Old 01-03-2014, 07:06 AM   #631
wmkbailey's Avatar
Engine: 3126
Re: The Journey Visvi 1999 Thomas MVP ER
Originally Posted by porkchopsandwiches
That is a lot of $ in fuel for heating! If I was going to live in my bus during cold months I'd absolutely put in a wood stove. Glad to see it is keeping warm though.
All my steel supports are exposed and they have frost on them.
That is a lot because the bus its empty and I'm only heating air. I have no thermal mass in here to help hold heat. It is not fully insulated, I still have places where the steel is exposed. I'm also still using the bus heaters, one in back and one in front. I bet my front gets to about 75 before the heat gets to my thermostat.
Once I get the rest of the insulation up, I still have another inch to put in and all the steel will be covered. I will use ducted heaters to get more uniform heat and I plan to install cabinets, furniture, wood floor and things that will help hold heat.
I do not plan to live in an empty and not finished insulated bus, using very inefficient heaters in 0 degree temps. This is only a temp setup, I had limited time to get ready.
I'm happy at how well it is performing. It shows that when I get done it will work much better.
By the way, it is now minus 8 outside and a nice warm 70 inside.
12 min to heat, 8 to cook back down.
I can still walk on the floor bear foot. I did not expect the heater to keep up in this cold.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 01-03-2014, 07:46 AM   #632
Chassis: Ward
Engine: 6.6L Brazilian Ford
Rated Cap: 1
I've been running an Eden Pure electric heater to keep the chill off over night (can't see your breath). I,ve got no gauge out there. While I'm working during the day I turn on a Big Buddy heater on low. that brings the temp up to working temp. (probably around 60). Supposed to hit -40 here monday without the wind chill. That'll be brutal even for us.
Bus Transformation: My CHEAP project >>> viewtopic.php?f=9&t=466640
gus
gusbus is offline   Reply With Quote
Old 01-03-2014, 07:53 AM   #633
wmkbailey's Avatar
Engine: 3126
I'm glad to be heading back to Maryland today. It will be 40 when I get back on Sunday.
Stay warm.
William
Old 01-03-2014, 09:19 AM   #634
JakeC's Avatar
I think that what you have planned for heat, and with the interior finished, is going to be incredibly efficient. At least relatively speaking. In other news, glad you got your air system figured out! Your dryer may be ok after all. I thought I had issues with mine, when I first drove it back to mn, due to lots of similar symptoms, but once I got the tanks heated and drained, it was fine.
Brutus
Old 01-03-2014, 02:12 PM   #635
sojourner's Avatar
Engine: DT408
It's my understanding that air dryers are basically not something that "goes bad" other than maybe corroding through. As you have found, ice can be a formidable opponent when troubleshooting anything with fluid. The heater element however might be in question. The main problem with air systems as a whole is lack of maintenance and moisture building up corroding things. If the parts are kept dry you can get a very long service life out of them with the exception of the pump which most definitely needs lubrication.
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 01-03-2014, 03:21 PM   #636
JakeC's Avatar
On mine, the pump is lubed with engine oil. Best idea ever
Brutus
Old 01-04-2014, 06:49 AM   #637
wmkbailey's Avatar
Engine: 3126
Same here.
My air dryer is old and rusted. I had a lot of water in the primary tank. That shows it is not removing the water as it should. A replacement is only $140.00, I think it is time for mine to retire.
William
Old 01-05-2014, 06:18 PM   #638
wmkbailey's Avatar
Engine: 3126
We made it home today. We stopped last night for dinner about two hrs away and decided to stay the night. I was not ready to get home yet.
A very dirty bus.
Hey somewhere I took Ohio 250 on the way back. The bus handled the curvy road just fine. I quite enjoyed it, some very good views. But not any shoulders to stop and take a photo.
The bus performed good with out any adventures this time.
William
Old 01-05-2014, 07:24 PM   #639
Chassis: Ward
Rated Cap: 1
Awesome!
Love the pic. That bus is going to be a class act when you're through with it.
I made it back to North Dakota yesterday with mine. I left home a day early because of extremely cold temps today. High today was -21 . On my 1000 mile round trip I don't think my old Ford used a half gallon of oil; I was pleasantly surprised.
gus
Old 01-07-2014, 06:58 PM   #640
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Originally Posted by wmkbailey
Question about riveting.
This is how I plan to rivet the sides of the bus. I'm using the same spacing that the panels around the emergency door uses, 3 1/2" from top then 4 1/2" the rest of the way down.
Here is my pillar after raising the roof.
This is with sheet steel skin over lapped and riveted with above spacing.
My question is; as you can see it will leave two rivets only riveted to the sheet steel skin.
Is this OK, or will this cause an issue later on?
The ribs on my bus are reversed so it looks like the rivets will go into the pipe,I found steel fencepost shaped like the ribs & will fit right over top of the bus ribs, you could use that as filler
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 11:55 AM
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 436 02-12-2017 09:38 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 11:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 11:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 07:49 PM
