Old 11-24-2013, 11:51 AM   #491
wmkbailey's Avatar
Engine: 3126
Re: The Journey Visvi 1999 Thomas MVP ER
Originally Posted by Tango
Two-Cents --- as others here have previously noted regarding other rig designs...unless you plan on sleeping alone...forever, configuring the bed so that no one has to crawl over anyone else getting in or out makes for a much happier arrangement. I've had both. Never again the "Scuse me" layout.
Like I said...Two-Cents.
You don't have to crawl over each other, the second person can get in and out at the end of the bed. Besides Durango is just happy jumping over me to get out of bed.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 11-24-2013, 07:09 PM   #492
wmkbailey's Avatar
Engine: 3126
Got out to the bus this morning and it was 28 out. Started up the old Wabasto heater and two hrs later it was 61 inside.
Not bad for an un-insulated bus. That poor Wabasto run almost none stop for eight hrs today to keep me warm.
I went to Home Depot and got 25' of 10 GA cable and made a 20 amp extension cord. Man did that new welder work better. I got the three rust holes welded over and sealed with Sikaflex 221. I also used the Sikaflex 221 to cover up all the holes in the floor from where the screws and bolt use to be.
I noticed that my rear driver side turn signal does not always work. Found out why, when I took it apart it is all rusted. The screws just disintegrated. I drilled out one of the mounting screws and replaced it with a larger one and got the light to work again. I got one of the lens screws out and replaced with a new one. It looks like all my rear lights are like this. I'm ordering all new LED lights.
This week I start insulating the inside.
William
Old 11-25-2013, 04:36 PM   #493
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
Funny, mine didn't work either. Neither did the brake / tail light, both were totally waterlogged. LED time!
porkchopsandwiches is offline   Reply With Quote
Old 11-25-2013, 08:31 PM   #494
wmkbailey's Avatar
Engine: 3126
Ha ha, I just ordered mine.
William
Old 11-26-2013, 05:18 PM   #495
wmkbailey's Avatar
Engine: 3126
My roof is leaking like a sieve. Mostly around rivets and all those screw holes where I removed the inner roof steel. Now I know why all the mold.
I guess the cold has made the steel contract enough to cause issues. I was hoping to start insulating this week.
My new Maxxair vent fan does not leak.
William
Old 11-26-2013, 05:44 PM   #496
Do you think a spray-in bed liner like Rhino-liner would fix the leaks and such?
Malkieri is offline   Reply With Quote
Old 11-26-2013, 06:49 PM   #497
eyedeal.ink's Avatar
Sorry to hear that, makes me cringe when I think about leak roofs...there's always Lexel, it's paintable and sticks real good even in the rain.
"That's,. like,.. your opinion, man...." - the Dude.
eyedeal.ink is offline   Reply With Quote
Old 11-26-2013, 06:53 PM   #498
wmkbailey's Avatar
Engine: 3126
Thanks, I will check it out.
I was check on Bus Kote, but it has to be at least 50 to put it on.
William
Old 11-27-2013, 12:17 PM   #499
wmkbailey's Avatar
Engine: 3126
Man, I wish I had brought my swim suit.
I have a small leak over the dash board.
Another coming from a rivet that holds the roof to the support by my door. It runs down the support and onto the floor.
Another form one of the rivets I put in to hold my new front panel. Nothing like creating leaks yourself.
As you can see the new steel is dry, This is where I expected all the leaks.
Here is the exact same spot that my old roof hatch leaked. Now my new cover is leaking too.
Now for the pond in the back. It is leaking through where the roof panels over lap.
Then runs down the wall.
And collects on the floor.
This explains all the mold on the roof here and the rust on the floor.
More good news, somehow I now have a broken window,
I guess it was raining really hard.
William
Old 11-27-2013, 01:02 PM   #500
Diesel Dan's Avatar
Engine: DT466/AT545
Damn man! I don't know what product will be best, but I have a feeling the word "elastomeric" will be featured, and multiple coats applied.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 11:55 AM
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 436 02-12-2017 09:38 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 11:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 11:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 07:49 PM
