Old 12-31-2013, 10:16 AM   #611
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Re: The Journey Visvi 1999 Thomas MVP ER
I also have "fly by wire" this set up attaches to the pedal. The guy who gave me the plans tried to hook to the engine on his MCI, but couldn't overcome the return spring back there.
Old 12-31-2013, 10:44 AM   #612
JakeC's Avatar
Hey man, just wanted to let you know I've still been following along on your progress. So impressed. That is going to be one warm bus!! Sounds like your trip has been a bit adventurous but so far successful!! Nice work!
Brutus
Old 12-31-2013, 11:01 AM   #613
sojourner's Avatar
Engine: DT408
I have complete plans to add cruise using late model GM truck cruise to anything. All parts bought for about $150. Do some google searches it's quite common.
All I am seeing are ones with electronic engine control. Do you know of any for mechanical controlled engines (with electronic speedo)? Got a specific link?
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 12-31-2013, 11:06 AM   #614
JakeC's Avatar
http://www.ebay.com/itm/Rostra-250-1223 ... 3cc40a8efe
Brutus
Old 12-31-2013, 11:41 AM   #615
sojourner's Avatar
Engine: DT408
Thanks. Definitely a consideration. I'd like to find the DIY plans though for consideration and finding parts if need be abroad (from salvage yards and such).
Old 12-31-2013, 02:42 PM   #616
Chassis: AARE
These are some of the links I got information from
http://ls1tech.com/forums/conversion...driven-tb.html
I used this to get a dual signal from the transmission. I have found while doing some research for something else that a hall effect trigger might be built much cheaper that I found them when doing the research for this project
http://www.dakotadigital.com/index.c...roduct_id=126/
I have a web page that you can see my wiring diagram and some other info here
http://www.somewhereinusa.x10.mx/cruise.html
Old 12-31-2013, 03:02 PM   #617
sojourner's Avatar
Engine: DT408
Hey somewhere,
Thanks so much for the links. I'll be looking into that for sure. very interesting.
Old 12-31-2013, 03:29 PM   #618
wmkbailey's Avatar
Engine: 3126
Hey somewhere,
Same here, it would be good to correct my speedo too.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 01-01-2014, 06:53 PM   #619
wmkbailey's Avatar
Engine: 3126
My air dryer needs to be replaced when I get back. I have had nothing but trouble with things freezing up on me. The other morning I had a air drain on my secondary tank freeze open. I took it off and brought it inside and thawed it out and drained about two drops of water out of it. It has been good since.
Now I do not have pressure in my break system, secondary system seems fine and the over pressure valve on my air dryer keep bowing air every so often. So I have pressure there, but blocked before it separates to the two break systems.
William
Old 01-01-2014, 07:30 PM   #620
Okay,had a glass or two....so air comes out of compressor and will fill primary tank first up until 60/90 pounds whatever cutoff is and then the secondary will air up...?search on busconversionmagazine in the last 2 months same type of issue with air, good luck sorry no more help...good luck
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 11:55 AM
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 436 02-12-2017 09:38 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 11:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 11:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 07:49 PM
