Old 12-17-2013, 09:06 AM   #591
Re: The Journey Visvi 1999 Thomas MVP ER
Godspeed on your journey, we are only driving about 1-1/2
Old 12-18-2013, 08:15 AM   #592
wmkbailey's Avatar
Engine: 3126
Boy have I been busy. I did get the Wabasto moved over to the house battery. It pulls 16 amps at startup, then 8 running. When it shuts off the water pump pulls 2 amps. Right now I have it on full time, but I see that as it gets warmer the Wabasto will run when heat is not needed. Im going to move it over to the thermostat and have it run only when the fans are on. That will also shut down the constant 2 amp draw from the water pump. I will keep it hooked in parallel with the switch so I can turn it on myself, like pre-warming the engine on a cold morning.
I got my composting toilet hooked up. Had to cut a hole in the roof for the vent.
I lined the hole with foil tape to seal it up, don't want toilet fumes in the bus.
Mounting the vent cap was fun. I still had 4 on snow on the roof that is melting. After I kicked it off, I had a wet and cold place to sit.
Here is the vent hooked up to the toilet. All that is left is the power to the fan, and a wall for privacy.
What took most of the night was finishing the mount for the passenger seat and seat belt. I built the rest of the mount on the seat, so I know it would fit. Then welded it to the support I built up front.
I will have to move the seatbelt around. Right now there is about 6" of slack in it when I use it, but for now it will do. I just can't have a large passenger, If you wast is over 46" you are out of luck.
It folds down and is heated, which I have not hooked up yet. ll waiting for the seat swivel, but it may not arrive before I leave.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 12-20-2013, 04:15 PM   #593
thommassey's Avatar
Chassis: All American RE
Engine: 3208TA Cat 250HP
Really enjoying this thread... hope your trip is going well.
TUMBLEWEED (AKA Rufus) build:
viewtopic.php?f=9&t=11121
PICTURES : http://s1338.beta.photobucket.com/user/ ... M-HP/Rufus
thommassey is offline   Reply With Quote
Old 12-20-2013, 06:55 PM   #594
wmkbailey's Avatar
Engine: 3126
So far not so good. First my battery separator got stuck in the on position, keeping both the bus and house batteries connected. I removed the power form the ignition switch that turns it on and the relay still would not release. I found I had to remove the ground side. I can still use it, I just have to turn it on and off myself.
Then while stopping at a PetSMart to get a refill for Durango I found radiator fluid all under the bus.
Lucky it was a cracked overflow container, not the radiator.
I drove all afternoon and evening and could not find a non-pressurized tank. I went to the truck repair shop that I got my inspection at. They did not have anything that would work, they sent me to a Freight-liner repair shop. Freightliner let me come back into the parts area and hunt something down, but no go. Off to a Ford, Mazda, Advanced Atuo. Finally I found an Auto Zone that had a generic one. My old tank hold about 1 gal, this one is only 2/3 gal. I have to remember not to put back a whole gal of fluid.
So I guess I start my trip tomorrow after I figure out how to install this. Freightliner can get the replacement for me from Thomas when I get back.
William
Old 12-20-2013, 08:55 PM   #595
good luck...it will work out........just remember....smile and enjoy.....it really could be worse than it is
Old 12-21-2013, 07:51 PM   #596
wmkbailey's Avatar
Engine: 3126
Another day and another break down with the bus. This time self inflected.
Did I mention torrential rain and fog. It was hard to see, did I mention torrential rain. After getting to Wheeling WV, I decided to hit the highway, visibility was too bad for the back roads, we were having torrential rain and fog. I got into Ohio and turned north on HW 77. I decided to pull off the highway and check and see where to stop for the evening and to eat. As I was pulling off there was this guard rail, but what I did not see was how it hooked out about a foot and a half at the end. I caught it with the side of the bus.
Here is the funny part, just as I hit the guard rail I also hit the rumble strips. I was only going 25 and it shook the bus and made a very loud noise. I thought I ripped half the front suspension off the bus. Lucky for me the rain stopped. I crawled around and under the bus but all I could find was that I ripped the rubber piece that seals the plastic cone that covers the front wheel bearings. I also cracked it, but on the end where the rubber fits. I looked but could not find the rubber piece. Right where I'm stopped is the 1 mile sign for the next exit, so I decided to drive the bus there to get it off the highway. That was when I discovered all the noise and vibration was the rumble strip. Because when I got back on the highway it got quite and smooth again. I had a good laugh.
I talked to porkchop for a little while and we decided I could epoxy a piece over the hole and re-fill it with gear oil for now. Got out handy smart phone and behold a Walmart not three miles from me. AN hour latter I was on the road again. I have photos and will upload them when I have a faster internet than my phone.
So what will be the fun tomorrow? I did not know you had to be a MacGyver to own one of these buses.
William
Old 12-22-2013, 10:56 AM   #597
sojourner's Avatar
Engine: DT408
It is not only good but a requirement!! We're talkin' old school here!! Make sure the cap on the bearing seals properly. It's very easy to repair while things are all in the place they need to be. Dealing with burnt out bearings alongside the road somewhere will be another challenge altogether. Running the highway is no place to jury rig anything. Do what you have to do but as soon as possible get it repaired properly.
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 12-22-2013, 03:07 PM   #598
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
wmkbailey just pulled out of the drive, We had a great visit, swapping ideas. It's always a treat to see how others are tackling some of the same problems you are facing. Also showing off things you have done to someone who appreciates it.
Old 12-22-2013, 10:52 PM   #599
roach711's Avatar
Rated Cap: 19
Originally Posted by wmkbailey
I will have to move the seatbelt around. Right now there is about 6" of slack in it when I use it, but for now it will do. I just can't have a large passenger, If your waist is over 46" you are out of luck.
I had the same problem with my passenger seat belt. With the retractor attached to the seat the belt was too short for anyone to actually belt in. I ended up attaching the retractor up near the roof which gave us lots of slack. Just test the locking mechanism to make sure it works inverted. Mine works fine.
The Roach Motel
Old 12-23-2013, 04:12 PM   #600
wmkbailey's Avatar
Engine: 3126
Well I was driving down the road minding my own business, thinking how nice to be on my second day without bus issues. When I look down and see my air pressure drop below 90 and not rising. I'm almost to where I want to go, so I took it easy and made it.
I open the engine door and right next to the compressor, I have a line that is leaking. I get a new compression fitting and cut it back to good tubing and re-attach it. Man that was a simple fix, but no go.
I call Coachnet and they say the most common issue in this 20 degree temp is the air dryer freezing. So under the bus I go and tack it apart and yes there is ice. I use my heat gun ( lucky my 1000 w inverter can run it) and melt it. Start the bus but only get to about 80 psi. After talking to somewhere, he says that the air dryer has a built in heater. I look at it and the ground wire is hanging in the air.
SO far so good, I will keep a eye on it, if it freezes again, I will replace the air dryer, ti is looking pretty bad.
William
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 443 04-13-2018 09:34 AM
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 10:55 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 10:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 10:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 06:49 PM
