Old 10-01-2008, 11:02 PM   #11
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
Re: The Land Barge ...
She's looking real nice. I love the choice of colors (not the staples, the bus) .
Roasting8 is offline   Reply With Quote
Old 10-08-2008, 11:19 AM   #12
Hex
Hex's Avatar
Coachwork: Bluebird, Model 3800
Rated Cap: 42
Okay ... I've been doing some work on the Barge, but it's slow going ...
It took me two days or so to tape it up and with the 'plasticity' of the green Rustoleum, I'm having to be really careful taking the tape down, so I'm only about half done with that ...
But, here's what the front look like with the mirrors all painted up and re-attached ...
I've got some pics with the 'brass' rub-rails un-taped, but it was so dark by then that they didn't really come out.
I'll try to get some more tonight before it rains. (I want to get all the a paper off the windows before it becomes pulp!)
And, I got all the seats broken loose. I'm still storing them in the bus for now, as we have some scavengers around who'll probably be more than happy to take the scrap for sale.
BTW - Anyone have a really simple and fast way to get those seat backs to come off the frames? Blue Bird seems to have used four million staples on just the base of the one I poked at ...
Hex is offline   Reply With Quote
Old 10-13-2008, 10:35 AM   #13
Hex
Hex's Avatar
Rated Cap: 42
Okay, update time!
I had once again called the DMV answer line/call center in order to clarify what sort of insurance coverage to get. Had a nice guy who walked me through filling out/altering the form to set up for a H/WH (House on Wheels). I had to list that the bus had been painted, seats removed, and 'school bus' markings and lights had been removed.
With the bus painted and seats out (and pictures taken and developed to show it just in case - thanks to whoever on the board suggested it someplace!), I was off to the DMV. 30 minutes and two supervisors later, I had nice, plain plates for a H/WH.
The first supervisor said that it had to be registered as a bus because the original titles had 'bus' on them. But, the computers wouldn't let the transaction go through because my passenger seating (currently 0) made it not 'qualify' for bus plates. Seems you have to have seating for 15 in NY to get bus plates. So the second (and apparently more important) supervisor came in and said basically what the guy on the phone had - with the exception of having me re-write the alterations to the bus in yet another place on the form.
I -am- however in violation, she warned me, because the weight of the bus is now -less- than what's stated on the title, although I can fix this by running the bus down to the scales and getting a reading, then returning to the DMV for an amendment. That said, she handed me the plates!
Anyhow, here's what I've got so far. I'll be ripping up the floor and covering the light holes on the top as my next projects ...
Old 10-13-2008, 11:19 AM   #14
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Congrats on the tags and kudos on the paint! She looks VERY nice!
Griff is offline   Reply With Quote
Old 10-13-2008, 10:06 PM   #15
Hex
Hex's Avatar
Rated Cap: 42
Thanks ...
The paint needs a bunch of touching up (if you look close), but we're happy.
And, once I got going with the seats, it went pretty quick. I was able to get the rail-side bolts off with a rachet, but the aisle-side ones took a grinder.
Now to pull up the flooring and those heating lines ...
Old 11-05-2008, 05:41 AM   #16
wdbowers's Avatar
Year: 90
Coachwork: Ward
Engine: 8.2 Detroit
Rated Cap: 70
I noticed the gold/brass paint right off in the pictures of your rig. Where did you find the gold paint and is it an outdoor paint? I would sure like to paint my Vanderbus gold with black rub rails. Nice looking bus and looks like a good paint job.
Will
wdbowers is offline   Reply With Quote
Old 11-05-2008, 04:10 PM   #17
Hex
Hex's Avatar
Rated Cap: 42
It's actually Rustoleum brass spray-paint. It says it's not recommended for outdoor use, and since painting, it has lost some of the shine, but for brass it just looks like it has a mild patina to it.
I don't know that I'd want to do a whole bus in spray-bombs, but it might work out, and they do make a 'gold' ...
I didn't have a lot of time to research, since we had to get it registered ASAP due to local regs. But I expect that a body/paint shop should be able to point you to a real quantity of a metallic paint ...
And thanks! I'm planning on touching up the paint in the spring, so if you get a good lead on metallics (like brass ... ) I'd love to know!
Old 11-05-2008, 04:31 PM   #18
Steve's Avatar
That paint job is great once you realize why it is painted that way.
Old 11-06-2008, 09:06 AM   #19
Hex
Hex's Avatar
Rated Cap: 42
And that's just what we were aiming for ... (though those lights cost about $2500 to get reproductions! )
And it was cool ... Using the HyTech ceramic additives to the cream paint -really- jave it a sort of canvas texture ...
BTW: I've started to rip up the floor and found a fun hole at the seam between the rear starboard wheelwell and the floor panel behind it. Wire-wheel cleaned it up nicely, and I think I'll try out my welding skills to patch it from the inside, then, I'll get to cleaning up the underside and painting ...
Old 11-06-2008, 10:05 PM   #20
Elliot Naess's Avatar
Engine: 5,9 Cummins
I just stumbled in here.... Very nice paint job! May I suggest painting the top of the cowl brown also, to eliminate that little hickup in the lines. In other words, make the hood look as long as possible.
I cannot see it well enough, but the destination sign window may be secured with a rubber molding that has a removable center strip. You would pull the center "rope" out, and then the rest of the molding would bend enough to get the glass out. However, after 13 years, the rubber may be too stiff to work with. I expect the glass shop would have a mile or two of it. Wear goggles when working with glass.
And congrats on finding a stick shift!
Elliot
The Land Lubber LandLubber Skoolie Conversion Projects 58 10-26-2015 08:21 PM
Parking on Private Land in North Carolina J-9 Everything Else | General Skoolie Discussions 5 03-01-2015 02:43 PM
A weekend at the Land travelinwithus On the Road | Travel, Trips, Camp Sites, Tailgates 4 07-02-2013 09:47 AM
Canadian Land and Skoolies - Perfect Match dgorila1 On the Road | Travel, Trips, Camp Sites, Tailgates 2 08-02-2011 09:15 PM
Best bus for BLM land? TygerCub Conversion General Discussions 16 05-11-2009 06:52 PM
