04-07-2014, 11:52 AM
#701
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Re: The Journey Visvi 1999 Thomas MVP ER
Sorry to hear about those morons. Stealing is low brow.
Landlords can suck too. At my apartment complex they HATE my bus. So I have a storage area about 15 miles away. I got lucky, $50/month on a lot that is difficult, at best, to rent. Spaces become available once every 3 or 4 years....... Now that I have my spot I'm NEVER giving it up until we move to Texas hill country. I feel your pain. If y'all were closer I'd offer you use of my truck ('06 Ford F-350 dually with utility bed with genset and air compressor). MD is a haul from here...
BTW, how do you like the Cat engine? The 31XX series I'm not familiar with it unlike the 3406 or 3208s. I haven't had much time to really read the thread, so my apologies if you discussed it before...
M1031
04-07-2014, 12:54 PM
#702
Chassis: B3800 Short bus
In what town did all this happen? I'll add it to my small list of places in this world to avoid
04-07-2014, 07:37 PM
#703
Coachwork: Crown / Pusher
Geuss I'm lucky I havn't had them problems yet, I only get flack from the wife who I love dearly, I bought my house in 08 watered the grass for a month then got the bill, told my wife who was my girlfriend at the time we don't have kids I ripping this crap out & made my front & back yards gardens, she said what will the neibors say, I replied when they pay my water & food bill I'll care about what they say, now they get fresh veg's in the summer & we can about 200 qts for the winter, I installed clothes line for my wife & she loves it, even in winter we hang clothes my ex brother in - law said what will your niebors think I said when they pay my PG&E bill I'll care what they think, my bill over the summer runs $40.00 to $50.00 a month, theirs are $300.00 plus, because we sit outside in the evenings & listen to their AC units running, I bought the bus she like what are the neibors going to say, I said well it's parked behind a gate except when I work on it so when it's parked the only people who see it are the ones on the right & you hear them all the time in their house yelling back & forth to each other how much they hate white people(even before I bought the bus) so I really don't care what they think, other have come by & think it's awesome what I'm doing.
04-07-2014, 07:59 PM
#704
Howdy Porkchop --- I have one of the new 6 speed 2xOD Allisons but have been told that many of the 5 speeds can indeed be re-programed to use all six gears. No idea which years or models but a call to Allison should work out whether it can be done with yours. Go for it and good luck. Let us know what you find out.
04-07-2014, 08:30 PM
#705
Coachwork: Ward
Chassis: Ford B600
Rated Cap: 26
Originally Posted by porkchopsandwiches
It seems alright. Mine has problems. ThePimentals' does too. Wmkbaileys is fine I think. He drove it from md to Indiana over Christmas season with no engine issues. They come in a variety of hp and torque ratings, the ones we have I believe are 210 hp and something like 550 lb ft making peak torque at 1400 rpm. Unfortunately since the trans is only programmed for 5 speeds (actually has 6 speeds but programmed out for speed limiting to 65) you're at 2400 rpm at 65mph which sucks down fuel and makes no power or torque. I've been meaning to contact Allison to see if they can unlock 6th since its not in warranty and not a school vehicle anymore.
The motor has this thing called HEUI or Hydraulic Electronic Fuel Injection. I wrote a bit about it in my thread a while ago. Basically instead of using an injector pump externally like a cummins b series or dt466 or the like, or a cam driven injector like some engines, this motor has a separate high pressure oil pump (600-700 psi) to push down on a plunger in the injectors, squirting fuel in. So there is no plumbing to each injector from a pump or anything, just cast bores in the block for fuel and high pressure oil. It is a clever idea really. However a common failure point is the rubber O Rings that seal the fuel from the oil inlets...if they fail, high pressure oil will enter the fuel return line. It causes no running issues except extremely high oil consumption, because it gets pumped back into the tank. I found this out on mine when I had to add a gallon of oil every hour of runtime, but there was no smoke or leaks. So I pulled a fuel sample and it was BLACK with oil. Fix is as simple as pulling the valve cover, injectors, and putting new o rings on and cleaning the injector bores.
