Old 11-28-2013, 05:10 AM   #511
Re: The Journey Visvi 1999 Thomas MVP ER
Dugh....you didn't use duct tape
Old 11-28-2013, 12:20 PM   #512
Just fill the cardboard box with concrete and then use "Redheads" to hold the seat in place--both kinds of readheads
Old 11-29-2013, 04:12 PM   #513
wmkbailey's Avatar
Engine: 3126
I was looking forward to finally be building something in the bus. I was not expecting all the stress.
I'm building out the supports for the passenger seat and the battery bank. They will be welded to the floor and I need to get them done before I can start insulating.
Five hrs to weld up the passenger seat support. The cutting and welding only took 1.5 hrs. The rest of the time was spent measuring, figuring and hemming and hawing. I'm learning every inch in the bus has an impact. You move one thing an inch this way and it impacts so many other things down the line.
I like where the seat is positioned.
It is welded to the floor and the seat rail. When I receive the seat swivel I will finish it up.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 11-29-2013, 05:05 PM   #514
Looks good, you will be glad that you have a passenger seat next to the driver, Mine is that way and it makes the drive much more injoyable having my wife beside me(most of the time )
Old 11-29-2013, 06:07 PM   #515
LuckyChow's Avatar
Coachwork: Phantom
Chassis: Gillig
Engine: Series 50
You are right! I usually spend 2 - 3 hours of figuring to every hour of doing. When you have to design everything, it takes time to consider all the options and ramifications of what you're doing. There have also been a few "I never thought of that" moments. They are a tough pill to swallow, especially if you have to tear it out and start over. The general theme I follow is to vision what you want the end product to look like in you head and then go backwards to get it that way. Especially on wood working. I pick out the surface and trim first, then build backwards in my head.
LuckyChow is offline   Reply With Quote
Old 11-29-2013, 10:29 PM   #516
Roger the above. And the smaller the platform, the more critical every inch becomes. There ain't a lot of Fudge Factor in a shorty. One more reason I have so much regard for Ol' Trunt.
Old 11-30-2013, 07:29 AM   #517
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
It took a bunch of "a 1/2" this way-a 1/2" that way" to manage to squeeze in a captians chair in the shotgun position in my shorty. I have to do a interesting dance of slide the seat forward a bit-tilt it a bit-rotate 1/2 way-slide it back--to get it to rotate all the way around. But hey-you only do that when we're parked for the weekend. Worth it to have a second seat in a "normal" option.
Old 11-30-2013, 07:55 AM   #518
Will there be a cover over the entry steps or do passengers need unfeasibly long legs?
Saddletramp is offline   Reply With Quote
Old 11-30-2013, 08:49 AM   #519
Heres my step cover well worth it , it keeps the noise down as well as a place for your feet
viewtopic.php?f=9&t=5931&start=180
Old 11-30-2013, 09:13 AM   #520
wmkbailey's Avatar
Engine: 3126
Hey, I like long legged women.
I plan to build a pull out cover of some sort. Right now it will probably be my grand-daughter and her legs don't touch anyway.
William
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 443 04-13-2018 09:34 AM
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 10:55 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 10:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 10:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 06:49 PM
