Old 03-22-2014, 10:54 PM   #21
Re: The Land Lubber
BTW --- HyTech makes a clear finishing coat that reportedly extends the life of the insulating paint quite a bit plus also makes it more UV & dirt resistant.
Old 04-23-2014, 12:53 PM   #22
Chassis: All American RE
Re: The Land Lubber
Me and my buddy Frank (caterpillar mechanic) changed all the fluids and filters on the 8.3. When we changed the fuel filter, the primer pump didn't seem to work so we had to fill the filter with fuel and he pulled some magic with a gasoline soaked rag held over the intake vent behind the passenger windows. It fired up, but the primer will need to be replaced or fixed. Haven't changed the belt or the air filter yet, I'll order them as soon I find out what it's gonna cost to get my Jeep fixed first. We also flushed the coolant system with distilled water and refilled it with antifreeze and distilled water.
also finally had some decent weather, so we painted the roof. Turned out great so far. We taped off the old bluebird and black stripe, to preserve that, but painted the entire roof otherwise. after the first coat was down, I was snowblind up there, couldn't see sh!t. Check the blog for pix, I still can't figure out how to put pics on here from my I phone. I'm a loser I know.
LandLubber is offline   Reply With Quote
Old 04-30-2014, 07:52 PM   #23
Re: The Land Lubber
Well the tape pulled off some of our original black stripes. Oh well just have to touch em up with some One Shot. The roof paint is very nice. This stuff spreads thick. We plan on using Hytech's clear coat to seal it up.
after we pulled off all the tape, it was time to level the bluebird. We used land scaping timbers(cut into 2 foot pieces) with treated 2x6 s(cut into 11.5 inch pieces) (width of tire roughly). Got a 20 ton jack from lowes and lifted the bus about 100 times.
Its not perfect, but it's in the bubble front to back and side to side.
We are going to MO for the weekend, so construction begins a week from Sunday.
Check out the blog for pics.
Old 05-10-2014, 06:02 PM   #24
eyedeal.ink's Avatar
Re: The Land Lubber
haha, I can relate to the blinded by the white thing, and that last sentence made me laugh, haha. Dig the tattoos by the way.
"That's,. like,.. your opinion, man...." - the Dude.
eyedeal.ink is offline   Reply With Quote
Old 05-11-2014, 07:24 PM   #25
Chassis: bluebird
Rated Cap: 16
Re: The Land Lubber
Don't be so hard on yourself about pics. You're not a loser just because your slightly technologically impaired.
You should have seen me trying to teach my mother email....
orangepeel91 is offline   Reply With Quote
Old 05-21-2014, 07:46 PM   #26
Re: The Land Lubber
We got the bed/platform built. We are using a Kreg joint jig system. So far we really like it. We are not carpenters so things are just built the way we can figure.
We also covered the rear wheel wells. Should have some pics up on the blog soon.
The bed has two sections. We put a hinge on front section, so you can access the rear engine hatch that is in the rear bench/engine hump. We built the bed to where the bottom of the mattress will rest on the engine hump in front of the rear window/emergency hatch. There will be storage under the bed where there's not an engine hump. If that makes sense.
We painted the floor with old left over paint. gonna burn up every old gallon I have laying around on it. We are gonna floor it too, but I figured it couldn't hurt for now. We used plywood on the woodwork. It isn't 3/4 it's like 19/32 or some BS. So I had to cheat back the collar on the kreg drill bit, after that no more screws coming through the face.
Thanks for the humor and I like your tattoos as well eyedeal.ink
this thing is getting to be a lot of fun. FO REELZ.
Old 07-01-2014, 11:08 PM   #27
Re: The Land Lubber
Haven't posted in a while. We deleted 5 windows. To delete the windows I took 29 gauge flat sheet metal and wrapped it around a 34 sheet of plywood cut to fit in the window's place. I liquid nails the metal to the wood and let it sit for a couple days. Then we folded/broke the metal around the wood. Then cut another piece of wood to fit against the back of the wood with the metal. This sandwiched the metal that is folded around between the two pieces of wood. the two pieces fill the hole perfectly and gave me a place to kreg jig the walls too. The back 3 windows on both sides stay, then the next one(s) are deleted. These are the bathroom and closet walls. Then a window, and then another one deleted for the front BR wall and closet wall. The bathroom and closet will close or open up to each other. there are three windows deleted on the starboard side the third one being the fridge.
We have up all the bathroom walls, We have to redo one of them. It isn't level, which is key for the dual purpose doors. I have pics on my Facebook page
Robbie Wilson (should be the one with the bama logo).
We have one wall up on the other side. The way we did our template for the ceiling was with a 3 ft wide roll of brown paper that we have had for ever. I use it to cover up my table when I make ribs, I have no idea where my wife got it, ask your wife. J/K. anyway, we used it to bend and cut with scissors to fit, then applied it to the wood and it worked very good. We kreg jig ed the walls to the floorboards, and to the window deletes. Then applied some brackets to the top in a couple of places. Sorry for no pics, but we think it looks good. Should be some pics on the blog (mentioned in earlier post). We are loving our progress and we are getting a lot done.
Now for a question. Do you guys think that if a strong enough trailer jack was mounted at each corner or wheel area, could they be used to level the bus? I know I would have to get under it to crank it, but I'm gonna be under there anyway.LoL. just a question I'm not married to it, but thought it could be a very affordable/temporary leveling system. Don't laugh too hard.
Old 07-02-2014, 02:14 AM   #28
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Re: The Land Lubber
i wish you had some photos, i would love to see your bus
proconsul100 is offline   Reply With Quote
Old 07-02-2014, 08:36 AM   #29
Re: The Land Lubber
It always says the files are too big. This is the only site that I have had to photo bucket first and then I don't have a clue how to share from there. Too many steps. I all ready run a tattoo shop and build a bus when I'm not doing that. I don't have time to learn a new way to do it. Last night it actually said the attachment was full. Full of something. sorry though. check em out on our blog or on my Facebook page. My name is Robbie Wilson in Hattiesburg, MS. lots of pics on there.
Old 07-02-2014, 10:45 PM   #30
Re: The Land Lubber
http://s1151.photobucket.com/user/robwi ... slideshow/
new pictures in the slideshow.
Parking on Private Land in North Carolina J-9 Everything Else | General Skoolie Discussions 5 03-01-2015 02:43 PM
The Land Barge ... Hex Skoolie Conversion Projects 91 01-04-2015 09:52 AM
A weekend at the Land travelinwithus On the Road | Travel, Trips, Camp Sites, Tailgates 4 07-02-2013 09:47 AM
Canadian Land and Skoolies - Perfect Match dgorila1 On the Road | Travel, Trips, Camp Sites, Tailgates 2 08-02-2011 09:15 PM
Best bus for BLM land? TygerCub Conversion General Discussions 16 05-11-2009 06:52 PM
