM
#845
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
I'm taking notes for my build as well. Getting my son's girlfriend's dad to help me work on mine since he has a metal shop and apparently our families are getting more closely acquainted.......
11-28-2015, 04:45 AM
#846
I'm sure plenty of folks do... I always check it out.
11-28-2015, 08:21 AM
#847
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
Lookin' good! I try and check out ALL builds daily or as often as I can for ideas, may not log on or comment. I've been planning my toy hauler for three years with cad drawings, cardboard cut outs, masking tape and s#!t gets changed daily. I to will have the folding lid storage box beds [4 singles at the rear].... two rear beds will be offset for two mattresses on each side so I can squeeeeze an ATV in between them.
Wow a finished 2x2" is 1 1/4 x 1 1/4" in your part of the woods? Still 1 1/2" here. Freakin' lumber yards are gettin' cheap!
My old man thought I was nuts buying the bus, our Thanks Giving weekend he was inside with a tape measure taking measurements.....looks like he's building the booth and couch....he's pretty damn handy with wood.
11-28-2015, 08:50 AM
#848
The whole scaling down of lumber standards is a royal PITA. Just makes it all that much harder to match anything previously built. The house on the farm I had in Tomball was built using 2 x 4's that had been milled on site as the first family there owned a lumber mill. They actually measure two inches by four inches and look like logs compared to modern lumber. But working on that house was a nightmare because of the difference.
At the rate things are going we'll be buying framing timbers that can double as chop sticks.
11-28-2015, 09:57 AM
#849
Chassis: AARE
Engine: 3116 Cat 250hp
Looking good William, I check out your build whenever I see something new, just don't comment much. You coming out for another visit this year?
11-28-2015, 12:56 PM
#850
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Having a sawmill is a handy thing. Next best thing is a portable mill like this.
11-28-2015, 01:04 PM
#851
Moderator
Bus looks like it's coming together nicely.
11-28-2015, 02:15 PM
#852
Engine: 190hp 5.9 Cummins
Looking good.
Doing the flooring last is the best way. You will be glad you did it that way.
11-29-2015, 10:48 AM
#853
Engine: 3126
That is good to hear, I was starting to worry. One nice thing, I wont have to worry about getting paint on the floor
11-29-2015, 10:54 AM
#854
Engine: 3126
Hey Red, they are not 2 x 2's they are pieces used in outside porch railings. they're just the size I'm looking for. I didn't want to use 2 x 4's or 2 x 2's but something bigger that a 1 x 1.
11-29-2015, 10:57 AM
#855
Engine: 3126
Hey Somewhere,
I'm in Lafayette right now. Will be here until the 8th. I head back for a week to pick up my daughter and granddaughter and come straight back until the 26th. Then I head to Florida.
Let me know if you are free over the next week and I will come out for a visit.
11-29-2015, 11:07 AM
#856
I'll cook you a steak or some chili if you want somewhere to park your bus for a bit in FL. We're in Sorrento/Apopka about a half hour north of Orlando.
Would love to meetup.
We are close to Disney if that's something you'd like to do with the little one.
12-01-2015, 08:01 PM
#857
Engine: 3126
Hey EastCoastCB
I'm heading down south of Tampa FL I will be there on Monday the 01/04/2016. I would be coming through your area on Sunday.
12-01-2015, 08:08 PM
#858
Engine: 3126
Re-doing the Bedroom finished… for now.
We got all the items I wanted to get done this time around finished. There will always be things to do.
The hardest issue was the fill piece where the roof curves and comes to a point because of the roof raise.
There is nothing to attach this piece to, but you don’t want to leave it open. My dad came up with the solution. We used the can of expanding spray foam. From experience we know it to be very sticky. So we sprayed it in to fill the void and pressed the wood to it and it stuck. When the foam harden, the piece is now “glued” in.
We did the same on both sides and then used cardboard to get the curve piece figured out. It all came together nicely. Since the bottom section of this piece should be close to the top section of the back piece we measured down the distance to the 1 1/4″ over the windows and cut. It fit like a glove.
We did cut insulation and fill in the gaps before we screwed in the wood. Then added the cabinets back in. Now I can’t wait to get some paint on the walls.
Before this was completed and fully insulated. It was always 2 degrees cooler in the back, I only run the front heater. I know this has made a difference because now the back is 1 degree warmer that the front. Next will be to tackle the front section.
We will start in on this, this week.
12-02-2015, 11:18 AM
#859
Looking great, man!
12-02-2015, 03:33 PM
#860
Coachwork: Thomsass
Balusters for a railing, OK then.
