Old 04-11-2019, 10:19 AM   #1021
Brewerbob's Avatar
I followed Elliot's example and I had the same rattling so, from the inside, I tack welded along the top in 4places in each window opening.
Here's to hoping that won't be needed with one row and spray foam. That might make welding difficult. Maybe I'll take it for a spin thru some Baltimore streets before foaming. Some of the potholes are near as big as the bus.
Old 04-11-2019, 01:18 PM   #1022
I had concerns when hanging side skins also. I have them tucked up under the hat channel, but with out removing the rivets from the drip edge and running the metal up there to secure would be a major amount of extra work. There is nothing to secure the top of the new skin to the top of the bus. So my plan also was to tack weld down along the top of the skin and then seam seal it.
o1marc is online now   Reply With Quote
Old 04-12-2019, 07:31 AM   #1023
Brewerbob's Avatar
To each their own but just NOPE!! And yes it was a lot more work taking that single row of rivets out. Not much easier putting them back as it turns out either. I'm not looking for nor an I getting a show room finish by any means but I'd be worried about the weld marring the outside. That and I trust rivets more than my welding.
Old 04-22-2019, 07:25 PM   #1024
Elliot Naess's Avatar
Engine: 5,9 Cummins
Time to take the worn-out turn-signal switch by the horns.
But I cannot even get into the horn button to remove the steering wheel so I can work on the turn signal switch!
The fluting sure looks like it is meant for a hand to simply grip it and unscrew it. But there are more notches than I have fingers on one hand, so maybe not. Or I am not strong enough.
Who has done this job -- successfully?
(Photo is actually of Albatross, but same type steering wheel.)
Elliot
Old 04-23-2019, 12:43 AM   #1025
Engine: 5,9 Cummins
And of course... soon as I overcame my Fear Of Scratching Anything, the horn button lifted right out of the fluted knob.
(Also, I asked a pro. )
Elliot
Old 04-23-2019, 06:47 AM   #1026
Brewerbob's Avatar
Good deal.
I'm more interested in this. Who is this pro of yours?
Old 04-23-2019, 06:11 PM   #1027
Engine: 5,9 Cummins
Well, strange as it may seem... this culturally deprived community where I live... actually does have schools, and even buses, and a technician or two. But I am careful not to make a nuisance of myself to them.
Elliot
Old 04-24-2019, 06:57 AM   #1028
Brewerbob's Avatar
Smartass!!
I'm not sure where the bus yards are here. I know of a couple of spots they get parked at but there's no garage there. Not sure how they would feel about answering questions either or wandering around in their yards. I don't know any even casually. I do have a skoolie maintenance forum bookmarked somewhere.
Roof Raise - Building My Own Flat Roof iverSUN Conversion General Discussions 26 02-18-2019 10:41 AM
Roof Raise ~ Cutting Roof ABOVE Windows ?? chev49 Conversion General Discussions 3 12-04-2012 02:07 AM
Roof raise: TMI !! thommassey Everything Else | General Skoolie Discussions 15 12-09-2011 01:58 AM
Roof raise Rod Conversion General Discussions 1 03-08-2008 05:51 PM
Roof Raise ~ Cutting Roof ABOVE Windows ?? pixemoss Skoolie Conversion Projects 6 12-31-1969 07:00 PM
