Old 11-18-2013, 08:37 PM   #461
wmkbailey's Avatar
Engine: 3126
Re: The Journey Visvi 1999 Thomas MVP ER
Originally Posted by LuckyChow
I have a similar power inlet on my bus. I've been wanting one of those right angle inlet cords for a while! Congratulations on picking the perfect combination (IMHO). I really like those marine power inlets.
When I bought the power inlet they had this cord as an accessory.
They have it on adventureRV for $69.94.
http://www.adventurerv.net/right-angle- ... Ogod-XcAsg
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 11-18-2013, 08:57 PM   #462
wmkbailey's Avatar
Engine: 3126
I pulled the bus up in front of my apartment. Ran the power cord over to the outdoor outlet. Cranked on my Halogen lights and got ready for work. It would be nice to have heat, but I don't want to run the bus batteries down. Then I remembered, I have the battery charger I was using to charge my new house batteries with. I dropped an extension cord out the back emergency door. In the battery bay I hooked up the bus batteries to the charger and kicked on the Wabasto. When I needed heat I turned the ignition to aux.This will come in handy on Sunday, high 37 low 28, brrr.
I got the last of the rubber off.
After I took this photo I realized I still needed to get the rubber off the wheel wells. Not a big issue it came off easy.
Then I started to wire wheel the rust. I have one of these for my grinder, correction porkchops grinder, it did not fit mine.
It took 20 minutes to do the top two panels. I think from here on, I'm just going to knock off the loose rust. Otherwise it will take too long. Then I will cover it with OSPHO and paint with Rust-Oleum.
William
Old 11-18-2013, 09:02 PM   #463
wmkbailey's Avatar
Engine: 3126
Originally Posted by Tango
The main issue I have witnessed regarding rust around wheel wells has simply stemmed from the lack of sealing (i.e.; "the gap") between the well and the floor. Rotating wheels toss a lot of water up in there. I just re-installed mine (after lots of cleanup, some rust inhibitor and a little paint)...and this time the gap is thoroughly sealed using modern automotive "seam sealant". Flows nicely and when properly applied forms a truly watertight and very durable seal.
That is what I plan to do, I have some OSPHO and Sikaflex 221
William
Old 11-18-2013, 09:11 PM   #464
wmkbailey's Avatar
Engine: 3126
I think I have a problem, I'm an over poster. I now have 576 pictures of my bus, and most of them are in this post. I have as many post as some who started two years ago, and I just started in July.
William
Old 11-18-2013, 10:20 PM   #465
Chassis: Ward
Engine: 6.6L Brazilian Ford
Rated Cap: 1
Good job on the roof raising. Good luck on the inside. That rust is a messy business; don't forget the breather mask.
Bus Transformation: My CHEAP project >>> viewtopic.php?f=9&t=466640
gus
gusbus is offline   Reply With Quote
Old 11-19-2013, 06:04 AM   #466
wmkbailey's Avatar
Engine: 3126
Don't worry, I have one.
William
Old 11-19-2013, 06:22 AM   #467
Chassis: Saf-t-liner
Engine: Cat 3126 - MD 3060
I had 4 wheel well rust throughs, if you only have 1 that's good. The rust has been what I've been doing for the last month. It's everywhere. Stairs too. Been cutting it out grinding it on both inside and out, then welding it and sealing it. Maryland is wet and salty.
ThePimentals is offline   Reply With Quote
Old 11-19-2013, 07:26 AM   #468
Chassis: Ward
Rated Cap: 1
No wheel well rust here but I've got stair rust for sure.
gus
Old 11-19-2013, 08:12 AM   #469
wmkbailey's Avatar
Engine: 3126
Montgomery county does not use salt on their roads. Frederick county does and you should see the rust on their buses. Be glad you got the bus you have.
I have three holes, the rear is small, not much damage. The front two have rust on the rear of the wheel wells. I'm taking a trip to Indiana over the holiday, two weeks, 1500 mile round trip. I will deal with the stairs when I get back.
William
Old 11-19-2013, 09:33 AM   #470
Amazingly...my '46 Chevy (now 67 years young) had zero rust through on the floor and none around the wheel wells. Only on the spacers between the inner and outer sheet metal and a few spots on the body. It appears they may have used creosote on a lot of the steel. It came from Utah.
The '78 Blue Bird I bought in 1985 had rust through around both rear wheel wells. It was from somewhere back East.
Go figger'.
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 443 04-13-2018 09:34 AM
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 10:55 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 10:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 10:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 06:49 PM
