Old 06-21-2014, 09:53 AM   #771
Re: The Journey Visvi 1999 Thomas MVP ER
I disagree with the looks of moving the rain gutter down........I like the hitch in the line.... in fact I think you should move the rub rails up in the middle to match it and trim a bit off the side skirts as well..... give it an inch-worm type look!! Also will keep people wondering how you bent a bus!
Malkieri is offline   Reply With Quote
Old 06-21-2014, 06:58 PM   #772
Chassis: Saf-t-liner
Engine: Cat 3126 - MD 3060
I just got to the bend in my ceiling with the breadboard and I'm not happy. I really thought it would bend the curve. I might take it all down now.
ThePimentals is offline   Reply With Quote
Old 06-22-2014, 10:16 PM   #773
Diesel Dan's Avatar
Engine: DT466/AT545
I can see what you are saying. I think if there was an angle in the back to match the angle in the front, that would be the easiest thing to do and make it look better.
Edit: what I mean is to just make the gutter follow the angle of the front where the white paint comes down, and then do the same in the rear, so both front and rear gutters make the 45 degree downturn to connect the lower sections, then fill in the little triangle in the rear with white paint to complete the look.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 06-23-2014, 07:38 AM   #774
wmkbailey's Avatar
Engine: 3126
I almost did the same thing. As you can see I made my transition at the bend. The gap I have will be mostly covered by cabinets and such, so I'm not too worried.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 06-23-2014, 07:40 AM   #775
wmkbailey's Avatar
Engine: 3126
The main reason I don't want to move the rain gutter down is the advantage the roof raise gives you, because now the windows will be at eye level.
William
Old 06-23-2014, 11:09 AM   #776
I was just at the lumber yard and we talked about any and all possibilities for bending plywood. And there is only one type that will work and it's 53$ a sheet. I've heard that lauan plywood is available with all the grain in the plys going the same direction so that it bends easy but no one there had ever seen that. I wonder if I flip the bead board over if the grooves will act like a kerf and will allow for bending.
Old 06-23-2014, 06:11 PM   #777
Check around your area for "Bender Board" --- Used by cabinet makers for curved work. Comes with kerfs cut all the way across the back. Nifty stuff.
Old 06-23-2014, 09:03 PM   #778
Chassis: B3800 Short bus
I had decent luck bending 1/4" oak plywood. There are pictures of the process about 3/4 of the way down the page on my build thread: http://www.skoolie.net/forum/viewtopic.php?t=466764
Old 06-25-2014, 09:07 PM   #779
crazycal's Avatar
I haven't been followig your build for a while. I think the bus looks great.
I'm hungry!
You Gotta Let Me Fly
Old 08-15-2014, 07:46 PM   #780
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Whats been happening on your build? It's been awhile, I've had to take a break and work on the house
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 443 04-13-2018 09:34 AM
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 10:55 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 10:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 10:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 06:49 PM
