Old 11-30-2013, 10:30 AM   #521
wmkbailey's Avatar
Engine: 3126
Re: The Journey Visvi 1999 Thomas MVP ER
Originally Posted by gbstewart
Heres my step cover well worth it , it keeps the noise down as well as a place for your feet
viewtopic.php?f=9&t=5931&start=180
Thanks, I was trying to figure out a way to store it under the seat. I did not consider folding it up under the hand rail like that. I have room there.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 11-30-2013, 10:42 AM   #522
yes it folds out of the way, the first one I made you had to lift it up and store it then put it back in place work great, but a pain in the ass, this is so simple to use.
I really like your build, keep up the good work
Old 11-30-2013, 10:43 AM   #523
Originally Posted by wmkbailey
Originally Posted by Saddletramp
Will there be a cover over the entry steps or do passengers need unfeasibly long legs?
Hey, I like long legged women.
I plan to build a pull out cover of some sort. Right now it will probably be my grand-daughter and her legs don't touch anyway.
You are going to get your grand daughter to crouch in the stairwell so the passenger can rest their feet on her?
Ingenious but probably illegal.
Saddletramp is offline   Reply With Quote
Old 11-30-2013, 11:03 AM   #524
wmkbailey's Avatar
Engine: 3126
Ha ha
William
Old 11-30-2013, 11:22 AM   #525
Chassis: Ward
Engine: 6.6L Brazilian Ford
Rated Cap: 1
The stair cover is a grand idea guys!
Bus Transformation: My CHEAP project >>> viewtopic.php?f=9&t=466640
gus
gusbus is offline   Reply With Quote
Old 12-02-2013, 05:17 PM   #526
Chassis: Saf-t-liner
Engine: Cat 3126 - MD 3060
Do you have any of the original clearance lights? I'm keeping them original and need some replacements I have 4 broken. 2 red 2 amber. Not looking to spend money on replacing all of them, because if they don't match I'll lose my mind.
ThePimentals is offline   Reply With Quote
Old 12-02-2013, 07:05 PM   #527
wmkbailey's Avatar
Engine: 3126
Mine were all corroded and nasty, that was one reason I replaced them. You can ask Porkchop to see if he has any of his. He removed them all.
William
Old 12-02-2013, 07:17 PM   #528
wmkbailey's Avatar
Engine: 3126
I got my battery bank platform welded in.
I welded so scrap 16 ga to the top.
For now I will bolt the batteries to the platform. When I get back from my trip to Indiana, I will make a slide out, so I can get to them when I build the bathroom around them. I need to find a drawer slide that can handle 400 lbs.
Now that I have this done, I can do two things.
1) Measure and order the cables for the batteries.
2) Start putting in the insulation.
William
Old 12-02-2013, 07:34 PM   #529
Chassis: Ward
Rated Cap: 1
Oh those things are so unmercifully heavy!!!
I've got three in my van; thankfully I've never had to mess with them in 2 years. They are AGM's. No Water!!!
gus
Old 12-02-2013, 07:41 PM   #530
wmkbailey's Avatar
Engine: 3126
I have six 90 AH AGM's at 65 lbs each, 390 lbs total.They had a sale on the 90 AH and the plus side they will be easier to move.
William
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 11:55 AM
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 436 02-12-2017 09:38 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 11:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 11:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 07:49 PM
