Old 11-28-2015, 01:04 PM   #851
crazycal's Avatar
Bus looks like it's coming together nicely.
I'm hungry!
You Gotta Let Me Fly
Old 11-28-2015, 02:15 PM   #852
Engine: 190hp 5.9 Cummins
Looking good.
Doing the flooring last is the best way. You will be glad you did it that way.
Old 11-29-2015, 10:48 AM   #853
wmkbailey's Avatar
Engine: 3126
That is good to hear, I was starting to worry. One nice thing, I wont have to worry about getting paint on the floor
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 11-29-2015, 10:54 AM   #854
wmkbailey's Avatar
Engine: 3126
Hey Red, they are not 2 x 2's they are pieces used in outside porch railings. they're just the size I'm looking for. I didn't want to use 2 x 4's or 2 x 2's but something bigger that a 1 x 1.
William
Old 11-29-2015, 10:57 AM   #855
wmkbailey's Avatar
Engine: 3126
Hey Somewhere,
I'm in Lafayette right now. Will be here until the 8th. I head back for a week to pick up my daughter and granddaughter and come straight back until the 26th. Then I head to Florida.
Let me know if you are free over the next week and I will come out for a visit.
William
Old 11-29-2015, 11:07 AM   #856
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I'll cook you a steak or some chili if you want somewhere to park your bus for a bit in FL. We're in Sorrento/Apopka about a half hour north of Orlando.
Would love to meetup.
We are close to Disney if that's something you'd like to do with the little one.
Old 12-01-2015, 08:01 PM   #857
wmkbailey's Avatar
Engine: 3126
Hey EastCoastCB
I'm heading down south of Tampa FL I will be there on Monday the 01/04/2016. I would be coming through your area on Sunday.
William
Old 12-01-2015, 08:08 PM   #858
wmkbailey's Avatar
Engine: 3126
Re-doing the Bedroom finished… for now.
We got all the items I wanted to get done this time around finished. There will always be things to do.
The hardest issue was the fill piece where the roof curves and comes to a point because of the roof raise.
There is nothing to attach this piece to, but you don’t want to leave it open. My dad came up with the solution. We used the can of expanding spray foam. From experience we know it to be very sticky. So we sprayed it in to fill the void and pressed the wood to it and it stuck. When the foam harden, the piece is now “glued” in.
We did the same on both sides and then used cardboard to get the curve piece figured out. It all came together nicely. Since the bottom section of this piece should be close to the top section of the back piece we measured down the distance to the 1 1/4″ over the windows and cut. It fit like a glove.
We did cut insulation and fill in the gaps before we screwed in the wood. Then added the cabinets back in. Now I can’t wait to get some paint on the walls.
Before this was completed and fully insulated. It was always 2 degrees cooler in the back, I only run the front heater. I know this has made a difference because now the back is 1 degree warmer that the front. Next will be to tackle the front section.
We will start in on this, this week.
William
Old 12-02-2015, 11:18 AM   #859
Looking great, man!
Old 12-02-2015, 03:33 PM   #860
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 8 Assengers 2 ATV's
Balusters for a railing, OK then.
Smells Like Teen Spirit: Conversion of 1999 Thomas MVP porkchopsandwiches Skoolie Conversion Projects 443 04-13-2018 09:34 AM
Our Skoolie Journey Ponyracer Skoolie Conversion Projects 60 03-19-2017 10:55 AM
Starting My Conversion Journey Mark Antony Wray Conversion General Discussions 26 10-28-2014 10:41 PM
The Skoolie Journey usafny Short-Bus Conversion Projects 15 04-05-2010 10:37 PM
Advice for my journey??? cobaltcry Veggie Oil | WVO | Biodiesel | SVO 0 10-20-2008 06:49 PM
