Old 01-08-2014, 01:35 PM   #651
wmkbailey's Avatar
Engine: 3126
Re: The Journey Visvi 1999 Thomas MVP ER
Originally Posted by JakeC
And with no thermal mass to store heat! Another inch of spray foam would be awesome, because then you would have a thermal break at the ribs (I'm assuming...).
Yes, When I get everything built inside and have thermal mass, I should be set.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 01-19-2014, 05:28 PM   #652
wmkbailey's Avatar
Engine: 3126
Finally got back out to the bus. I was using the cold weather as an excuse, but I have heat working in the bus. I started the heat up and an hour latter it was 60 inside. I guess I will have to find another excuse. I can't park the bus next to my apartment anymore, because someone has a trailer parked there. I asked them to move over one space so I could back the bus in there, but they refuse to move the trailer. The only other place I can park it is on the other side of the parking area. I have to run 200' of extension cord to reach it. I have just enough cord to reach.
I'm starting to remove the dash and front heater core.
As you can see there isn't much between the interior and the doors for the windshield washers.
I get a lot of cold air through here when driving. I want to seal this up and insulate.
I also want to install my radio below the gauges on the right hand side of my dasboard. There is a second row of empty gauges that I will remove and cut out to fit the radio.
The problem is, behind that area is the relay box for the electronic gear selector we have for our transmission.
When you take it all apart there is enough cable to move it to a new location.
It has about three feet of cable. When the heater core is removed, it will free up a lot of space for storage.
William
Old 01-20-2014, 09:05 AM   #653
Chassis: All American RE
Engine: Cummins 8.3
Rated Cap: 90
wmkbailey,
Have you considered moving the heater core or otherwise modifying it to accomplish the same purpose? I see the huge bulk you're saving; is the extra functionality also that much better than stock? I ask because $450 seems like a lot of money for a smaller version of something you already have. The energy savings seem negligible considering it will only be operating when you're already burning enough diesel to get the engine hot anyways.
Otherwise, could some other heater core from a junkyard or OEM be employed for considerably cheaper?
Just wanting to follow your thought process. I'm budgeting for a skoolie of my own; and that's a half of another thousand dollars right there that I hadn't considered at all.
Jdecker
My build:
http://www.skoolie.net/forums/showthread.php?t=10085
JDecker is offline   Reply With Quote
Old 01-20-2014, 09:16 AM   #654
wmkbailey's Avatar
Engine: 3126
Originally Posted by JDecker
wmkbailey,
Jdecker
1) This is my whole heating system. Not just when the engine is running.
2) I will be living in it full time.
3) Budget is not as much of an issue building the bus. There are some things I will pay more for so they will last.
4) What I have is very loud, to many btu's for the area and not ducted.
I will have just a heater core in each room so I can zone my heat. The other cores are cheaper, this is a dule core. I know porkchop plans to do what you suggest to save money.
William
Old 01-20-2014, 09:30 AM   #655
wmkbailey's Avatar
Engine: 3126
If I had unlimited time I woud look into building my own heaters, but I also plan to install radiant in floor heat. That will take a lot of my time to figure out. If this is not Cadilac building, I don't know what is
William
Old 01-20-2014, 10:03 AM   #656
wmkbailey's Avatar
Engine: 3126
The other thing that will take up my time will be the air conditioning side of the bus. A lot of people here have convinced me to use window units over the roof RV units. They cool better and use less power. They are cheaper to fix or replace. I'm not sure yet how I plan to install them, I would like to have two ducted, one front one back. That way I can use the back unit during the day and the front unit at night. Both if I need the additional cooling.
William
Old 01-20-2014, 10:31 AM   #657
Chassis: Ward
Engine: 6.6L Brazilian Ford
Rated Cap: 1
I'm still trying to decide whether to trash my rear heater or not. I don't really plan on driving the bus much, if at all, in winter. It does take up valuable space in the living compartment. However, traveling home with the bus over the holidays so I could work on the bus in the weeks I was home, that heater did prove to be a valuable asset up here in the hinterlands. I was traveling in sub zero temps in my shirt sleeves.
So I'm torn!!
Bus Transformation: My CHEAP project >>> viewtopic.php?f=9&t=466640
gus
gusbus is offline   Reply With Quote
Old 01-20-2014, 10:39 AM   #658
wmkbailey's Avatar
Engine: 3126
So I'm torn!!
For me I'm not giving up anything, just replacing. They will be used during driving and while parked. That makes my thought process different than most. I want to get rid of the larger and replace with smaller more efficient.
William
Old 01-20-2014, 10:50 AM   #659
Coachwork: blue bird
Chassis: International, 3000, Blue Bird
Engine: Dt360
Rated Cap: 25000
Hi all, I am John and my wife is Shelby, she is a quadriplegic, we bought a handy cap bus 32 feet total length, we have been at home for the last 4 years now and it is time to get out of the house and see the country. I will have many of the same issues as the rest, but with the added equipment for her power chair and Hoyer lift med supplies and the like. One of the many things to consider is cooling and heat. I had gained a lot of insightful ideas from reading the skoolie site.
Looking for that happy place, I've got a home on wheels and I'm going to find it.
Better Tomorrows is offline   Reply With Quote
Old 01-20-2014, 11:32 AM   #660
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
My question is can you use window units while traveling? I know you would need to run a generator but point I'm getting at is haven't come across a system for Crown, could a window unit be mounted & ducted some way to use while driving to cool the driver area only?
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 443 04-13-2018 10:34 AM
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 11:55 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 11:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 11:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 07:49 PM
