Old 12-03-2013, 09:35 AM   #531
wmkbailey's Avatar
Engine: 3126
Re: The Journey Visvi 1999 Thomas MVP ER
Looks like I will flip my bathroom around. I was going to put the sink above the battery bank and a closet on the other side. I discovered that my inverter needs to be less than six feet away. So now the closet will be over the battery bank with the shower next to it. The sink and toilet will be on the other side.
I will put the inveter and charger below the batteries. The distrubution pannel and battery monitor above. This will shorten several cables for me.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 12-03-2013, 10:07 AM   #532
Chassis: Ward
Engine: 6.6L Brazilian Ford
Rated Cap: 1
Those cables are expensive too!
Bus Transformation: My CHEAP project >>> viewtopic.php?f=9&t=466640
gus
gusbus is offline   Reply With Quote
Old 12-03-2013, 12:57 PM   #533
wmkbailey's Avatar
Engine: 3126
I just got back from out Battery Plus to have them made. I have one 14' that will go from the battery separator to the bus battery. Now I'm $350.00 poorer.
William
Old 12-03-2013, 02:19 PM   #534
Chassis: Ward
Rated Cap: 1
Yup; I feel your pain! That stuff is expensive. I tied my aux. batteries into my Van charging system. The batteries are just inside the back door. Long ways and many dollars from the back of the van to the battery under the hood.
gus
Old 12-03-2013, 02:58 PM   #535
Diesel Dan's Avatar
Engine: DT466/AT545
...Now I'm $350.00 poorer.
Dang! Now I'm REALLY glad my bus came with a wheel chair lift. I have a large gauge cable running the full length of the bus which I plan to use to connect the house batteries to the alternator via a separator switch.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 12-03-2013, 04:14 PM   #536
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Too late now--but welding cable is much cheaper + works just fine.
Old 12-03-2013, 04:47 PM   #537
If your putting any kind of electronics "under" the batteries, make certain the area is absolutely sealed off or the battery fumes will eat the expen$ive $tuff in a heartbeat.
Old 12-03-2013, 05:11 PM   #538
wmkbailey's Avatar
Engine: 3126
I don't have the equipment to build 1/0 GA cables. So I'm having the experts do it for me.
William
Old 12-03-2013, 05:15 PM   #539
wmkbailey's Avatar
Engine: 3126
They are AGM sealed batteries, so not as bad an issue. The equipment will be sealed off and the back of the battery bank goes to the floor, so I will vent then through the floor. That will have to wait until I get back. Only so much time left.
William
Old 12-03-2013, 05:27 PM   #540
Chassis: Ward
Rated Cap: 1
AGM's are the only way to go if you can afford them. You can mount them upside down if you want and no fumes whatever. I've had mine two years now and I love them . . .no maint. at all; other than making sure they never go below 12.5 volts. The solar panels pretty much take care of that. Sometimes on a real cloudy day I'll have to charge them with the little gen-set I've got but not often. Keep in mind; I live in my van 24/7 for two weeks at a time only going home every other weekend. They've paid for themselves easily in the two years I've had them.
gus
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 10:55 AM
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 436 02-12-2017 08:38 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 10:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 10:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 06:49 PM
