Old 06-13-2014, 12:04 PM   #761
Chassis: All Canadian FE
Re: The Journey Visvi 1999 Thomas MVP ER
Originally Posted by wmkbailey
I'm sold.
No kidding! I'm in. Just made a note-to-self.
fly the coop
Fig. to escape; to get out or get away. (Alludes to a chicken escaping from a chicken coop.) I couldn't stand the party, so I flew the coop. The prisoner flew the coop at the first opportunity.
www.flythecoop.ca
pictureLOVE is offline   Reply With Quote
Old 06-13-2014, 12:42 PM   #762
eyedeal.ink's Avatar
Originally Posted by kenny76
I would think that coating it with another color would reduce the reflective properties of the white paint and maybe even the insulating beads.
How much paint did it take to get the paint work done with the 3 coats on your bus. I ask because I am considering buying the beads and adding them to elastomeric paint I can buy locally and not pay to ship.
We bought the beads and mixed them in with white elastomeric paint you can buy at lowes or home depot (or local supplier), didn't want to pay for shipping weight. We ordered 12 lbs of beads and still have 6 lbs left over for another coat down the road (we painted our floor with the same thing as our roof, reflects heat right?)
"That's,. like,.. your opinion, man...." - the Dude.
eyedeal.ink is offline   Reply With Quote
Old 06-15-2014, 05:25 AM   #763
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Excellent work my man! I have been ordering stuff for mine. Next month she will get 30 days of straight work on her!! Now to get my paint ordered.
-Doc
My build thread - viewtopic.php?f=9&t=467197
Old 06-19-2014, 08:38 AM   #764
Chassis: Saf-t-liner
Engine: Cat 3126 - MD 3060
Yea. The bead board was hard enough for me and I had a helper and my roof is not raised. You are a trooper.
I can't wait to paint my bus. I've had bus kote waiting to go on for 8 months now. I wanted to do it befor winter but I realized I should paint the sides first.
Keep up the good work.
ThePimentals is offline   Reply With Quote
Old 06-20-2014, 10:17 AM   #765
Diesel Dan's Avatar
Engine: DT466/AT545
You may want to shoot me for saying this, but now that you've painted the roof white, I think your bus would look better if you lowered the rain gutter on the raised section of the bus to be on the same plane as the gutters on the front and rear non-raised sections, then smooth out the line where the original rain gutter was to blend it in, and then continue the white paint down to the level of the new rain gutter.
It might pan out like this:
- cut off the raised section gutter and smooth out the transition line
- have a metal shop make you a new gutter the correct length to connect the front and rear sections
- Install the new gutter and then re-paint to cover the areas you modified
It would be extra work, but I think it would look awesome!
Maybe someone could use a photo editing program to render what it would look like. I don't have a program handy right now that would do it justice.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 06-20-2014, 10:31 AM   #766
wmkbailey's Avatar
Engine: 3126
You are right, it would be easier to shoot you.
My roof steel ends at the gutter. The side steel slides up under it. The only connection are the rivets.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 06-20-2014, 10:52 AM   #767
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
I've got nothing in this but, I can use PS and although it would be a lot of work. I think Dan has a point.
Too bad it's not this easy.
Old 06-20-2014, 03:20 PM   #768
Diesel Dan's Avatar
Engine: DT466/AT545
I suppose you could just paint it white and then paint a 3-D looking dark line to imply a gutter...
Gallery:
Conversion Thread:
Old 06-20-2014, 03:52 PM   #769
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
You are right, it would be easier to shoot you. .
Old 06-20-2014, 04:40 PM   #770
Perfect
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 11:55 AM
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 436 02-12-2017 09:38 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 11:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 11:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 07:49 PM
