10-13-2015, 12:18 PM
#21
Chassis: Thomas
Engine: 3208 CAT
Got a ton more done, but still a long way to go
10-13-2015, 12:21 PM
#22
Chassis: Thomas
Engine: 3208 CAT
I'm so glad to have this old nasty insulation out
10-14-2015, 07:54 PM
#23
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
There's more of that behind the walls below the windows you haven't cut out yet..........
10-28-2015, 12:04 PM
#24
Engine: Cat 3208
Rated Cap: 84 px
Hey CityRatt
Since you have the same model as mine:
There is a door handle on the front of the bus right below the driver's side window. What is that for? Mine might be broken, but it just spins in place, doesn't seem to open, close or lock anything.
Thanks.
10-28-2015, 12:36 PM
#25
Chassis: Thomas
Engine: 3208 CAT
Originally Posted by OMGIBoughtABus
Hey CityRatt
Thanks.
I'm not sure, ill check it out next time in up at my bus to work on it.
How's the deconstruction coming along? have you gotten the roof panels done yet?
10-28-2015, 12:46 PM
#26
Engine: Cat 3208
Rated Cap: 84 px
Ach! I keep failing to get out the screws where I have stripped the heads. I couldn't use the angle grinder on them the last two weekends, it was pouring rain and I didn't want to use the extension cord in the wet. When I get a reasonably dry Saturday (which by the forecast won't be this weekend) I'll try cutting slots in them like you did and put a flat blade screwdriver in them.
I wish that handle were for locking the front door, it would sure make my life a little easier if I could secure the door without using the driver opener handle thing.
10-28-2015, 02:06 PM
#27
Chassis: Thomas
Engine: 3208 CAT
10-28-2015, 02:37 PM
#28
Engine: Cat 3208
Rated Cap: 84 px
Oh crap, are you having to cut off the wall panels above the chair rail?
Also, did you grind off the rivet on the little metal plate between windows or is there another way to get it off?
10-28-2015, 02:52 PM
#29
Chassis: Thomas
Engine: 3208 CAT
Yes, that's the only way to get the side panels off is to cut them off under the window. as far as the metal plate, its held on by a rivet, grab a 1/4 inch drill bit and drill it out, that is by far the easiest way to do it.
10-28-2015, 02:55 PM
#30
Engine: Cat 3208
Rated Cap: 84 px
Thanks, man!
I look forward to your roof raise. If you make it look easy enough, I might change my mind about not raising mine.
10-30-2015, 10:12 PM
#31
I learned the hard way that gloves and goggles are not enough when grinding. A thick long sleeve shirt will help protect your arms.
10-31-2015, 12:09 AM
#32
Engine: 190hp 5.9 Cummins
Leather apron and jacket.
Wide window welding helmet with clear lens. Better than face shield because of neck, side and top of heat protection.
Remember, some fabrics light on fire from only sparks. This is why I wear leather.
11-02-2015, 02:32 PM
#33
Chassis: Thomas
Engine: 3208 CAT
was able to get the side panels off this weekend, hoping to get the windows out this upcoming weekend in preparation to do the roof raise over thanksgiving weekend.
11-02-2015, 02:50 PM
#34
Engine: Cat 3208
Rated Cap: 84 px
Is that kitty litter for the standard purpose? That's what I keep in my bus for now, along with a roll of tp and some grocery bags. Just in case.
11-02-2015, 04:43 PM
#35
Chassis: Thomas
Engine: 3208 CAT
HAHA, I'm working out in the country, no need for any of that.
12-31-2015, 12:11 PM
#36
Chassis: Thomas
Engine: 3208 CAT
