Old 08-26-2010, 09:21 AM   #31
Hex
Hex's Avatar
Coachwork: Bluebird, Model 3800
Rated Cap: 42
Re: The Land Barge ...
And, I'm apparently competent at working on air brakes, at least at the end points of the air lines. I got the broken release valve replaced and was able to move the bus and have it hold pressure with out the brakes on.
Now I only have to secure the release valve to the frame and find a way to grind off the bolts to the starboard valve so I can replace that one ...
Hex is offline   Reply With Quote
Old 08-29-2010, 07:53 PM   #32
Hex
Hex's Avatar
Rated Cap: 42
Good bus day.
My wife and I got a workable final floorplan hammered out, and the boy and I got the walls marked out on the floor with tape.
With all that in place, I started trading around windows. It looks like we'll end up losing three windows out of the 22 we've got, so it seems pretty acceptable.
AND the walls won't seriously interfere with the roof hatches, so all's good. It's a flurry of activity (for me, not for some of you other folks! ) in a forward direction.
I'll try and get a scan of the floorplan up relatively soon, and my wife found a bunch of bus floor work pictures on her camera, so I'll be uploading some soon too ...
Old 08-30-2010, 12:27 PM   #33
Hex
Hex's Avatar
Rated Cap: 42
Okay, so here's the firmed up floorplan.
The red windows are the emergency exit windows, and the black ones are ones that I'll end up skinning over.
I'll still have to figure out where fun things like the hot water heater and such are going, but this gives a much nicer start, and a rather convenient travel path overall.
Where the walls meet the emergency hatches, I'm planning on angling the walls so that the bathroom/bunk area are still separate once the doors are closed ...
Old 08-31-2010, 06:43 AM   #34
houskou's Avatar
Coachwork: flatnosed
Chassis: amtran/bluebird/thomas
Engine: diesel
I am not sure if it is polite to offer a critique, but I will and if it is, then I ask your forgivness.
Consider this if you will:
Switch the toilet and shower location- doing so will allow you to
1) use the space between the bunk and now shower location. You can built the floor up onto the wheel hump and mount the toilet on the higer level floor ( I see this in a lot of stick/staples - I think they have the Black water tanks under the "lift".
2) in case you really needed to, you can run past the toilet and out the emergency exit door.
designed to be a friendly suggestion
The sun is the same, in a relative way, but you're older; shorter of breath, and one day closer to death.
Pink Floyd - Dark Side of the Moon
houskou is offline   Reply With Quote
Old 08-31-2010, 09:13 PM   #35
Hex
Hex's Avatar
Rated Cap: 42
No need to ask for forgiveness. I love feedback and constructive criticism. It saves me from not thinking things through.
But I thought about some of that already. I wanted to keep the extra space over the wheelwell as an accessible wet-wall, as well as an extra storage area ...
But the extra-high toilet is something to think about ...
Thanks!
Old 08-31-2010, 09:29 PM   #36
yankeflyer's Avatar
Chassis: Safe T Liner
Engine: 3208 turbo
the preferd craper - http://www.skoolie.net/forum/viewtop...=1728&start=45
yankeflyer is offline   Reply With Quote
Old 09-01-2010, 08:55 AM   #37
Hex
Hex's Avatar
Rated Cap: 42
If only I had the money ...
Old 09-01-2010, 04:30 PM   #38
Seeria's Avatar
ugh.... I must hurt you now
Your layout gave me a few ideas on changing the bed setup I had planned, gosh darn it all to Arizona and back. Gonna need more wood
Old 09-01-2010, 07:39 PM   #39
I see someone else has the idea for the emergency exit in the shower - my thoughts are about the same, but I was thinking no sink, and putting the hall entrance into the shower area, requiring less room in front of the toilet. A shower curtain could be used instead of a hall door, unless your crew suffers from barge-in-itis.
Old 09-01-2010, 08:32 PM   #40
Hex
Hex's Avatar
Rated Cap: 42
Eep!
Well, it was somewhat of a trick, since we didn't want to lose the back door, we wanted to keep as many windows as possible, as well as the roof hatches, -and- have a place to stand up if the 'master bed' was still a bed ...
But it certainly wasn't my intention to disrupt your plans. Really!
It was actually my wife's idea, since trying to fit in a decent-sized shower was causing some floorplan issues. Her argument was that it could work like a 'mud-room' if needed, especially taking into consideration that we've got a couple of decent-sized dogs whose paws seem to magnetically attract dirt and other fun stuff. And of course, you can walk through the shower area to get out the door anyhow, so that's not an issue.
The sink worked in there nicely to give one clean wetwall, to keep the plumbing simple and easy to drain come winter.
But I can see the entrance through the shower thing too. It's a perfectly reasonable floor, and showers do tend to be pretty empty and open when not being used ...
The Land Lubber LandLubber Skoolie Conversion Projects 58 10-26-2015 08:21 PM
Parking on Private Land in North Carolina J-9 Everything Else | General Skoolie Discussions 5 03-01-2015 02:43 PM
A weekend at the Land travelinwithus On the Road | Travel, Trips, Camp Sites, Tailgates 4 07-02-2013 09:47 AM
Canadian Land and Skoolies - Perfect Match dgorila1 On the Road | Travel, Trips, Camp Sites, Tailgates 2 08-02-2011 09:15 PM
Best bus for BLM land? TygerCub Conversion General Discussions 16 05-11-2009 06:52 PM
