Old 01-25-2014, 03:36 PM   #681
wmkbailey's Avatar
Engine: 3126
Re: The Journey Visvi 1999 Thomas MVP ER
Originally Posted by Tango
Suggestion for any roof raise (I've been there) --- before you do any cutting, cross brace both the roof and the lower section (above & below the cut line). Tack weld something like square steel tube from side to side at least every six feet. Makes maneuvering inside a little trickier but it prevents either section from torquing out of shape. Remember that the existing structure is under stress and I can virtually guarantee you it will try to reshape itself when cut free and being jacked up. Just a question of how much...some move more than others. You can remove the bracing as soon as you have a few of the ribs tied back together and secured in place.
Trying to realign things after it is cut can be done but is a bona fide bitch. Ask me how I know.
This is a good idea, I got around it because I had my bus parked on a flat level parking lot. My roof torqued about 1/4 ". It was easy to correct.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 02-16-2014, 08:06 AM   #682
houskou's Avatar
Coachwork: flatnosed
Chassis: amtran/bluebird/thomas
Engine: diesel
where have you gone joltin joe?
The sun is the same, in a relative way, but you're older; shorter of breath, and one day closer to death.
Pink Floyd - Dark Side of the Moon
houskou is offline   Reply With Quote
Old 02-16-2014, 09:42 PM   #683
wmkbailey's Avatar
Engine: 3126
it will warm up this week and I hope to get back out to it again. I miss working on it.
William
Old 02-24-2014, 05:48 PM   #684
Chassis: Saf-t-liner
Engine: Cat 3126 - MD 3060
i need warm weather badly, i want to caulk and paint.. im getting annoyed.
ThePimentals is offline   Reply With Quote
Old 02-24-2014, 06:48 PM   #685
wmkbailey's Avatar
Engine: 3126
We had nice weather this past weekend, but i got sick. Can't wait for spring.
William
Old 02-27-2014, 04:53 AM   #686
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Hey bud, what was the GVW of it when you bought it? I am looking at the exact same model/year to buy.
-Doc
My build thread - viewtopic.php?f=9&t=467197
Old 02-28-2014, 02:41 PM   #687
wmkbailey's Avatar
Engine: 3126
-Doc
33,000 lbs 11,000 on the front axle, 22,000 on the rear.
William
Old 03-09-2014, 08:44 PM   #688
sojourner's Avatar
Engine: DT408
I need to get a role bender, and start making one piece sheet metal front and rear end caps for you fellow skoolies.
Been thinking myself how to use one to make rain caps for the RV windows I want to install. Gonna have to frame above the top of the stock window openings and as such will lose my drip rail at these places.
Travis
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 03-23-2014, 10:44 PM   #689
Chassis: AmTran
William,
I am really interested to see what you will do for your bathroom. You mentioned, somewhere in here, that you were considering putting it in the rear. The bus we may be purchasing is a Rear Engine with some engine air vents poking in and up through the back of the interior. I'm trying to figure out how to best utilize that space. And I read somewhere that others have done the same before. Also, is that a Nature's Head composting toilet? We are also planning on a composter so we won't need to deal with black water, just grey.
I am really enjoying your conversion thread. I love the style of your roof raise! Keep up the great work! Can't wait to see what you do next!
~Sarah
Conversion Thread:
viewtopic.php?f=9&t=467377
scgwagner is offline   Reply With Quote
Old 03-27-2014, 10:44 AM   #690
wmkbailey's Avatar
Engine: 3126
Man, I'm way behind here. I have been in Winter Hibernation mode. I need to get out and back to work on the bus. It may take me a couple weeks just to catch up here on skoolie. I see a lot of new builds.
William
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 11:55 AM
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 436 02-12-2017 09:38 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 11:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 11:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 07:49 PM