Other than this common failure point I think theyre ok. They have good torque down low which drops off up high cause the Allison trans loves to make this motor rev, which it doesn't want to do. They never smoke while running and barely do on cold starts (never black smoke) because of the electronic injection, fuel is metered precisely based off load rpm and boost pressure. As a result they're pretty fuel efficient, wmkbailey I believe told me he did 10-11 mpg in his bus to Indiana, which is good for such a huge heavy vehicle, considering I had an old bronco that did 8 mpg. CAT parts are EXPENSIVE though. If you go to the dealer for anything other than filters, bring lube if you know what I mean.
I ran 3406 B engines in my semi tractors back in the '90s when I was a trucker, so I KNOW about the expenses. $9K for a rebuild, $12K for an out-of-frame reman, probably double that now. Since I'm looking at this bus I'm driving on my new-to-me route I was just given today, I was curious about your experiences so far. I may just get this bus when it goes to auction. I don't have deep pockets, but this engine appears to be a bit more affordable than the 34XX series I owned back in the day. If I remember right it's a Japanese manufacture.......
04-08-2014, 08:12 PM
#706
Engine: 3126
Man, I stay away for a week and looks at what happens.
I just moved the bus back over to the tattoo shop I had it parked at last year. They are very happy to see me back. They can't wait to see what I do next with the bus.
I have been very lucky with my bus. It runs good. I drive it all the time. My trip to Indiana and back 1600 miles, I averaged 10.7 mpg. I ran all day on the trip up through Ohio is a strong head wind with 50 -60 mph gust and still got 9.6 mpg. My oil is still right on the full line. I did have issues with my air dryer not working. It has a heater and the wire was broke so the water in my tanks froze. I had to heat them up with my heat gun until I got it figured out.
I had a propane 30 amp generator that cost $350.00. I just bought the same one again. I want a nice diesel gen for the bus, but I wont have the money until next year. So this will get me byuntil then, as long as I can keep it safe.
04-08-2014, 11:49 PM
#707
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
Scour Craigslist for diesel gens, I found mine for $300 (dude didn't know what he had). Granted it's air cooled and very loud but it's a real yanmar from 1994 and has a built in fuel pump / parker racor (same brand as Thomas uses) fuel filter / water seperate on it. It came off an ambulance.
04-09-2014, 11:40 AM
#708
Also, look at the RPM of the generator. This is very important in estimating the service life.
To make 60 Hz, AC, the easy way is to join the motor to the alternator shaft and turn 3600 rpm. One turn of the shaft produces one AC cycle. 60 cycles/second times 60 seconds/minute = 3600 rpm. That's what the cheap big-box contractor-style portables do.
The life figure rumors I've heard for 3600 rpm generators are about half of what Nat_ster has published.
I know I have had to order rebuilds done on a few 3600 rpm propane standby gensets, I think in the 900-2000 hour range.
Larger, more expensive gensets, such as big diesels, run at 1800 rpm. The alternators are somehow wound to produce two AC cycles for each revolution. I would expect an 1800 rpm genny to last at least 3 times as long as a similar 3600 rpm model.
There are also some belt drive gennies, where because of pulley size the engine can turn slower for longer life, while still spinning up the alternator to provide 60 Hz.
Finally, there are the inverter generators, generally the smallest output overall but some are big enough for most RV loads. The engines spin fast enough to provide enough current for the transistorized circuits whose job it is to "fake" a 60 Hz sine-wave output. These are the quietest when running at lower rpm.
I have also seen some auctions on military surplus gensets with DC output. Obviously, rpm is not a factor when the output is not an AC waveform.
04-09-2014, 01:07 PM
#709
Engine: 3126
If it wasn't for the fact that I need to run AC, I would get a genset with DC output and just recharge my batteries and run everything off them. I think Nat posted a link to an offroad RV the has two alternators running of it's Diesel engine. The engine is qiuter that a generator and uses less fuel at idle. They just recharge the batteries.
04-14-2014, 07:35 AM
#710
Chassis: Saf-t-liner
Engine: Cat 3126 - MD 3060
You can't think about the maybes. Maybe the tyranny goes and I've got to shell out 9k for a new one.. Maybe the engine siezes. Blah blah. If your going to do that you shouldn't even leave the house. Maybe you get hit by a bus? Live it up guys. If you do what you want and it doesn't work that's great. Way better than just continuing to watch tv and buy other expensive plastic stuff.
